Feet Per Minute Conversion Question
Old August 24th 03, 03:38 PM
W.J. \(Bill\) Dean \(U.K.\).
On the Equator.
W.J. (Bill) Dean (U.K.).
Remove "ic" to reply.
"JJ Sinclair" wrote in message
Navigational question for the day;
One minute of latitude = 1 nautical mile.
At what point on the earth does 1 minute of longitude = 1 nautical mile?
JJ Sinclair.
Old August 24th 03, 06:17 PM
Gene Nygaard
On Sun, 24 Aug 2003 14:38:07 +0100, "W.J. \(Bill\) Dean \(U.K.\)."
On the Equator.
Wrong.
There have been some geographical miles based on the equatorial
circumference, but I've never seen them called nautical miles. There
was one geographical mile equal to 4 minutes of arc on the equator, or
about 7.421 km; I have a copy of a map using these units.
Nautical miles have normally been defined to be some midrange,
midlatitude value for a minute of arc as you travel north-south along
a meridian.
At the equator, 1 minute of longitude is 1.001795 nmi.
But 1 minute of latitude (geodetic latitude, the kind normally used)
at the Equator is only about 0.9950 nmi.
JJ Sinclair.
It is at some place close to the equator, where the circumference of
the earth at that latitude is 40.0032 Mm, rather than the 40.007495 Mm
at the Equator (WGS-84 ellipsoid). A latitude close to the arccosine
of 40.0032/40.007495, or about 3½ degrees from the Equator either
north or south (a more exact value depends on which type of latitude
you use, as well as which ellipsoid you use to approximate this).
To help see this better, your "minute of longitude" at a latitude of
60 degrees would be about 0.50 nmi, and at the poles a
"minute of longitude" is 0 nmi. It is actually the minute of latitude
as you travel along a meridian (constant longitude) that most people
consider in evaluating the fit of a nautical mile to the Earth.
Now, at what point is one centigrade of latitude equal to one
kilometer?
Gene Nygaard
http://ourworld.compuserve.com/homepages/Gene_Nygaard/
Old August 26th 03, 11:33 AM
Doug Hoffman
Hey Gene, What kind of glider do you fly? Methinks you are a troll
and should leave this newsgroup alone with your misguided "superior"
knowledge of weights and measure. This is a newsgroup for soaring.
Gene Nygaard wrote in message . ..
On the Equator.
Wrong.
a meridian.
JJ Sinclair.
kilometer?
Gene Nygaard
Old August 25th 03, 02:13 AM
Doug Hoffman
Iwrote:
I have two "older" gliders, each with 2 varios (4 varios total). 1
vario reads in feet per second, another in meters per second, another
in knots, and the last one in 100's of feet per second...
Pardon me, that should read "100's of feet per *minute*..."
-Doug
Old August 26th 03, 01:12 AM
Liam Finley
How do I convert Meters/second to Leagues per Hour? I need the answer
to five significant digits.
I also need to convert wing loadings from Kg/square meter to
tons/acre.
Can I do the conversion in Winpilot?
Old August 26th 03, 10:36 AM
Jonathan Gogan
tons/acre = Cos( furlongs/ weekend)
Jon.
"Liam Finley" wrote in message
om...
tons/acre.
Old August 27th 03, 05:52 PM
John Lee
On 27 Aug 2003 10:54:05 GMT, John Lee
One minute of latitude = 1 nautical mile. At what point
on the earth does 1
minute of longatude = 1 nautical mile?
JJ Sinclair
Nowhere! However on the equator 1 second of longitude
equals 1 nautical mile
That isn't any more correct now than when Bill Dean
claimed that
earlier in this thread. See my reply to his message.
Gene Nygaard
Still looking Gene...... the other stuff is interesting
though
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 01:18 PM
Hiroshima/Nagasaki vs conventional B-17 bombing zxcv Military Aviation 55 April 4th 04 08:05 AM
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 03:54 AM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 02:26 AM
got this from a friend JD Naval Aviation 7 August 31st 03 04:21 AM
