#11
Does Kinkos have a large format printer? The one near me does. Larry "01" LS3-a USA |
Eric Greenwell wrote: I assume Winpilot's database has these same closed airports, so how do you deal with those? Can you delete or modify them in the database? Is there a listing of these errors somewhere so every pilot doesn't have to do each bad airport listing by hand? This is actually a big reason why I switched from Winpilot to SeeYou Mobile. I can edit my SYM turnpoint/airport database for my local area, removing "ghost" airports and adding non-charted landing areas. Not easy to do in Winpilot (at least I couldn't find an easy way to do it!). It does take a little work during the off season, or when preparing for a safari, but I like the result. Plus it doesn't overlap airports and co-located turnpoints (I can make them the same point, with unique symbol). It would be nice if we had updated US-wide lists of actual, seen-with-eyeballs-from-the-ground, useable airports/airstrips. With the current GPS navigation/mapping equipment available, it would make off-airport (or known landable location) landouts a much rarer event. I've made several straight in final glides to airports that I had never been to before, using my GPS, getting there just high enough to put the gear down and land. So far, every time it has been a good airport (again, using carefully "vetted" local turnpoint data). I would be leery of doing that to a private strip on a sectional, though - too often I've overflown them to find them long gone! Wasn't there a project in the West US a few years ago to document known landout locations? Final suggestion - if each glider operation documented all the landable airports within reasonable XC distance and used them for turnpoints exclusively, it might be a start. With AATs becoming the norm for tasking, it makes sense to use only landable locations for turnpoints, IMHO. Kirk 66 |
Eric,
I don't use the WinPilot database at all. My hardcopy map is from SeeYou with landout locations (airports, airstrips, fields, etc) from my own turnpoint database. My turnpoint database is created from several well developed airfield and turnpoint databases. (Crystal Squadron, Agua Fria River Racers, ASA, etc etc etc). Every year or two I solicit help from my fellow rASArs to scrub this database using satellite imagery, eyeballs on the ground, etc to tweak the database. The same turnpoint database is loaded into both my WinPilot and LX7007. But the LX7007 has its aviation database, which is updated once or twice a year from their web site, and it seems to be pretty good. Anything but those $#^* sectionals! 2NO |
I did my first map printing at Kinkos by printing to PDF (in 11x17"
page size) from SeeYou (as described in my earlier post). I took the PDF files to Kinkos on a thumb drive and printed and laminted them right there. A good print-to-PDF solution is deskPDF from docudesk dot com; a license is $20 US. If you laminate them, here's a tip: pre-fold your map where you want the creases, then laminate. This makes it much easier to fold it where you want it folded after lamination. 2NO |
Most Kinos have large format printers. However, printing on anything larger
than 11x17 gets pricy. Mike Schumann "Gary Emerson" wrote in message et... Mike Schumann wrote: If you are going to be a serious user, you want to spend the $250 for a full license for Global Mapper. Another option that I have used is to use Acrobat Distiller to save a printed sectional. This however requires a full Adobe Acrobat license. In the end, you still need to have access to a wide format color printer. There is no free lunch..... Mike Schumann "Henryk Birecki" wrote in message ... Once you have sectional images you can use (free) Flight Display (http://www.soaringpilotsoftware.com) to do the rest. Sectionals can be downloaded from http://www.naco.faa.gov/ecomp/Catalo...S+DIGITAL+DSEC for $1.50 each to make them visible download Global Mapper (http://www.globalmapper.com). The free version allows you to stitch up to four images together. Form there on you have to save an image - this leaves a lot to be desired as you can only save what you have on the screen (from what I remember). I used screen capture and Corel Paint to create a "sectional" of "western US" (west of 112W in the north and 113:30 in the south) Cheers, Henryk Birecki "BB" wrote: The season is coming. Has anyone figured out a software package that can download sectionals or wacs, put turnpoint markers on them based on the turnpoint exchange files, and print out, avoiding the yearly cutting pasting and marking job? Thanks John Cochrane BB Does Kinkos have a large format printer? -- Posted via a free Usenet account from http://www.teranews.com |
Tuno wrote:
I did my first map printing at Kinkos by printing to PDF (in 11x17" page size) from SeeYou (as described in my earlier post). I took the PDF files to Kinkos on a thumb drive and printed and laminted them right there. A good print-to-PDF solution is deskPDF from docudesk dot com; a license is $20 US. PDFCreator is free. http://sector7g.wurzel6.de/pdfcreator/index_en.htm Jeremy |
On Jan 22, 3:04 pm, "Matt Herron Jr." wrote: GlidePlan will be able to do this in the next release (1.2) scheduled for February. I think this may end up being the best solution for creating and managing your sectional charts. Remember, the FAA frowns on a non-current sectional in the cockpit. A current chart is essential if you need airport frequency info or to stay out of airspace you shouldn't be in. (yes, checking with FSS is also required before each flight to ensure nothing's changed) Matt provides free sectional chart upgrades as new ones are released, so I can download and print *current* chart segments as needed. So once you buy GlidePlan, you're set for a few years of free updates. Or, you can "roll your own" tools as described in other posts, for at least the same money and probably a bit more busywork to get to the final product. I use pdf995 (free nagware with $9.95 license) to generate an 11x17 document that I then scale to 8.5x11, which reduces it to near WAC scale. Text is small but readable. I then put these pages into heavy duty page protectors and "bind" the 5-10 pages that make up the area I fly in. Am looking forward to being able to import waypoints so I can create custom and FAA legal charts for contest flying. -Tom |
Ted
Be carefull, See you has some of those as well!!!! "Tuno" wrote in message oups.com... Ha!! The latest sectionals I've seen for Arizona have airports that have been reported closed to the FAA for years. So define "current". What we need in cockpits is "useful". |
| Thread Tools | |
| Display Modes | |
| Customizing Sectionals | Mike Schumann | Soaring | 14 | October 10th 06 12:54 AM |
| Sectionals | Simulators | 1 | July 21st 06 01:45 AM | |
| free digital sectionals | Jose | Piloting | 22 | July 26th 05 08:37 PM |
| class C and B comms on sectionals? | Magnus | Piloting | 31 | April 27th 04 10:49 PM |
| Old Iowa City Sectionals on line! | Jay Honeck | Piloting | 4 | December 17th 03 10:59 PM |
