Change the name to trainers.
Old November 23rd 03, 10:39 AM
Corey C. Jordan
On Sat, 22 Nov 2003 19:10:26 -0800, Mary Shafer wrote:
On Sun, 23 Nov 2003 00:26:55 GMT,
(Corey C. Jordan) wrote:
On Sat, 22 Nov 2003 23:23:07 -0000, "Simon Robbins"
Flight Simulator implies replicating the
dynamics of the science behind the process, which is plainly modelled only
very simply in a "game."
Please define for me what is specifically modeled "very simply" in Aces High
or MSFS.
The dynamics of the airframe. Frequency, damping, poles, zeros,
transfer functions, the stability and control coefficients of the six
equations of motion, the atmosphere, the actuators, controller
dynamics, mass characteristics, that kind of stuff. As well as the
flight control system.
The mathematical model of the vehicle, in other words. That which
makes each airplane fly like that kind of airplane.
I spent a lot of my career determining this stuff so it could be put
into engineering simulations. Read Iliff & Shafer on the estimation
of S&C derivatives for the Space Shuttle to see how we determine such
numbers and put them into the mathematical model used in the
simulation. You'll find it on www.dfrc.nasa.gov, in the technical
reports section.
That's very interesting and extremely impressive work.
However, can anyone tell me what data is used to generate the mathmatical
model coded for the previously mentioned simulators?
My regards,
Widewing (C.C. Jordan)
http://www.worldwar2aviation.com
http://www.cradleofaviation.org
Old November 23rd 03, 01:35 PM
Simon Robbins
"Corey C. Jordan" wrote in message
No, but the procedure for simulation is approached from a different angle.
For example, a "true" simulation of an aircraft will model the atmosphere
and airframe so that the resultant parameters determine its performance,
i.e. the exit parameters will cause (for example) a Spitfire to roll at say
45 degrees a second, whereas a PC simulator will use a previously defined
input parameter to dictate the aircraft rolls at that rate. It's not a
simulation of the airframe, but of its known performance. Not the same
thing. You're not going to be able to design an aircraft and predict it's
flight envelope using MS-FS because you have to start by knowing the
performance envelope you're wanting to simulate. A militray simulator will
take the design of the aircraft and inform you of its likely real-world
envelope.
Obviously there's varying different methods and levels of fidelity. I'm not
trying to denegrate PC sims, I love 'em and it's the main reason why I spend
a fortune at regular intervals upgrading my PC. But I'm not under the
illusion that they compare in method or fidelity to the "real" thing.
(Favourites being Falcon 4 SP3, EAW and FS2002.)
A good example is at (generally) how badly departed flight is modelled. They
generally model the instability of the aircraft and its predicted behaviour
outside the envelope, rather than the extremely complicated chaotic dynamics
which go into causing that behaviour. Anyone who's performed spins and
stalls in a Cessna and then tried the same thing in MS-FS or any WW2 prop
sim will likely agree.
Si
Old November 23rd 03, 01:49 PM
ArtKramr
Subject: Change the name to trainers.
Date: 11/23/03 4:35 AM Pacific Standard Time
Message-id:
envelope.
Si
And of course no one has ever said that MSFS or any other home PC simulator
program was a military simulator. But hope springs eternal. (:-))
Regards,
Arthur Kramer
344th BG 494th BS
England, France, Belgium, Holland, Germany
Visit my WW II B-26 website at:
http://www.coastcomp.com/artkramer
Old November 23rd 03, 06:02 PM
Mary Shafer
On Sun, 23 Nov 2003 12:35:11 -0000, "Simon Robbins"
envelope.
No, no, no. Only at the very beginning do we use predictions based on
the design. Those predictions come from the wind tunnel, CFD, and
prior experience. The instant we get such data from flight we update
the simulation with the actual, not the predicted, numbers.
Simulators are not tools used to predict the actual flight dynamics at
all. This is exactly backward. Simulators mimic the real thing. The
flight envelope is usually defined by _design_ limits, like load
factor and qbar.
Read the paper I mentioned. You'll find a very complete explanation
of how the actual data is used.
The PC games use a very generic model, not a detailed model of the
specific vehicle. They're not predicting anything, either.
That's usually because we don't have data for post-stall flight.
Aircraft are not necessary unstable in that region, either. Stall and
spin don't imply instability.
Mary
Mary Shafer Retired aerospace research engineer
Old November 23rd 03, 06:41 PM
Kirk Stant
"ArtKramr" wrote in message
Flight Simulators as used on PC's should not be called simulators because
they
simulate too damned little. Call them flight trainers. That is a far more
accurate description by far. Except the ones that are just games. Call
them
flight games. After all else has failed, always resort to reality no
matter
how much it hurts.
I've been following this (and the related thread) and cannot believe
the bull**** you have been saying. First, a little background and
some definitions: I'm a retired AF WSO, flew F-4s, have time in
several other fighters, lots of small plane PIC, and currently fly
about 200 hrs a year in competition sailplanes. I also did a tour
running the Air Force SIMCERT program, which certified all fighter
"simulators" and training devices. Since retiring, I have spent the
last 9 years as an F-15C/E Subject Matter Expert, and probably have
more time in the F-15E WST than anyone alive.
Now, first of all, a "Simulator" is a very specific beast, according
to the FAA. There are several levels of fidelity, but the highest (as
used by the airlines and - rarely - by the military) can be used in
place of actual flight time (requires full visuals, motion, etc).
