Benchtops & Shelving
Old March 6th 04, 02:32 PM
Blueskies
http://www.roscoemoss.com/specs.html
Dan D.
"Blueskies" wrote in message .com...
Cast some concrete in a 2" form?
How about some of those new plastic deck 'boards'.
Dan D.
"Jim Weir" wrote in message ...
Oooookay, let me try again.
What NONLUMBER bench tops have you ever seen or considered that might work?
I'm not making 747s, fellers, nor am I building spars. The worst I might want
to do is bend up a 4" x 6" bracket out of 5052H32 and drill it with a Harbor
Freight benchtop drill press.
Jim Weir
-However, since I'm going to a new method of framing, I'd like thoughts on what
-you have used as workbench/shelving materials. The benches will be about 2'
-wide and 6' long. Yes, I know, solid moulded Teflon would be best, but quick
-and cheap is high on the list of attributes I'm looking for.
-Thoughts appreciated.
http://www.rst-engr.com
Old March 5th 04, 06:02 AM
Leon McAtee
Jim Weir wrote in message . ..
What are your operating parameters? How sturdy? Chemical resistance?
Impact resistance? Easy to clean? Non static? Humidity resistant
(no rot or rust)?
My favorite work bench is part of an old restaurant. 1" galvanized
steel structure, 14 ga stainless top with a nice rounded lip on the
back to keep things from rolling off. The only thing that I could
never clean off was some oil from a MB diesel. Nasty stuff. The oil
not the Merc.
Old March 4th 04, 12:19 AM
PaulaJay1
In article , Jim Weir
writes:
what
I built my work bench out of construction pine and then used oak flooring to
cover the top. "Flooring" at a 45 deg angle to prevent any pine warping
getting to the top. The surface has held up for 20 years and every 5 years I
sand and put on a coat of plastic varnish.
Chuck
Old March 4th 04, 01:59 AM
G.R. Patterson III
Jim Weir wrote:
I'm about to start building the "furniture" for the hangar.
Well, if the stuff is rotting on you, I would go to pressure-treated pine and
stick with the construction you usually use.
I've also found it impossible to get decent hollow-core doors these days. They
used to make the inexpensive ones out of luan plywood, but the stuff we get on
the dirty side is all masonite with a woodgrain finish these days. I've got
nothing against masonite, but the glue doesn't hold and they're way too flimsy
to use for tables.
That said, the last bench I built was put together from a set of plastic legs
that HD was discontinuing (on sale at $25) and a sheet of 3/4" particle board.
My lathe is on it now.
George Patterson
A diplomat is a person who can tell you to go to hell in such a way that
you look forward to the trip.
Old March 4th 04, 03:53 AM
Don Tuite
Has anybody mentioned prefabbed kitchen countertops?
I know, particleboard underneath. But if they don't rot out around
your sink, they must be pretty rot-proof.
Don
Old March 4th 04, 04:00 AM
G.R. Patterson III
They don't rot, but they will swell and disintegrate if they stay wet. They
stay together because the installer uses various tricks to make sure the water
stays where it's supposed to be.
George Patterson
Old March 4th 04, 04:26 AM
Jerry Wass
1/4" steel plate works pretty good, you can glue down a thin short-nap outdoor
carpet,(or indoor for that matter)---that keeps screws etc from bouncing off onto
the floor--Kinda makes it hard to drive nails in, but It ain't wood!!
Jim Weir wrote:
I'm about to start building the "furniture" for the hangar. After a lifetime of
building "manly" workbenches out of DF 4x4s milled to take 2x4 crossmembers, and
having the concomitant rot and deterioration of wood, I'm considering making the
framing out of 1¼ PVC Schedule 40 pipe and fittings. The problem is what to use
for the bench tops and shelving underneath.
So far, all my "heavy duty" workbenches have been made out of 3/4" plywood with
a 2" doubler plate along the front and back, and my electronic workbenches have
been either solid core or hollow core doors with an appropriate varnish or Deft
coating on them.
Old March 5th 04, 11:29 AM
Corrie
Restaurant supply houses that specialize in used equipment will have
stainless steel tables. Size / price / condition will vary. Might be
able to find a butcher's table. I suspect that it's a sheet of
teflon-like stuff (those white plastic cutting boards) laid over SS.
Plexiglas / Lexan? You could stiffen it up with bracing on the
underside.
Foam board used for insulating houses and some a/c designs? You can
get it thick for stiffness, though it won't handle beating on. It'll
take pins well if you're building balsa models or laying out wiring
harnesses. Just don't try to solder on it. ;-^
Corian / synthetic stone counters. Not cheap, unless you can find one
salvaged or scrap. Some towns have architectural recycling centers
where you can get pre-owned building materials cheap. (Might even
find some old luan doors.) They might have a counter top or two;
likewise the manufacuter or an installer might have a damaged or
customer-rejected one they'd unload at cost.
Why do you want a non-wood top, anyway?
Benchtops & Shelving Jim Weir Home Built 30 March 6th 04 02:32 PM
