Testing the Testing of Mogas
Old July 21st 06, 12:06 AM posted to rec.aviation.piloting
Al[_1_]
Default Testing the Testing of Mogas
"Jay Honeck" wrote in message
ps.com...
others have already commented on the alka seltzer chemisty, but a simpler
and quantitative way of measuring how much alcohol is in the fuel is to
simply mix it with water. Try 9 parts of fuel to 1 part of water in a
graduated cylinder. the alcohol will migrate to the water phase so you
will
see an increase in the height of the water layer at the bottom and a
decrease in the height of the fuel layer if there is significant amount
of
alcohol..
Does this mean that you can use water to REMOVE alcohol from mogas?
Fill the mighty grape. Pour in a gallon of water. Drive around to mix. Drain
the water. Ta-Da.
Al G
Old July 21st 06, 02:09 AM posted to rec.aviation.piloting
Peter Duniho
Invent one, Edison!
I would, but I'm too busy posting to Usenet.
Old July 24th 06, 10:38 PM posted to rec.aviation.piloting
d&tm
"Al" wrote in message
ps.com...
simpler
will
of
alcohol..
I guess it does but I wouldnt reccommend this to anyone. Interestingly we
had a major fuel contamination issue in australia in 2000 which grounded
half the GA fleet , a corrosion inhibitor , diethylamine which was supposed
to be washed out of the fuel before sale, wasnt removed properly . it
reacted with brass in the fuel systems to form a black gunk which caused
some engine failures. fortunately no one was hurt ( other than financially).
the solution was to just wash the stuff out with water.
terry
Testing MoGas Jay Honeck Piloting 14 July 20th 06 05:36 AM
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
MoGas Long Term Test: 5000 gallons and counting... Jay Honeck Home Built 82 May 19th 05 03:49 PM
MoGas Long Term Test: 5000 gallons and counting... Jay Honeck Owning 87 May 19th 05 03:49 PM
Testing Stick Ribs Bob Hoover Home Built 3 October 3rd 04 03:30 AM
