Pete wrote: "AL" wrote in message ... Hi, Here is a newbie question. What are the merits and the pitfalls of rail vs ejector launchers for guided missiles? I suppose bombs have to be ejector launched and rockets rail. Whenever I visit an airshow, I ended up scratching my head. A general rule for missiles might be: Ejector racks next/on the fuselage Rails away from the fuselage. underwing and wingtip. Ejector racks kick the missile out from the fuselage to get out of the airflow, to clear other protuberances (other missiles, etc) and also to limit the burn effects from the missile motor. Consider if the F-4/Sparrow were on rails. The front missile can't launch without burning the aft missile, and the aft missile can't launch because the front missile is in the way. (Not counting the fact that two of the fins are recessed into the fuselage, and the missile body itself is in a slight recess) Pete So a AIM-9 when mounted on the fuselage willl be ejector launched or are they limited by design? -- AL New anti-terrorism tool, "Fly naked" http://www.alfredivy.per.sg |
they limited by design? All AIM-9's are rail launched. Fuselage mounting of one would require a short pylon and a rail attached to it. |
"Bob Martin" wrote in message ... So a AIM-9 when mounted on the fuselage willl be ejector launched or are they limited by design? All AIM-9's are rail launched. Fuselage mounting of one would require a short pylon and a rail attached to it. A-7 http://www.fas.org/man/dod-101/sys/ac/a-7-dvic154.jpg Pete |
"Pete" wrote in message ... "Bob Martin" wrote in message ... So a AIM-9 when mounted on the fuselage willl be ejector launched or are they limited by design? All AIM-9's are rail launched. Fuselage mounting of one would require a short pylon and a rail attached to it. A-7 http://www.fas.org/man/dod-101/sys/ac/a-7-dvic154.jpg Looks like it fits the discription well, doesn't it. |
"Pete" wrote A general rule for missiles might be: Ejector racks next/on the fuselage Rails away from the fuselage. underwing and wingtip. And of course, to any "general rule", there is an exception. A-7 Little pylons w/ rails, mounted to the fuselage. http://www.fas.org/man/dod-101/sys/ac/a-7-dvic154.jpg Pete |
On Wed, 12 Nov 2003 04:00:33 GMT, "Pete" wrote:
"Pete" wrote A general rule for missiles might be: Ejector racks next/on the fuselage Rails away from the fuselage. underwing and wingtip. And of course, to any "general rule", there is an exception. A-7 Little pylons w/ rails, mounted to the fuselage. http://www.fas.org/man/dod-101/sys/ac/a-7-dvic154.jpg Pete As with the F-8 and F-104 Al Minyard |
On Wed, 12 Nov 2003 11:11:56 -0600, Alan Minyard
wrote: On Wed, 12 Nov 2003 04:00:33 GMT, "Pete" wrote: "Pete" wrote A general rule for missiles might be: Ejector racks next/on the fuselage Rails away from the fuselage. underwing and wingtip. And of course, to any "general rule", there is an exception. A-7 Little pylons w/ rails, mounted to the fuselage. http://www.fas.org/man/dod-101/sys/ac/a-7-dvic154.jpg Pete As with the F-8 and F-104 Al Minyard Certainly the F-8 mounted AIM-9s on fuselage pylons, but don't think you'll find any Zippers with such. Strictly wing-tip mounts as I recall. I don't think there's a "general rule" for rail vs ejector. Certainly free-fall weapons are ejector released, predominantly to insure clear and immediate separation from the airframe. Missiles, it seems, depend upon the size. Smaller missiles tend toward rail mount since they obtain an initial stabilized vector from their launch run. Larger missiles, with a larger impulse motor, seem to lean toward ejector release with an umbilical that allows for motor fire once clear of the airframe. Examples would be the large AGM-12C Bullpup (ejector) compared to the AGM-12B (rail). Or, the AGM-45 Shrike (rail) compared to the AGM-78 Standard (ejector). |
you'll find any Zippers with such. Strictly wing-tip mounts as I recall. The Zipper can carry them on the wing-tips, as you stated, but also on a double belly pylon, just in front of the main gear doors. _____________ José Herculano |
The F104G had a double rail pylon (2xAIM9s) that could be mounted on
the center fuselage station. I don't know if the C had the same capability. FWIW USAF experimented with a 104A carrying a Genie (MB1) nuke rocket on an extendable rail hung on a center fuselage station. I think the problem was lack of precise ranging information for an accurate launch. (Glad they didn't do it - nukes were always a PITA.) Walt BJ |
On Wed, 12 Nov 2003 17:47:36 GMT, Ed Rasimus wrote:
On Wed, 12 Nov 2003 11:11:56 -0600, Alan Minyard wrote: On Wed, 12 Nov 2003 04:00:33 GMT, "Pete" wrote: "Pete" wrote A general rule for missiles might be: Ejector racks next/on the fuselage Rails away from the fuselage. underwing and wingtip. And of course, to any "general rule", there is an exception. A-7 Little pylons w/ rails, mounted to the fuselage. http://www.fas.org/man/dod-101/sys/ac/a-7-dvic154.jpg Pete As with the F-8 and F-104 Al Minyard Certainly the F-8 mounted AIM-9s on fuselage pylons, but don't think you'll find any Zippers with such. Strictly wing-tip mounts as I recall. I don't think there's a "general rule" for rail vs ejector. Certainly free-fall weapons are ejector released, predominantly to insure clear and immediate separation from the airframe. Missiles, it seems, depend upon the size. Smaller missiles tend toward rail mount since they obtain an initial stabilized vector from their launch run. Larger missiles, with a larger impulse motor, seem to lean toward ejector release with an umbilical that allows for motor fire once clear of the airframe. Examples would be the large AGM-12C Bullpup (ejector) compared to the AGM-12B (rail). Or, the AGM-45 Shrike (rail) compared to the AGM-78 Standard (ejector). There was a seldom used set of rails that mounted on the C/L just aft or the front gear door. I don't think they were used operationally, but they did exist. Al Minyard |
| Thread Tools | |
| Display Modes | |
| Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 04:13 PM |
| Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | December 2nd 04 08:00 AM |
| Questions from a newbie. | Andrew Tubbiolo | Home Built | 9 | September 14th 04 02:40 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 04:07 AM |
| Basic Stupid Newbie Questions... | John Penta | Military Aviation | 5 | September 19th 03 06:23 PM |
