Crosswind Landings... But airspeed?
Old September 29th 05, 08:21 AM
Jmarc99
Default Crosswind Landings... But airspeed?
After having read all the posts in the previous thread, no one said a word
about de right airspeed to keep along the final approach... whatever this is done
with a sideslip or crabbing.
I am wondering what should be the right airspeed (calculated or not, 1.3 Vs + wind speed)
to get in a crosswind landing.
What about a straight 90 degrees crosswind, or more?
I wouldn't turn back ON the old "Crosswind Landings" thread!
Just wish to talk about the airspeed to get according different wind speeds and gusts!
jmarc
Old September 29th 05, 09:16 AM
Duncan McC
In article , jmarc99
@sympatico.ca says...
There, yer just said it - wind speeds and gusts (namely gusts).
Nothin' to do with crosswinds (same speed applies).
Admittedly, if you're going to take a slightly longer flare (to get
'crossed up' and lined up), one might consider adding an extra knot or
two to allow for that - as well as the extra drag while yer crossed up.
Duncan
Old September 29th 05, 02:25 PM
GSA
I was learnt to adjust the airspeed in the following way:
(normal landing speed 90 kmh)
- when you need to move your stick more than halfway to the left or
right to keep the plane horizontal, you are flying too slow...
- when you try to fly 90 and airspeed is varying between 70 and 110, fly
110, so airspeed will always be more than 90.
Old September 29th 05, 03:10 PM
Bert Willing
Well, I learned that when I need to move the stick out of center to keep the
glider horizontal, something is wrong...
Bert Willing
ASW20 "TW"
"GSA" a écrit dans le message de news:
- when you need to move your stick more than halfway to the left or right
Old September 29th 05, 09:27 PM
GSA
With crosswind I land with 'crossed' controls, so the stick is out of
the center... but the plane isn't horizontal then, my fault
Old September 30th 05, 09:12 AM
Bert Willing
With crosswind, I crab and I touch down with crossed controls. Crossed
controls on final means higher stall speed, unreliable ASI readings and is a
nono.
Bert Willing
ASW20 "TW"
the glider horizontal, something is wrong...
With crosswind I land with 'crossed' controls, so the stick is out of the
Old September 29th 05, 03:48 PM
Jmarc99
"GSA" wrote in message
l...
I agree with all that, when the wind is straight on the runway!
But, I wander if this is true whatever the wind direction is 90 degrees,
or worst, let say 180 degrees. Is the rule 1,3 Vs + wind speed still right
to use,
when your final is downwind?
jmarc...
Old September 29th 05, 04:38 PM
Nyal Williams
Your aircraft flies through the air; that's aerodynamics.
Neither your wings nor your ASI can identify crosswind
or downwind; tha'ts geography. They connect only at
touchdown
At 14:06 29 September 2005, Jmarc99 wrote:
'GSA' wrote in message
. nl...
way:
70 and 110, fly
the runway!
is 90 degrees,
to use,
jmarc...
Old September 29th 05, 04:39 PM
Nyal Williams
touchdown
. nl...
way:
70 and 110, fly
the runway!
is 90 degrees,
to use,
jmarc...
Old September 29th 05, 09:46 PM
Andy
Beware of flying indicated airspeed during a slipping approach. The
pitot/static system on some giders will give large indicated airspeed
errors when slipping. As an extreme example my ASW-19 read zero
airspeed in a full rudder slip, probably due to the nose pot pitot.
You need to know your glider and fly the appropriate attitude rather
than the ASI.
Andy
terminology questions: turtledeck? cantilever wing? Ric Home Built 2 September 13th 05 10:39 PM
A new direction for an old thread: Crosswind landings [email protected] Soaring 96 March 4th 05 02:22 AM
Inaccurate airspeed indicator Wyatt Emmerich Instrument Flight Rules 20 April 20th 04 01:08 AM
Strong crosswind landings! Toks Desalu Piloting 12 April 19th 04 08:43 PM
