Temporarily removing fuel and replacing it into the same aircraft
Old July 24th 07, 12:47 AM posted to rec.aviation.piloting,rec.aviation.owning
Andrew Gideon
Default Temporarily removing fuel and replacing it into the same aircraft
On Mon, 23 Jul 2007 12:52:18 -0700, Brian wrote:
I have to agree with Michael, there are a lot of experts who know rules
that don't exist.
There's even a FAR which states this. I don't recall which, off hand, but
you could get it by calling your local FSDO.
- Andrew
Old July 24th 07, 03:08 AM posted to rec.aviation.piloting,rec.aviation.owning
: Recently another FSDO inspector told a local 141 flight school that
: all the gas caps on their aircraft needed to be painted Red. I am
: still trying to figure out which hat or book he might have pulled that
: rule out of. Maybe someone here knows?
Perhaps the same theorem we used in a math course in graduate school.... the "CRE."
Complete-Rectal-Extraction
-Cory
* Cory Papenfuss, Ph.D., PPSEL-IA *
* Electrical Engineering *
Old July 23rd 07, 08:51 PM posted to rec.aviation.piloting,rec.aviation.owning
John Godwin
B A R R Y wrote in
. net:
Does anyone know of a FAR that prohibits removing fuel, avgas in
this case, and then putting it back into the same plane? The
plane is flown for part 91 service only.
Nope. Maintenance shops do it all the time. The shop I'm familiar with
have special containers and procedures (comply with fire and other
safety codes).
Old July 23rd 07, 09:35 PM posted to rec.aviation.piloting,rec.aviation.owning
Maxwell
"B A R R Y" wrote in message
. net...
Does anyone know of a FAR that prohibits removing fuel, avgas in this
case, and then putting it back into the same plane? The plane is flown
Examples:
1.) The plane is 50 pounds overweight for conditions. 10 gallons is
siphoned out into a clean, single-purpose, approved for gasoline
container. The sealed container is stored in a safe place. 2-3 hours
later, upon completing the trip and returning to the field, I pour it back
into the tank.
2.) I want to calibrate a fuel dipstick, so I remove a gallon at a time
while taking readings. After I read the tank, I return the fuel to the
tank.
I've been told this is a violation. The person who tells me this can't
cite a FAR, and I can't find one in my own search.
Defueling is common practice in the airline business. We always defueled
before bringing in both narrow and wide body aircraft. I feel certain they
reused the same fuel.
Old July 24th 07, 01:38 PM posted to rec.aviation.piloting,rec.aviation.owning
B A R R Y[_2_]
Now that you mention that, I seem to remember a crewmember telling me
how the MD-88 I was aboard was ferrying fuel from DFW to SJO.
Old July 23rd 07, 10:04 PM posted to rec.aviation.piloting,rec.aviation.owning
Al G[_2_]
. net...
Examples:
into the tank.
tank.
I hope it is not a violation, I've had to do this at remote mountain
airstrips
for years. I have seen tanks calibrated(Sticks & Gauges) in an approved
shop.
Al G
Old July 23rd 07, 11:11 PM posted to rec.aviation.piloting,rec.aviation.owning
pgbnh
Greater likelihood is that you may be violating an AIRPORT rule. If your
field does not permit self-fueling, then the activity you note would
probably be considered a violation. But FAR's???? Naahh !
"Al G" wrote in message
. net...
Examples:
back into the tank.
tank.
airstrips
shop.
Al G
Old July 24th 07, 03:12 AM posted to rec.aviation.piloting,rec.aviation.owning
In rec.aviation.owning pgbnh wrote:
: Greater likelihood is that you may be violating an AIRPORT rule. If your
: field does not permit self-fueling, then the activity you note would
: probably be considered a violation. But FAR's???? Naahh !
: "Al G" wrote in message
My friendly-neighborhood AIRPORT manager tried to mandate no self-fueling of aircraft shortly after we shelled out just
shy of $2000 for an autogas STC for our PA-28-180. I pointed him in the direction of the regulations regarding restrictions on
public airports that accept federal funding. Included in those (can't find the link at the moment) is a requirement that pilots
can fuel their own aircraft for non-commercial use. Non-issue after that.
-Cory
Old July 24th 07, 03:51 AM posted to rec.aviation.piloting,rec.aviation.owning
150flivver
Some FBOs have a policy that prohibits fuel that has been removed from
an aircraft from going into any other aircraft. They'll use the
"used" fuel for AGE (ground equipment) but won't pump it back into an
airplane for liability reasons (could have become contaminated in the
airplane they took it from, perhaps?). I don't know of anything that
prohibits a private owner from defueling his part 91 aircraft and
refueling it with the properly stored "used" fuel. Common sense
requires the fuel to be kept free of contamination and proper safety
measures utilized in the refueling process.
Old July 24th 07, 04:21 AM posted to rec.aviation.piloting,rec.aviation.owning
Morgans[_2_]
From the things I have seen, there is even more danger in defueling. There can
be considerable static electricity generated in fuel falling into a fuel
container.
Planes have been burned to the ground, and the hangar with it. I'm sorry, but I
don't remember where I read these articles.
Replacing innertubes without replacing tires? Ben Jackson Owning 28 November 6th 06 05:54 PM
Removing 100LL Fuel Stain Jeff Home Built 7 September 20th 05 09:45 PM
FOLO: Replacing fuel cut-off valve with non-a/c part??? Michael Horowitz Owning 10 February 23rd 05 05:35 AM
Fuel quality control standards for aircraft rental/fuel sales... [email protected] Owning 19 January 19th 05 05:12 AM
Replacing fuel cut-off valve with non-a/c part??? Michael Horowitz Owning 46 January 15th 05 11:20 PM
Copyright ©2000 - 2026, Jelsoft Enterprises Ltd.
Copyright ©2004-2026 AviationBanter.
