#21
"Chuck Johnson" wrote in message 5.241... "Doug \"Woody\" and Erin Beal" wrote in : On 9/2/03 10:41 PM, in article , "Guy Alcala" wrote: Doug \"Woody\" and Erin Beal wrote: On 9/2/03 7:07 PM, in article , "John Halliwell" wrote: In article , Paul J. Adam writes The MiG-29 is a dangerously agile point-defence interceptor, and it's got afterburners to further reduce its endurance. The Harriers are short-cycle, but at least they get max thrust dry (and I'm led to believe that carrier fuel reserves are somewhat more stringent than land-based... willing to be corrected) I just don't see MiG-29s having time and fuel to get up to speed, arrange a supersonic intercept on agile opponents, and make it back to base on a routine basis. From Sharkey's book on SHAR fuel consumption: 'When at full power and at low level (the worst situation for high fuel consumption) it used very little gas; less than 200 pounds of fuel per minute (compared with the F-4's 1800 pounds). This latter attribute meant that it could outlast any other known fighter in fully developed combat - a truly excellent characteristic.' That's against an F-4 (who can't turn inside and shoot). Against a more agile fighter, I'd bet the Sea Harrier would get shot before it outlasted. By the way, I'm not slamming the Sea Harrier... Had written orders to go fly it at one time and was REALLY looking forward to it, but for the "good of my career" I turned them down and took a staff job. I know that the Blue Vixen is capable in the BVR stages of the fight, but in close--pilots being equal--it's no match for a Hornet/Viper/Fulcrum. No doubt, although Sharkey did take on and beat F-15s and F-16s (the F-16s were tougher, according to him), and it's apparently quite hard to get an IR lock (at least with the missiles available in 1982; IIR types may not have that problem) with a planform view from above, like when they're turning into you -- the wing and stab mask the exhausts. And it is small and smokeless. But the best bet is undoubtedly to kill the adversary BVR before maneuverability ever becomes an issue. Give both a/c HMS and off-boresight missiles and maneuverability's almost irrelevant. Guy True... Very true. --Woody Man that's laughable. The Brits enjoy trumping up the very minor curious attributes of their strange birds. They say similar things about the other assets that comprise their fleet of indigenously designed aircraft. May I name a few? The Panavia (British Designed) Tornado F.3? ("...the F-14 was considered, but it was not up to the job... ...inferior radar..." I love that one--Hardee har-har! Inferior indeed! Lets talk about the development time for the Foxhunter radar). How about the Electric Lightning F.6? ("Pioneered supercruise!" ... sure; "better than an F-15" uh-huh, bear in mind F.6 did not have a gun--just two short range and very ineffective missiles. Although no longer in service, it's frequently brought up as a high water mark of British aircraft engineering. Even among the Brits it had a notorious reputation for being short ranged and almost impossible to maintain. Lastly, who can forget the beautiful Blackburn Buccaneer? ("Faster than an F-16 or F-15 with a full load of armament..." OK... ****'s getting deep.) Would this be the same Buc that carried a full load at 250ft (or below) that the F16s and F15s were BANNED (yes you did read that right) from fighting in the weeds due to the severe performance advantage enjoyed by the Buc. Not sure if its true, but I've heard that at least one f16(?) tried to fight in the weeds, and ended up becoming a weed? I'm not trying be belittle the Brits, but this aircraft is still in front line service (Although I'm sure that point will be disputed). What they don't say is that the Buccaneer can only achieve this by flying at the lowest of levels-which due to the density of the air, does create high drag on the F-16 and F-15. But it also penalizes the Buccaneers own range. At moderate altitudes where a typical aircraft would fly the bulk of the journey before descending to attack (have you ever seen a tanker at lo-lo level--other than landing?), both F-16 and F-15 have superior range and speed-even with a full bag of ordinance. The Buccaneer, assuming it had refueled several times to reach the attack point, would promptly be shot out of the sky upon the initiation of an attack. Why, you ask? She would make a wonderful target: Her obsolete tail pipes would be glowing red hot, or better yet, the opposition would have an excellent heat lock due to the boundary layer control system (engine bleed gases exiting the wing leading edge) used to enhance lift. I love the Brits. -Chuck |
Would this be the same Buc that carried a full load at 250ft (or below) that the F16s and F15s were BANNED (yes you did read that right) from fighting in the weeds due to the severe performance advantage enjoyed by the Buc. Not sure if its true, but I've heard that at least one f16(?) tried to fight in the weeds, and ended up becoming a weed? What utter Bullsh**. The Buc would not last 5 minutes in the same sky with an F -15 or an F-16. It was, repeat was, a fine a/c thirty years ago, now it is a museum piece. Al Minyard |
So at a rough guess, you don't believe me? Well thats your choice, but when
