It is clearly explained in "Aerodynamics for Naval Aviators", NAVWEPS
00-80T-00, page 295.... "Dallas" wrote in message nk.net... Would anyone care to comment on the accuracy of this illustration of how wing dihedral works from a 1981 Jeppesen Sanderson book. http://makeashorterlink.com/?B25A35DCC The accompanying statement reads: "When an aircraft with dihedral rolls so that one wind is lower than the other, the lower wing will have more effective lift than the raised wing because it is not tilted from the horizontal as much. The imbalance in lift tends to raise the lower wing and restore level flight." Dallas |
Dallas wrote:
Would anyone care to comment on the accuracy of this illustration of how wing dihedral works from a 1981 Jeppesen Sanderson book. http://makeashorterlink.com/?B25A35DCC The accompanying statement reads: "When an aircraft with dihedral rolls so that one wind is lower than the other, the lower wing will have more effective lift than the raised wing because it is not tilted from the horizontal as much. The imbalance in lift tends to raise the lower wing and restore level flight." Dallas This is not quite correct, and most of the "pilot books" have it wrong too. Here is a very nice explanation taken from the book titled "Mechanics of Flight" by A.C. Kermode of the RAF. "The most common method of obtaining lateral stability is by the use of a dihedral angle on the main planes. Dihendral angle is taken as being the angle betwen each plane and the horizontal, not the total angle between the two planes, which is really the geometrical meaning of dihedral angle. If the planes are inclined upwards towards the wing tips, the dihedral is positive; if downwards, it is negative and called anhedral; the latter arrangement is used in practice for reasons of dynamic stability. The effect of the dihedral angle in securing lateral stability is sometimes dismissed by saying that if one wing tip drops the horizontal equivalent on that wing is increased and therefore the lift is increased, whereas the horizontal equivalent and the lift of the wing which rises is decreased, therefore obviously the forces will tend to right the airplane. Unfortunately, it is not all quite so obvious as that. Once the aircraft has stopped rolling, provided it is still travelling straight ahead, the aerodynamic forces will be influenced only by the airstream passing over the aircraft. This will be identical for both wings and so no restoring moment will result. What, then, is the real explanation as to why a dihedral angle is an aid to lateral stability? When the wings are both equally inclined the resultant lift on the wings is vertically upwards and will exactly balance the weight. If, however, one wing becomes lower than the other, then the resultant lift on the wings will be slightly inclined in the direction of the lower wing, while the weight will remain vertical. Therefore the two forces will not balance each other and there will be a small resultant force acting in a sideways and downwards direction. This force is temporarily unbalanced and therefore the aeroplane will move in the direction of this force - i.e. it will sideslip - and this will cause a fow of air in the opposite direction to the slip. This ahs the effect of increasing the angle of attach of the lower plane and increasing that of the upper plane. The lower plane will therefore produce more lift and a restoring moment will result. Also the wing tip of the lower plane will become, as it were, the leading edge so far as the slip is concerned; and just as the center of pressure across the chord is nearer the leading edge, so the center of the pressure distribution along the span will now be on the lower plane; for both these reasons the lower plane will receive more lift, and after a slight slip sideways the aeroplane will roll back into its proper position. As a matter of fact, owing to the protetcion of the fuselage, it is probably that the flow of air created by the sideslip will not reach a large portion fo the raised wing at all; this depends very much on the position of the wing relative to the fuselage. Both the leading edge effect on the lower wing, and the shielding of the upper wing by the fuselage, occur on nearly all type of aircraft, and may well mean that an aeroplane has a sufficient degree of lateral stability without any dihedral angle, or too much if some of the follwing effects also apply. Even if there is no actual dihedral angle on the wings, these other methods of achieveing lateral stability may be described as having a dihedral effect." |
"Andrew Sarangan" posted the exciting message
oups.com: That is an excellent writeup! |
Quote:
Let's consider the "90 degree" dihedral wing mentioned earlier. Let's assume that when the wings are "level" they produce enough lift to fly level at the current airspeed. Let's assume that one wing is horizontal, and one vertical. The relative wind is coming from ahead, and from slightly below. The vertical component of lift on the upper wing is now directed inwards, and is therefore no longer supporting the plane's weight, so the plane starts to descend, increasing the AOA on the lower wing even further. The AOA on the upper wing remains lower than normal, because the relative wind is hitting it diagonally. Note that due to the relative wind, the dihedral would right the plane even if it weren't descending. |
Excellent excerpt - it was what I was trying to say. Thanks.
Andrew Sarangan wrote: Dallas wrote: Would anyone care to comment on the accuracy of this illustration of how wing dihedral works from a 1981 Jeppesen Sanderson book. http://makeashorterlink.com/?B25A35DCC The accompanying statement reads: "When an aircraft with dihedral rolls so that one wind is lower than the other, the lower wing will have more effective lift than the raised wing because it is not tilted from the horizontal as much. The imbalance in lift tends to raise the lower wing and restore level flight." Dallas This is not quite correct, and most of the "pilot books" have it wrong too. Here is a very nice explanation taken from the book titled "Mechanics of Flight" by A.C. Kermode of the RAF. (snip) (snipped) |
"Andrew Sarangan" wrote in message oups.com... This is not quite correct, and most of the "pilot books" have it wrong too. Here is a very nice explanation taken from the book titled "Mechanics of Flight" by A.C. Kermode of the RAF. I really enjoyed reading this book and would recommend it highly. I did notice that some British terminology differed from common American usage. The book lived on my bedside table for several months and I would often read several pages to give me something to ponder as I fell asleep. Happy landings, |
| Thread Tools | |
| Display Modes | |
| Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 05:40 AM |
| terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 10:39 PM |
| Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 03:37 AM |
| Grob G102 Setup | BDS | Soaring | 11 | August 30th 05 04:42 PM |
| Biplane wing dihedral | vincent p. norris | General Aviation | 20 | June 18th 05 03:58 AM |
