How much is autopilot on commercial flights today?
Old August 31st 06, 08:24 AM posted to rec.aviation.piloting
John Gaquin
Default How much is autopilot on commercial flights today?
"Mxsmanic" wrote in message
How much of an average commercial flight on a large airline and
aircraft today is done automatically,
I used to routinely hand fly to 20-25K on departure, and from 10K down on
arrival, just for the enjoyment of it. There were some exceptions, such as
an approach in serious weather, or at the end of a ten hour flight, when
everyone is already tired. Better to let the machine do it, and just
monitor.
Old August 31st 06, 09:25 PM posted to rec.aviation.piloting
Scott Skylane
Michael Nouak wrote:
/snip/With HDG 360 selected the A/P doesn't slowly drift to 002,
then realize it's off a bit, correct to 358, then to 360 again, then drift
away again to 357 and so forth. It holds HDG 360. The same goes for
altitude,
/snip/
Well, Micheal, perhaps if you hand flew the aircraft a little more
often, this wouldn't be such a challenge.
Happy Flying!
Scott Skylane
Old September 1st 06, 01:16 AM posted to rec.aviation.piloting
Mxsmanic
John Gaquin writes:
monitor.
From the way people talk, I get the impression that it may be more fun
flying a simulator than the real aircraft today, since the simulator
offers more challenges and is far more forgiving if one fails to meet
the challenge. I suppose if the simulator run is required to keep
one's job or license, it might be stressful, but surely there is
simulator time available for "fun" or at least discretionary use for
pilots?
As a passenger I always liked takeoff and landing, with cruise being
okay (as long as it didn't last for hours and hours). Nowadays,
though, with all the overhead of air travel, it's just not worth
flying for the short experience of takeoff and landing. I have the
impression that the situation is similar for pilots, with much of
normal flying reduced to pressing buttons and turning dials.
Old September 1st 06, 07:32 AM posted to rec.aviation.piloting
John Gaquin
I don't think I would agree with you on that, although some might. De
gustibus.....
....but surely there is
pilots?
Those simulators probably cost way more to operate than a small plane, and
there ain't nothin' free in aviation. :-(
Old September 1st 06, 11:19 PM posted to rec.aviation.piloting
Mxsmanic
John Gaquin writes:
I meant in comparison with the large commercial aircraft that they
simulate. Flying a small plane wouldn't be the same experience,
although some might prefer it.
Old September 2nd 06, 05:57 AM posted to rec.aviation.piloting
Capt.Doug
"Scott Skylane" wrote in message
Depends on the stability of the aircraft in question.
D.
Old September 5th 06, 11:23 PM posted to rec.aviation.piloting
Michael Nouak
First of all, sorry, mxs, for the late reply but I've been working...
"Mxsmanic" schrieb im Newsbeitrag
Michael Nouak writes:
Oh yeah: I didn't gain any flying experience either from keeping the
needles
centered. And I didn't get to read my newspaper.
So you're saying that even flying the aircraft yourself is essentially
just a matter of watching the needles? Is this because you must stay
exactly right on the flight path? I take it there is very little
margin for pilot discretion on commercial flights.
Let me start again with the short answer, which is, surprise: yes
And now a bit more long-windedness:
To be sure, commercial a/c will fly happily on full manual, i. e. with A/P,
F/D and A/T off. There is no problem flying visual patterns until your tanks
are dry if you're so inclined. You could navigate by pilotage if you wanted
to. You could take off from St. Louis and say to yourself: "If'n I jess
follow that thar rivah down south, b'gosh at some point I must be in
Nawlins." OK, so my twang is pretty bad (hey, I'm just a furrinah :-)), but
I think you get the point.
Unfortunately, that's not what airlining is about. In a commercial
environment, it is your job, as a pilot, to fly SIDs, STARs, and Airways
with best possible precision. The reasons for that precision requirement are
quite numerous. As far as SIDs and STARs are concerned, more often than not
the main reason is noise abatement. Obstacle avoidance is, of course,
another good one! On Airways, the reasons may be to make ATCs job of
providing separation easier; to stay clear of prohibited airspace; etc.
