Can tanker aircraft draw off all their onboard fuel?
Old December 4th 03, 04:39 AM
David Lesher
Hobo writes:
Can a tanker aircraft draw on the fuel they carry to refuel other
planes, or are they limited to the fuel that model of plane would
normally carry?
I got a private tour of a RAF ?Victor? tanker a few decades ago.
It came across for an air show (with good beer aboard..).
"Say, don't pull anything yellow & black" we were warned.
The crew member in charge of such things showed me the fuel manifold
panel and pointed out it had no separate "our" tankage...if he
screwed up, they all swam.
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old December 4th 03, 03:50 PM
Ron Parsons
362436 (Ron) wrote:
The KC-10 can burn all its fuel or offload all but a couple thousand pounds.
We can easily burn the JP-7 fuel that the SR-71 used, it just doesn't
lubricate the fuel pumps as well. I assume the KC-135 is the same. Not sure
about the KC-130 with Benson tanks in the fuselage.
Curt
U. S. Air Force, almost retired
There was a mid air explosion of a KC-135 about 15 years ago. They had
offloaded all the fuel they could, and the pumps no longer had that fuel for
cooling. Something got really hot, and the remaining vapors ignited...
That doesn't compute here. The only electric fuel pumps are in the mains
and the aircraft would be down to zero fuel before one was dry. The a/r
pumps are hydraulic are routinely run until the low pressure light comes
on.
Found this online so far in my search...
"On Oct. 4, 1990, an Air Force KC-135A tanker exploded during approach to
Loring Air Force Base in Maine, in an incident that involved a rear refueling
tank rather than the central fuel tank. Witnesses said they saw two explosions
on the plane and then saw the tail section separate. Investigators blamed the
accident, which killed all four crew, on an overheated fuel pump. "
The terms used don't match the names of any of the tanks. The only thing
close to being a rear refueling tank would be the Aft Body tank. While
the Upper Deck tank is the aftmost, it has no pumps.
Your cite has the tone of ground witnesses filtered through the press.
Ron
Old December 5th 03, 04:36 AM
mg
"Ron Parsons" wrote in message
pounds.
sure
Curt
fuel for
on.
refueling
explosions
Ron
KC135--In the body, there is a foward body, a center wing, and an aft
body, plus upper deck (no pumps) In the wings, 4 mains and 2 reserve tanks.
The forward and aft body tanks have two "Air Refueling" pumps each
(hydraulic driven). The center tank has two "override pumps" (electric).
The mains have two "boost pumps" each (electric). You can only offload from
the forward and aft tanks, but all the other fuel can drain either forward
or aft depending on the tank, except for a little standpipe fuel in each
main. The accident in question was likely an aft body tank explosion due to
overheated AR pump, but hard one to prove. Result: tank level restrictions
for years until they came up with an auto shutoff system that sensed a low
pressure and automatically turned off pumps when it was low. Almost all
pumps have now been replaced with modern pumps that do not overheat due
improved cooling.
MG
Old December 10th 03, 09:22 PM
Tarver Engineering
"B2431" wrote in message
I stand corrected.
The little chimp must be back on his meds.
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 04:13 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 03:31 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 06:15 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 08:17 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
