Inspiration for Homebuilders
Old May 28th 09, 07:05 AM posted to rec.aviation.homebuilt
John Kimmel[_2_]
Default Inspiration for Homebuilders
This is a pointer to a home build 20 ft diam windmill on a 70 ft pole.
It features three 10 ft long laminated red cedar blades and nice
looking
generator, tower couplings and gin....
http://www.otherpower.com/20page1.html
Brian W
(Thanks to Larry for the pointer on rec.boats)
I hope that you have good lightning suppression!
Ha! I noticed the maker specified a blade angle of 3 degrees at the
tips, increasing to (approaching) 9 degrees at the roots.
It took me a little while to get my head round this. The maker mentioned
the blades are set flat (undersurface) forward into the wind, and I
think he mentioned a target rotation rate of 65 rpm.
I imagine he was thinking of an AoA of 15 degrees at the rated wind. The
tips do a revolution in pi x 20 ft = 63 ft per rev - so the rotation
rate at 65 rpm would give a tip speed of 65rpm X 63ft/rev X 60 min/hr /
5280 ft/mile or 47 mph.
I guess the pitch angle for zero AoA at the starting windspeed 16 mph
would be atan 16/47 = 19 degrees from the plane of revolution, so for 15
deg AoA the pitch angle might be 4 degrees from the plane of revolution
at the tips.
And he mentions 3 degrees. But getting up to speed with stalled blades
would be an issue...
What's your take, Orville?
Regards
Brian W
My first take is that you misspelled my name.
We had a big windmill on our farm when I was growing up. The plane of
rotation was parallel to the wind, rather than at a right angle. The fan
acted more as a wind turbine than a propeller. IIRC, the fan had about a
dozen curved steel blades. It also had a brake on it for when the winds
got too high.
The blades were turned sideways (parallel to the tail) if they didn't
want it to pump any water---If you needed water you operated the lever
that placed the blades perpendicular to the rudder, tail,
whatever,-pointing into the wind, then you got some POWER..---OR--
did you have one of those weird looking things where the blades were
raked back severely at an angle about like the back 2/3 of a snowcone
cup? Jerry
Neither. The fan was 10-12 ft diameter, fixed so the wind would always
turn the fan. Since the blades were curved (cambered), the advancing
blade had less drag than the receding blade. I think it was a
Fairbanks-Morse product, but don't hold me to that, and it was built
about 1910.
A lot of windmills in our area (Northern Illinois) were of similar
design.
Sounds like a pelton wheel.
http://www.google.com/search?hl=en&q...on+w&aqi=g 10
Nope -- it wasn't a Pelton Wheel!
As I posted earlier, I thought it was a Fairbanks-Morse model.
See the picture at: http://www.agwt.org/store/FairbanksWindmill.htm
The fan disc was parallel to the wind direction. This raises the
question: Could we dispense with the directional pivot and mount the fan
horizontal to the ground? It should be able to rotate with any direction
of wind.
Of course, good lightning protection is a MUST!
A windmill with the fan mounted horizontal to the ground is called a "vertical axis wind turbine". The Savonius and Darrieus are
examples of this.
On a Fairbanks-Morse type windmill, when the vane is parallel to the disk, it is "out of gear" (according to the windmill brochure I
found). As wind speed increases above 15 MPH, the disk of the windmill turns more and more away from the wind to maintain constant
RPM. At very high wind speeds, the disk is parallel to the wind and a brake is engaged to stop it rotating altogether. To take the
windmill off line, (as you would if you've upgraded to an electric pump), you lock the vane and the brake in the furled position.
http://vintagewindmillpartslist.com/FMWGtrade.pdf
Old May 28th 09, 06:04 PM posted to rec.aviation.homebuilt
Brian Whatcott
ft pole.
nice looking generator, tower couplings and gin....
Brian W
the tips, increasing to (approaching) 9 degrees at the roots.
mentioned the blades are set flat (undersurface) forward into the
wind, and I think he mentioned a target rotation rate of 65 rpm.
wind. The tips do a revolution in pi x 20 ft = 63 ft per rev - so
the rotation rate at 65 rpm would give a tip speed of 65rpm X
63ft/rev X 60 min/hr / 5280 ft/mile or 47 mph.
16 mph would be atan 16/47 = 19 degrees from the plane of
revolution, so for 15 deg AoA the pitch angle might be 4 degrees
from the plane of revolution at the tips.
blades would be an issue...
Regards
Brian W
of rotation was parallel to the wind, rather than at a right
angle. The fan acted more as a wind turbine than a propeller.
IIRC, the fan had about a dozen curved steel blades. It also had a
brake on it for when the winds got too high.
didn't want it to pump any water---If you needed water you operated
the lever that placed the blades perpendicular to the rudder, tail,
were raked back severely at an angle about like the back 2/3 of a
snowcone cup? Jerry
always turn the fan. Since the blades were curved (cambered), the
advancing blade had less drag than the receding blade. I think it
was a Fairbanks-Morse product, but don't hold me to that, and it was
built about 1910.
design.
fan horizontal to the ground? It should be able to rotate with any
direction of wind.
"vertical axis wind turbine". The Savonius and Darrieus are examples of
this.
disk, it is "out of gear" (according to the windmill brochure I found).
more and more away from the wind to maintain constant RPM. At very high
stop it rotating altogether. To take the windmill off line, (as you
I notice that the design which started this thread seems to have a
particularly simple wind overspeed unloader.
The mill rotation axis is offset to one side of the mast rotary
bearing, and the tail vane is offset to the other side of the mast
bearing, but it is also set on a pivot tube oriented 45 degrees or so to
the vertical. The M.O seems to be that excess wind tries to "fold the
fan and the tail in two, resisted by the tail's lifting away from the
horizontal as the wind blows harder.
Brian W
AN ENGINE FOR HOMEBUILDERS Bob Home Built 65 June 5th 09 07:45 PM
A Camcorder for Homebuilders [email protected] Home Built 3 June 1st 08 03:27 PM
Inspiration by friends - mutal interest and motivation to get the PPL Gary G Piloting 1 October 29th 04 09:19 PM
Best Homebuilders Books? [email protected] Home Built 5 January 21st 04 01:06 AM
"Big" Jon Johanson --- an Inspiration Larry Smith Home Built 0 December 17th 03 05:01 PM