Obviously, best possible precision is achieved by the A/P, which happens to
be linked to the Flight Management System (FMS), which calculates the
required track. However, when flying manually, whether by choice or
malfunction, the next best level of precision is provided by the F/D, which
is also linked to the FMS. And that's what I meant by "keeping the needles
centered." It's my job to fly the required track as accurately as possible,
and I do that best by following the F/D. If the F/D fails, the next best
level of precision is provided by the Navigation Display, which shows, among
other things, the required track, an airplane symbol, the heading I'm flying
and the track I'm flying. With both A/P and F/D inop, I would then try to
manipulate the controls such that the airplane symbol is over the track line
and the indicated track flown coincides with the required track.
I think you can see that a lot of equipment needs to fail to lower the best
possible precision to the level of pilotage.
With all that said, it is possible to deviate from the required track if
necessary. Best example, especially at this time of the year, would be if
you saw a TS (either visually or on weather radar) lying across your track.
A short note about A/Ls:
Long years ago I came into CDG on a flight from LAX and noticed that
the landing was glassy smooth despite essentially zero visibility (in
fact, I didn't know we were on the ground until I saw buildings in the
distance rushing by outside the window). At the time I thought it was
just a very good pilot. Now I suppose that it was actually an
autolanding--the best pilot of all.
During an A/L, the A/P will put the a/c down in the Touch-Down Zone, come
what may. I've seen A/Ls that were smooth as glass, and others that ended
with a pretty solid thump. I'm glad to report that the smoothest landings
I've seen were performed by either myself or my human colleagues!
Crews will usually elect to perform an A/L well before the weather is such
that it is an absolute requirement. With a reported ceiling of 250' and fog
patches, it makes little sense to hand-fly the approach, only to see that at
200', big surprise!, you're in a fog patch and have to go around. It would
also be rather difficult to explain to management.
HTH!
Michael Nouak
remove "nospamfor" to reply:
Old September 6th 06, 01:37 AM posted to rec.aviation.piloting
Mxsmanic
I'm surprised that noise abatement is still an issue. Modern
high-bypass turbofans are very quiet compared to their turbojet
ancestors of a few decades ago.
I used to live directly beneath the approach path of a very large
airport and had aircraft flying over my house every few minutes on
most days, but I never even noticed any noise. However, some people
down the street in a retirement community constantly complained about
the noise. I'm not sure how they managed to hear it when I didn't.
Old September 6th 06, 02:06 AM posted to rec.aviation.piloting
Emily[_1_]
I work for a manufacturer of high-bypass turbofans and they're still
extremely loud. I also live next to one of the busiest airports in the
country. Believe me, there's not much difference between old and new.
Old September 7th 06, 01:27 AM posted to rec.aviation.piloting
Mxsmanic
Emily writes:
extremely loud.
Turbojets are ear-splitting even from the observation decks from which
I used to watch them. Turbofans are hard to hear more than a few
hundred metres away. They may sound very loud, but that's only
because it's hard to remember how low turbojets were. Military
aircraft can serve as a good reminder of how loud engines can get (for
an extreme example, the SR-71 is a good test, with its turbojets that
cruise in afterburner).
How can you be so sure? There isn't much of the old around any more.
KAP140 autopilot and a KLN94 GPS question STICKMONKE Instrument Flight Rules 5 November 12th 05 05:06 AM
18 Oct 2005 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 October 19th 05 03:19 AM
Another Addition to the Rec.Aviation Rogue's Gallery! Jay Honeck Home Built 125 February 1st 04 06:57 AM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 13th 03 12:01 AM
Part 91 Commercial Glider Rides to be Outlawed? Vaughn Soaring 9 October 27th 03 10:26 PM
