John C.,
My reverse (perverse) logic: When each of you can see what the other is (or is not) doing as thoroughly as one could in the A-6 cockpit, there is less call for command ejection, IMHO. I also believe that good crew coordination had much to do with this attitude. You either learned to work well as a crew, or your squadronmates began sniveling to the Ops Officer. -- Mike Kanze "It's scary when you start making the same noises as your coffeemaker." - Anonymous "John Carrier" wrote in message ... One of the peculiarities of the A-6 was its lack of a command ejection system. There was some kind of reverse (perverse) logic in the community that had sufficient following to keep it that way (IIRC) for the life of the aircraft. R / John |
In article , "John Carrier" wrote: Probably engine failure on the stroke. Possibly wrong weight setting on the cat. The older catapults would use a given steam pressure to achieve a A fully-loaded A-6 didn't have very good single-engine fly away capability. The "something" was probably all the underwing stores. Pilot pushed the emergency jettison and the pylons were cleaned off. Yeah, I figured it was the stores, although I only saw one big thing falling from one side of the plane. The plane wasn't fully loaded, at least that much was evident. In fact, it looked clean, which is why the big thing falling off was so odd. D |
Yep, Owl, it was the Buckeyes. Correctly identified.
On 5/29/06 4:56 PM, in article , "Mike Kanze" wrote: Woody, If this occurred late in the A-6's service (i.e., after 1990) and both souls survived, it was likely the following, per Morgan & Morgan: BuNo 154148/A-6E, VA-85, 09/18/91, Mediterranean, CV-66, Lost engine on cat shot. ****** The engines had de-tuned over time making the single-engine performance charts incorrect. Pax re-vamped them in about 1994-5. ...just in time for that last flight to the boneyard, or to "NAS Barrier Reef." g Any number of gremlins begin popping up in elderly aircraft after many years of otherwise uneventful service. Witness B/N Keith Gallagher's partial ejection, caused by aging components. In his case, the ejection seat components were ~28 years old: http://www.gallagher.com/ejection_se...al_aspects.htm |
They had some footage of some cat launches gone wrong. In one an A-6 took
off the waist catapult of a carrier and started losing altitude almost immediately. Then something really big fell off the plane, it started to roll, and the pilots ejected at very low altitude. The pilot was Rick "Twig" LaBranche, who is now a CDR and has the distinction of being the CO of the last operational Tomcat squadron (VF-31 flying F-14Ds at least until September). _____________ José Herculano |
On 5/27/06 5:27 PM, in article ,
"José Herculano" wrote: They had some footage of some cat launches gone wrong. In one an A-6 took off the waist catapult of a carrier and started losing altitude almost immediately. Then something really big fell off the plane, it started to roll, and the pilots ejected at very low altitude. The pilot was Rick "Twig" LaBranche, who is now a CDR and has the distinction of being the CO of the last operational Tomcat squadron (VF-31 flying F-14Ds at least until September). _____________ José Herculano Twig's STILL CO? I would have thought that he was done by now. --Woody |
Essex class carriers had bow cats only.
Dick... "DDAY" wrote in message . net... I was watching a documentary called "Top Gun" on the Military Channel. They had some footage of some cat launches gone wrong. In one an A-6 took off the waist catapult of a carrier and started losing altitude almost immediately. Then something really big fell off the plane, it started to roll, and the pilots ejected at very low altitude. Any idea what happened there? I remember hearing about some aircraft launch where the fuel in an external tank acted like a ram and caused some heavy damage, but I'm not sure if these are the same events. In another shot, a large prop plane, possibly an S-2F, took off the waist catapult of a smaller Essex class carrier and immediately slammed into a wave. Again, does anybody have any details? D |
On Sat, 27 May 2006 04:30:42 GMT, "DDAY"
wrote: I was watching a documentary called "Top Gun" on the Military Channel. They had some footage of some cat launches gone wrong. In one an A-6 took off the waist catapult of a carrier and started losing altitude almost immediately. Then something really big fell off the plane, it started to roll, and the pilots ejected at very low altitude. Any idea what happened there? I remember hearing about some aircraft launch where the fuel in an external tank acted like a ram and caused some heavy damage, but I'm not sure if these are the same events. In another shot, a large prop plane, possibly an S-2F, took off the waist catapult of a smaller Essex class carrier and immediately slammed into a wave. Again, does anybody have any details? The video you are referring to ( I believe) was the USS Ticonderoga. In the video, you should be able to clearly see the "14" on the pointy end. The squadron was VS-38 out of North Island. And it was not a cat shot. As others have mentioned, no angle deck cats on Essex class. The S-2 in question was not shot off the cat - it was a deck run from the aft part of flight deck. The aircraft was partially filled with salt water but the R1820's just kept on chuggin'. Aircraft was put in the hanger bay for maintainers to dry out, which was only partially successful. Corrosion set in (duh!!!) and the A/C never flew again. Oh yea - no back seaters in the A/C at the time - just 2 O's in the front. Hope this helps. Regards, D |
Charlie Wolf wrote:
The aircraft was partially filled with salt water but the R1820's just kept on chuggin'. Aircraft was put in the hanger bay for maintainers to dry out, which was only partially successful. Corrosion set in (duh!!!) and the A/C never flew again. Now I'm wondering why the cleaning work was not done properly. Shurely rinsing out the a/c would have been cheaper than replacing it. Joachim |
| Thread Tools | |
| Display Modes | |
| VQ-1's P4M-1Q crash off China - 1956 | Mike | Naval Aviation | 0 | May 7th 06 12:13 AM |
| UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 07:58 PM |
| Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 05:40 AM |
| Yet another A36 crash | H.P. | Piloting | 10 | April 23rd 05 06:58 PM |
| spaceship one | Pianome | Home Built | 169 | June 30th 04 06:47 AM |