you consider the air mass displacement the buc had at low level, anybody trying to get in behind it was going to end up in trouble, as I previously mentioned. This was in the days before a true look down shoot down missile existed, and anything that did try to lock on, usually ended up (or would have if they were real missiles - Red Flag) getting lost in ground return - the point I was making. "Alan Minyard" wrote in message ... Would this be the same Buc that carried a full load at 250ft (or below) that the F16s and F15s were BANNED (yes you did read that right) from fighting in the weeds due to the severe performance advantage enjoyed by the Buc. Not sure if its true, but I've heard that at least one f16(?) tried to fight in the weeds, and ended up becoming a weed? What utter Bullsh**. The Buc would not last 5 minutes in the same sky with an F -15 or an F-16. It was, repeat was, a fine a/c thirty years ago, now it is a museum piece. Al Minyard |
"Ian Craig" wrote in
: So at a rough guess, you don't believe me? Well thats your choice, but when you consider the air mass displacement the buc had at low level, anybody trying to get in behind it was going to end up in trouble, as I previously mentioned. This was in the days before a true look down shoot down missile existed, and anything that did try to lock on, usually ended up (or would have if they were real missiles - Red Flag) getting lost in ground return - the point I was making. "Alan Minyard" wrote in message ... Would this be the same Buc that carried a full load at 250ft (or below) that the F16s and F15s were BANNED (yes you did read that right) from fighting in the weeds due to the severe performance advantage enjoyed by the Buc. Not sure if its true, but I've heard that at least one f16(?) tried to fight in the weeds, and ended up becoming a weed? What utter Bullsh**. The Buc would not last 5 minutes in the same sky with an F -15 or an F-16. It was, repeat was, a fine a/c thirty years ago, now it is a museum piece. Al Minyard Yeah, I don't believe you. What you quote is a 'book legend.' A practice almost exclusively enjoyed by the British. Whatever happened to British understatement? Instead its given way to British Hyperbole: seemingly impossible feats of daring do accomplished only by Brits in their obsolete, funny looking airplanes. I'm getting tired... Can you tell me a good fairy tale? Why don't you tell me the story about the Buc that hooked a tumbleweed on its pitot tube. I love that one! Your Pal, Chuck |
Nope - never heard that one. Care to enlighten me?
I have heard about the USAF fitter (don't know what the americans call them?) who did pull-ups on a pitot probe and bent it. Rather than fix it he bent the rest of the flights? Heard that one - I'm sure I could find it and read it to you some other time?? "Chuck Johnson" wrote in message . 165.241... "Ian Craig" wrote in : So at a rough guess, you don't believe me? Well thats your choice, but when you consider the air mass displacement the buc had at low level, anybody trying to get in behind it was going to end up in trouble, as I previously mentioned. This was in the days before a true look down shoot down missile existed, and anything that did try to lock on, usually ended up (or would have if they were real missiles - Red Flag) getting lost in ground return - the point I was making. "Alan Minyard" wrote in message ... Would this be the same Buc that carried a full load at 250ft (or below) that the F16s and F15s were BANNED (yes you did read that right) from fighting in the weeds due to the severe performance advantage enjoyed by the Buc. Not sure if its true, but I've heard that at least one f16(?) tried to fight in the weeds, and ended up becoming a weed? What utter Bullsh**. The Buc would not last 5 minutes in the same sky with an F -15 or an F-16. It was, repeat was, a fine a/c thirty years ago, now it is a museum piece. Al Minyard Yeah, I don't believe you. What you quote is a 'book legend.' A practice almost exclusively enjoyed by the British. Whatever happened to British understatement? Instead its given way to British Hyperbole: seemingly impossible feats of daring do accomplished only by Brits in their obsolete, funny looking airplanes. I'm getting tired... Can you tell me a good fairy tale? Why don't you tell me the story about the Buc that hooked a tumbleweed on its pitot tube. I love that one! Your Pal, Chuck |
On Tue, 23 Sep 2003 20:47:38 +0100, "Ian Craig"
wrote: Nope - never heard that one. Care to enlighten me? I have heard about the USAF fitter (don't know what the americans call them?) who did pull-ups on a pitot probe and bent it. Rather than fix it he bent the rest of the flights? Heard that one - I'm sure I could find it and read it to you some other time?? That was a Greek guy guarding two transient aircraft, not an American. It was reported in Flight International. Mary -- Mary Shafer "There are only two types of aircraft--fighters and targets" Major Doyle "Wahoo" Nicholson, USMC |
"Mary Shafer" wrote in message ... On Tue, 23 Sep 2003 20:47:38 +0100, "Ian Craig" wrote: Nope - never heard that one. Care to enlighten me? I have heard about the USAF fitter (don't know what the americans call them?) who did pull-ups on a pitot probe and bent it. Rather than fix it he bent the rest of the flights? Heard that one - I'm sure I could find it and read it to you some other time?? That was a Greek guy guarding two transient aircraft, not an American. It was reported in Flight International. Indeed, it was a Greek guard who did this on one of four Mirage F.1EQ underway from France to Iraq, in April 1981. After noticing he did something wrong, he bent the pitot probes on the other three aircraft too... The French had to fly-in a team of technicians with spare parts to solve the problem.... ;-))) Tom Cooper Co-Author: Iran-Iraq War in the Air, 1980-1988: http://www.acig.org/pg1/content.php and, Iranian F-4 Phantom II Units in Combat: http://www.osprey-publishing.co.uk/t...hp/title=S6585 |
