To Glass or Not To Glass...
Old August 16th 06, 07:41 PM posted to rec.aviation.piloting
Kingfish
Default To Glass or Not To Glass...
Martin Hotze wrote:
"Kingfish" wrote:
New 182s list at $326K, '05s are 275K+. '04 was the first year
for the G1000 182 IIRC
and for (starting at) $ 478.000 you can buy a Diamond DA42 Twin Star.
That's a multi engine with a G1000 and burning Jet fuel ....
478k is a heckuva lot more money than he was considering spending for a
1 or 2 year old 182 in his OP. Personally, I like the DA42 and can't
wait to check one out, even if it's just a look-see on a ramp somewhere.
Old August 16th 06, 07:54 PM posted to rec.aviation.piloting
Andrey Serbinenko
Yes, you can still rent if you like, in addition to owning an airplane.
If you can afford both. Your airplane sitting on the ramp is money wasted,
and this can be a significant factor when choosing your next destination.
Peter Duniho wrote:
"Andrey Serbinenko" wrote in message
But doesn't it tie you up to your home base? With a rental you have the
option to do some flying far from home without having to ferry your
aircraft all the way there and back. It would be more of a concern for
a smaller single, of course.
How does owning an airplane remove that option?
Old August 16th 06, 08:00 PM posted to rec.aviation.piloting
If you get the desired options and pay taxes to the peoples republic of CA then
it will be more than 500K more than what I can afford.
Other than not being able to afford it I'd love a DA42.
Old August 16th 06, 08:18 PM posted to rec.aviation.piloting
Peter Duniho
Why would it be a significant factor when choosing your next destination?
If you can fly your airplane there, you would. Owning is a benefit in that
case.
If you can't fly your airplane there, then you don't. But it's not as
though your owned airplane costs you MORE just because you had to travel
without it. If when you are at your destination, you choose to rent an
airplane locally, then you have the expense for that rental, but you'd have
that expense whether or not you owned an airplane. Again, owning the
airplane doesn't increase your cost in that situation.
I don't see any way that owning an airplane ties you to your home base, nor
do I see any way that owning an airplane restricts one's ability to fly
other airplanes elsewhere.
I've owned my airplane for 12 years now, and not once have I found that
owning an airplane has in any way restricted my ability to travel or other
fly other airplanes.
Your comment sounds a lot like something someone who has never owned an
airplane might say when trying to find some reason to not own an airplane.
There ARE reasons to not own an airplane (economics and the hassle of
managing the airplane being the two main ones), but the question of what
one's options are when traveling without the owned airplane is NOT among
them.
Pete
Old August 16th 06, 08:32 PM posted to rec.aviation.piloting
Gig 601XL Builder
Let's say I'm like the majority of the population and don't own a plane and
I take and airline across county and need to travel on the surface once I
get there. Should the fact that I own a car at home have any effect on my
decision whether to rent a car or walk?
Old August 16th 06, 08:46 PM posted to rec.aviation.piloting
Andrey Serbinenko
That seems like a good analogy, but for one thing: you get enough utility
out of your car to justify the cost of owning it as it is, and it is not
a huge cost or hassle. If recreational trips is all the flying you do,
then every trip made in a different airplane from the one you've paid and keep
paying for takes away from its utility and drives the cost/value number
ever higher.
  #29
Old August 16th 06, 08:54 PM posted to rec.aviation.piloting
Andrey Serbinenko
It is not the pure dollar cost that matters, but the effectiveness of
the money spent, i.e. cost vs. utility. It is especially true for
something requiring continuous money infusions like owning an airplane.
That's exactly that. I'm evaluating my options now.
Not that I'm trying to find a reason not to own, rather a sound justification
to own.
Andrey
  #30
Old August 16th 06, 10:01 PM posted to rec.aviation.piloting
Gig 601XL Builder
There's the problem in your logic. You are assuming that an airplane owner
that just uses the aircraft for recreational trips isn't getting enough
utility out of it.
keep
ever higher.
wasted,
destination.
and
FS: "Kennedy Space Center, Spaceport USA" Souvenir Glass J.R. Sinclair Aviation Marketplace 0 April 10th 06 12:14 PM
How much glass in a glider? Marian Aldenhövel Soaring 0 July 12th 05 02:33 PM
Glass panels: what OS? Bruce Horn Piloting 84 June 28th 04 09:31 AM
C182 Glass Panel Scott Schluer Piloting 15 February 27th 04 04:52 PM
Lesson in Glass JimC Owning 3 August 6th 03 02:09 AM