Everything else is considered a "training device". And all of you who
think military fighter "sims" are so high tech would be in for a
surprise - the majority are pretty basic, with the emphasis on cockpit
fidelity and flight dynamics. Visuals are way behind what is available
in the PC game field, and motion is not used. So to say that PC
"simulators" are not sims but fighter "simulators" are is bogus -
neither is!
On the other hand, only a bonehead would even think to equate a PC sim
with no cockpit and only a small monitor with a real "simulator" - but
on the other hand that little PC device can be used as a really nice
training device; the key is to define what is being trained. And
guess what, the military (and airlines) use a lot of lower fidelity
devices to teach various tasks - systems, emergencies, etc.
So, Art, get off your high horse - a PC-based "flight simulator" can
be a game, or a training device, or a way to pretend to be flying, or
just a fun way to spend some time. And it is a "simulation", just not
a "Simulator" per the FAA definition. And I think only you seem to
care about what it is called. The accepted convention is to call the
PC software "simulations" to differentiate them from arcade-style
games, and in the military you get scheduled to go to the "sim" even
though it is technically an Weapons System Traner. But actually only
Airline pilots get to really fly a "simulator".
As far as training value of PC simulations; I firmly believe that they
can be useful, as long as the task to be trained is precisely defined
and the sim (and hardware) is carefully matched to that training need
- which is what the Navy does with MS FS for it's students at
Pensacola. The more experienced your are, you actually need less
overall fidelity as long as there is high fidelity in the task you are
training - you basically ignore the rest and can concentrate on
solving the specific task at hand.
Finally, your description of the B-26 trainer is fascinating - but by
current definitions (and yours in slamming PCs) was not a Simulator at
all (after all, the pilots didn't really have to fly it, they were
just going through the motions) - it was a training device! And so was
the Link Blue box no-one ever claimed it was a realistic simulation of
flying!
Bottom line, Art, qwitchubitchin and just let the young kids (and
older kids like me) enjoy our PC sims (IL2- FB is awesome). And the
next time you get on a commercial jet, or talk to a young military
pilot, ask them if they ever play on a PC sim- you might be surprised!
BTW, B-26s are cool, but A-26s rule!
Kirk
Old November 23rd 03, 07:21 PM
Ron W
"Kirk Stant" wrote in message
om...
because
they
more
Call
them
matter
how much it hurts.
Some deleted
Excellent post Kirk. With Art's years at Madison Avenue, he knows, much
more than the rest of us, that the originator is the one that names his
product.
"Simulator" is a for more sellable name than "trainer". Our Art, the
group's
lovable WWII veteran curmudgeon has been acting as a troll. I'm sure he
knows
that Bill Gates will certainly rename MS Flight Simulator to MS Flight
Trainer
now that he has seen the error of his ways! ;}
Old November 23rd 03, 07:23 PM
Simon Robbins
"Mary Shafer" wrote in message
Ok, I take your correction. But my point was essentially that pc sims
generally concentrate on the back end of the simulation process, i.e. what
is represented to the operator, rather than the front end, the inputs to the
process. i.e. accurate descriptions of the airframe qualities and
environmental modelling.
Si
Old November 23rd 03, 07:48 PM
Corey C. Jordan
Kirk is exactly on target.
There are more than a few who find the online combat sims to be fabulous tools
for teaching Situational Awareness and ACM. Because the aircraft are simple
(we are talking WWII aircraft with minimal systems to manage), and with the
systems themselves being simplified even further, the emphasis is placed upon
the specific function of air combat. Even the USAF Academy has used Aces High as
training tool and to my understanding, maintains several active accounts for its
cadets.
As I stated in the other related thread; "Think of Aces High as a simulator
within a game.... Art is right to some degree, but the simulator fans are also
right in some respects. Understanding this allows one to place these sims/games
in their proper perspective. Just because a guy is a terrific sim pilot doesn't
mean he'd display the same talent flying real aircraft. Possibly not. However,
as a combat pilot trainee the sim player will have a significant advantage in
SA, ACM and tactics knowledge over someone with no sim experience at the outset
of training. Therein lies the value beyond simple entertainment."
Perhaps, some do not believe this to be true. Well, the proof is in the pudding
as the say. Which is why I always invite everyone to try Aces High or even the
earlier Warbirds (both developed by the same engineering and software team).
There are active duty fighter jocks who participate. I know of several airline
pilots who enjoy flying these sims as well.
Many partcipate because they enjoy the competition of battling real people
rather than artificial intelligence. Other's join in because they enjoy the
genre and sense of history it creates. Others simply love anything related to
flying. And, there are those who simply enjoy the gaming aspect.
The reason these combat sims are so successful is that they appeal to many
different people, with many differing expectations of what "fun" is. Seriously,
if it was not entertaining to some degree, who would bother?
Yet, the military has nothing that comes even remotely close to the immersion
and intensity of these combat sims. Furthermore, you don't need massively
complex flight models to accomplish the learning of SA and ACM.
A final point. On any given night, especially weekend evenings (around 9 PM east
coast time US), there are more fighters flying in Aces High than the Luftwaffe
had available for the Battle of Britain. Like I said, it's extremely immersive
and intense.
My regards,
Time to change the air in your tires Rich S. Home Built 18 March 22nd 04 07:47 PM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 01:14 PM
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap tim liverance Military Aviation 0 August 18th 03 01:18 AM
Change in TAS with constant Power and increasing altitude. Big John Home Built 6 July 13th 03 04:29 PM
Playing Card Deck Shows Way to U.S. Regime Change John Mullen Military Aviation 4 July 8th 03 01:03 PM