"Tom Cooper" wrote in
: "Mary Shafer" wrote in message ... On Tue, 23 Sep 2003 20:47:38 +0100, "Ian Craig" wrote: Nope - never heard that one. Care to enlighten me? I have heard about the USAF fitter (don't know what the americans call them?) who did pull-ups on a pitot probe and bent it. Rather than fix it he bent the rest of the flights? Heard that one - I'm sure I could find it and read it to you some other time?? That was a Greek guy guarding two transient aircraft, not an American. It was reported in Flight International. Indeed, it was a Greek guard who did this on one of four Mirage F.1EQ underway from France to Iraq, in April 1981. After noticing he did something wrong, he bent the pitot probes on the other three aircraft too... The French had to fly-in a team of technicians with spare parts to solve the problem.... ;-))) Tom Cooper Co-Author: Iran-Iraq War in the Air, 1980-1988: http://www.acig.org/pg1/content.php and, Iranian F-4 Phantom II Units in Combat: http://www.osprey-publishing.co.uk/t...hp/title=S6585 More British (penis) envy of their French neighbors. How tiresome... and yet fun! Not that I love the French, but I love the unrestrained never ending British jealousy directed at the evidently technically superior French (Planes, Trains and Automobiles--oops! I forgot ships too (Queen Mary II)!). As for the Brits, they do degrade their neighbors in remarkably good taste. Jolly Good! On a military note, what's the deal with the MoD considering 'drastic reductions' in the Eurofighter orders? |
#29
"Chuck Johnson" wrote in message . 165.241... "Tom Cooper" wrote in : More British (penis) envy of their French neighbors. How tiresome... and yet fun! Not that I love the French, but I love the unrestrained never ending British jealousy directed at the evidently technically superior French (Planes, Trains and Automobiles--oops! I forgot ships too (Queen Mary II)!). As for the Brits, they do degrade their neighbors in remarkably good taste. Jolly Good! On a military note, what's the deal with the MoD considering 'drastic reductions' in the Eurofighter orders? Chuck, if this was sent to my adress, let me tell you, first of all, I'm not British: I'm a pretty weird mix with a WASP, German and even Slavic backgrounds. In short: a product of a familiy with 700 years of military-service tradition. If you want to bash me, call me a "prototype K.u.K. bourgeois", no problem: just not "British". ;-))) As second: that with the bent pitot tubes simply happened: that is a fact. And, it was done by a Greek guard to a French aircraft. So, sorry: not my fault. Re. your military note: everybody is talking about "drastic cuts" of the EF-2000's production run already since years. Sometimes they do this, many times not. Germany already threatened to get out of the project completely, two or so years back.... Tom Cooper Co-Author: Iran-Iraq War in the Air, 1980-1988: http://www.acig.org/pg1/content.php and, Iranian F-4 Phantom II Units in Combat: http://www.osprey-publishing.co.uk/t...hp/title=S6585 |
#30
The deal with the MoD 'considering drastic cuts' - probably the same thing
as the DoD doing exactly the same thing to F(should I add the /A?)-22. Politics...... "Chuck Johnson" wrote in message . 165.241... "Tom Cooper" wrote in : "Mary Shafer" wrote in message ... On Tue, 23 Sep 2003 20:47:38 +0100, "Ian Craig" wrote: Nope - never heard that one. Care to enlighten me? I have heard about the USAF fitter (don't know what the americans call them?) who did pull-ups on a pitot probe and bent it. Rather than fix it he bent the rest of the flights? Heard that one - I'm sure I could find it and read it to you some other time?? That was a Greek guy guarding two transient aircraft, not an American. It was reported in Flight International. Indeed, it was a Greek guard who did this on one of four Mirage F.1EQ underway from France to Iraq, in April 1981. After noticing he did something wrong, he bent the pitot probes on the other three aircraft too... The French had to fly-in a team of technicians with spare parts to solve the problem.... ;-))) Tom Cooper Co-Author: Iran-Iraq War in the Air, 1980-1988: http://www.acig.org/pg1/content.php and, Iranian F-4 Phantom II Units in Combat: http://www.osprey-publishing.co.uk/t...hp/title=S6585 More British (penis) envy of their French neighbors. How tiresome... and yet fun! Not that I love the French, but I love the unrestrained never ending British jealousy directed at the evidently technically superior French (Planes, Trains and Automobiles--oops! I forgot ships too (Queen Mary II)!). As for the Brits, they do degrade their neighbors in remarkably good taste. Jolly Good! On a military note, what's the deal with the MoD considering 'drastic reductions' in the Eurofighter orders? |
| Thread Tools | |
| Display Modes | |
| Osprey vs. Harrier | Stephen D. Poe | Military Aviation | 58 | August 18th 03 04:17 PM |
