What is the L/D penalty of outside mounted GoPros?
Old January 6th 15, 03:48 PM posted to rec.aviation.soaring
son_of_flubber
Default What is the L/D penalty of outside mounted GoPros?
On Tuesday, January 6, 2015 9:34:02 AM UTC-5, PBA wrote:
I'm doing this currently and have landed with 5 hrs of extremely boring, continuous flight video of flatland soaring....I need to move to the mountains!
Serious question. Did watching the video change your enjoyment of flatland soaring? Or were you starting to get bored with it before you took the video?
Old January 6th 15, 04:43 PM posted to rec.aviation.soaring
PBA
Flubber,
Serious answer: I love flatland soaring and I'm not bored with it by any means. Video taping my own flatland flights has increased my passion and satisfaction with soaring immensely. I was just comparing my 5-hr local flatland soaring video to B4's edited, 1-hr, monster XC, mountain flight. Boring in comparison
Old January 11th 15, 04:54 PM posted to rec.aviation.soaring
On Saturday, January 3, 2015 at 12:55:47 PM UTC-8, wrote:
I am thinking about trying to do some soaring videos. Inside the cockpit footage only is boring and I want to be more like Balleka with amazing outside camera shots. The reason why I haven't done much is concern over the performance penalty of outside cams while trying to do longer XC flights.
Anyone smarter than me (I know most of you are, other than TT) able to figure out the drag penalty of a GoPro either mounted on the wing or on the tail of a 27? It would be attached with the adhesive mount and not the larger suction cup mount in hope of reducing the drag. The GoPro in its larger case to accommodate an extra battery is 41mm H x 59mm W x 40mm D.
What I am hoping to figure out is if it is a 1-2 point L/D penalty or something more like a 4-5 point drop. Those of you who have flown with me know I need every L/D point I can get.
Here's to hopefully a lot of fun 2015 soaring videos shared from a bunch of us!
Bruno - B4
Oh yeah - and Nephi is amazing!
Bruno, Don't change a thing, your YouTube videos are amazing. Keep up the good work. You have quite a fan base.
Old January 12th 15, 08:07 PM posted to rec.aviation.soaring
ND
I am thinking about trying to do some soaring videos. Inside the cockpit footage only is boring and I want to be more like Balleka with amazing outside camera shots. The reason why I haven't done much is concern over the performance penalty of outside cams while trying to do longer XC flights..
Bruno - B4
CAN'T be any worse than "downgrading" to an ASW-20 from your 27.
Old January 13th 15, 11:39 PM posted to rec.aviation.soaring
Ivan Volny
Maybe camera used by Sebastian Kawa in Nad Annapurna video would be better than multiple cameras. See 9:20 in http://youtu.be/4UdfTZ3bf9E.
Old February 23rd 15, 07:48 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Bruno,
Here are a couple of links to external camera rigs I've tried in the past. Both were shot at Parowan FWIW. The first dates from 2005 when the best available solution required a remote bullet camera hard-wired to a digital video tape-based camcorder.
https://www.youtube.com/watch?v=BXbfs0tzqbQ
The second one is from 2012. A GoPro mounted to a piece of aluminum channel stock mounted to the wingtip. Issues with framing and vibration, but promising.
https://www.youtube.com/watch?v=Vv-GTknLkQE
Hope that helps as you think about possible camera locations. I have a few more ideas to pursue - including a cheap version of a panning camera you can mount externally.
Looking forward to Nephi this summer.
Andy - 9B
Externally mounted GoPros okay? Jim Lewis[_2_] Soaring 4 December 30th 14 11:52 PM
UO penalty @ Hobbs For Example John Smith Soaring 4 June 12th 05 09:34 PM
There is no penalty for failing to make the required FAA reports or investigation! Larry Dighera Piloting 9 October 12th 04 05:06 AM
TFR Penalty Magellan Piloting 9 September 5th 04 02:24 AM
~ US JOINS CHINA & IRAN AS TOP DEATH PENALTY USERS ~ Matt Wiser Military Aviation 0 April 8th 04 03:55 PM
