#21
"Sliker" wrote in message
... On Tue, 20 May 2008 19:51:36 -0700 (PDT), BobR wrote: you know if the stuff didn't smell so bad, or take so long to cure, or wet out the cloth a little better due to it's higher viscosity, I might be in the group of those who hail the stuff. There are lower viscosity epoxy resins designed for lamination / wetting out... -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
On May 21, 8:06*pm, "Capt. Geoffrey Thorpe" The Sea Hawk At Wow Way
D0t C0m wrote: "Sliker" wrote in message ... On Tue, 20 May 2008 19:51:36 -0700 (PDT), BobR wrote: you know if the stuff didn't smell so bad, or take so long to cure, or wet out the cloth a little better due to it's higher viscosity, I might be in the group of those who hail the stuff. There are lower viscosity epoxy resins designed for lamination / wetting out... This site argues that epoxy is not a good choice for amphibian aircraft http://www.seawind.biz/techtalk.html ..scroll down to "Not all fibreglass is created equal" John Halpenny |
On May 21, 9:16*pm, John Halpenny wrote:
On May 21, 8:06*pm, "Capt. Geoffrey Thorpe" The Sea Hawk At Wow Way D0t C0m wrote: "Sliker" wrote in message .. . On Tue, 20 May 2008 19:51:36 -0700 (PDT), BobR wrote: you know if the stuff didn't smell so bad, or take so long to cure, or wet out the cloth a little better due to it's higher viscosity, I might be in the group of those who hail the stuff. There are lower viscosity epoxy resins designed for lamination / wetting out... This site argues that epoxy is not a good choice for amphibian aircraft http://www.seawind.biz/techtalk.html *..scroll down to "Not all fibreglass is created equal" John Halpenny I read it and find it rather strange that epoxy is widely used for boat construction and none of the boat supply sites that I have seen ever made mention of any problems. I would think they would be quick to point out such a major problem. |
On Wed, 21 May 2008 14:20:50 -0700 (PDT), BobR
wrote: Get a good carbon filter mask, some gloves, and good ventilation. GOOD LUCK and try to have fun anyway. I've made peace with the stuff for now. I've got a fan pointed up at the ceiling above where I'm working. It pushes the air downward over my work area, carrying away the fumes, and me being upwind of it, I'm not smelling anything. I can tell the cured epoxy has more toughness than vinyl ester resin does. Messing around with some leftover, cured epoxy, it kind of reminds me of stainless steel. Not the brittle type of hardness some cured resins have, but it feels very strong. And it does wet out better when the temperature is warmer. It was up into the high 70's in my shop yesterday, and it flows a lot better at that temp. I got my pods from Gary Hunter, but noticed he doesn't respond to emails. I've read other posts on the Canard Zone blog, and at least one other EZ owner reported the same thing. Do you know if he's out of the baggage pod business? If so, when I sell my plane, I may keep the pod, since they aren't available anymore. Not sure if any other company is making them. Researching those pods, I ran across something interesting. It seems if one wanted to build a Long EZ, the plans are available. By first downloading the "openEZ" file, then purchasing the TERFCD, a complete set of Long EZ plans is then aquired. The plans have to be taken to a printer to get the full sized plans, but at least they are available. I'd be inclinded to build a Cozy MK IV if a canard was in my future, just to have the extra room. Although, with todays fuel prices, the Long EZ, with it's smaller engine requirement might get popular again. There was also a shareware version of the Aerocanard floating around for a while, but it's been removed from the sites that had it. It might be still out there somewhere, but from what I've read, it's not a complete set of plans you could build one from. It's just to let prospective builders look it over. |
On May 22, 10:34*am, Sliker wrote:
On Wed, 21 May 2008 14:20:50 -0700 (PDT), BobR wrote: Get a good carbon filter mask, some gloves, and good ventilation. GOOD LUCK and try to have fun anyway. I've made peace with the stuff for now. I've got a fan pointed up at the ceiling above where I'm working. It pushes the air downward over my work area, carrying away the fumes, and me being upwind of it, I'm not smelling anything. I can tell the cured epoxy has more toughness than vinyl ester resin does. Messing around with some leftover, cured epoxy, it kind of reminds me of stainless steel. Not the brittle type of hardness some cured resins have, but it feels very strong. And it does wet out better when the temperature is warmer. It was up into the high 70's in my shop yesterday, and it flows a lot better at that temp. The temperature issue would also explain you problems with cure time as well. Room temperature means warm, not cold. However, when the temps rise into the 90's which was not uncommon for my working environment, the slow cure epoxy was really really appreciated. When I took the builders class on composites one of the demos performed by the instructor was to use a hammer on cured blocks of both epoxy and Vinyl Ester. The Vinyl Ester shattered into a thousand pieces while there was no effect on the epoxy except for a small chip where the hammer hit. Not sure if that is the same with all epoxy formulations. I got my pods from Gary Hunter, but noticed he doesn't respond to emails. I've read other posts on the Canard Zone blog, and at least one other EZ owner reported the same thing. Do you know if he's out of the baggage pod business? If so, when I sell my plane, I may keep the pod, since they aren't available anymore. Not sure if any other company is making them. I know Gary but didn't know he was making pods. Haven't talked with him in a very long time and haven't any idea what he is upto now. Researching those pods, I ran across something interesting. It seems if one wanted to build a Long EZ, the plans are available. By first downloading the "openEZ" file, then purchasing the TERFCD, a complete set of Long EZ plans is then aquired. The plans have to be taken to a printer to get the full sized plans, but at least they are available. I'd be inclinded to build a Cozy MK IV if a canard was in my future, just to have the extra room. Although, with todays fuel prices, the Long EZ, with it's smaller engine requirement might get popular again. There was also a shareware version of the Aerocanard floating around for a while, but it's been removed from the sites that had it. It might be still out there somewhere, but from what I've read, it's not a complete set of plans you could build one from. It's just to let prospective builders look it over. I looked at the Velocity and the Cozy a long time ago before I started on my project. I loved the look of the planes but after getting an opportunity to flying in a Velocity once, I am glad I decided on a more traditional tractor design. Nothing concrete to say against the canards other than my personal preference. I just didn't like the ground handling and the transition to and from flight mode of the canards. |
On May 22, 4:40*am, "Byron Covey" wrote:
Saying "epoxy" is analogous to saying "steel." *It isn't very specific. BJC Very true. The number of formulations and the ability to program in the desired characteristics desired in the completed product are endless. |
This thread has precipitated a lot of discussion on the Yahoo glidertech
news group http://tech.groups.yahoo.com/group/glidertech/ Wayne HP-14 "Six Foxtrot" http://www.soaridaho.com/Schreder "BobR" wrote in message ... On May 22, 4:40 am, "Byron Covey" wrote: Saying "epoxy" is analogous to saying "steel." It isn't very specific. BJC Very true. The number of formulations and the ability to program in the desired characteristics desired in the completed product are endless. |
On Thu, 22 May 2008 15:02:03 -0700 (PDT), BobR
wrote: I looked at the Velocity and the Cozy a long time ago before I started on my project. I loved the look of the planes but after getting an opportunity to flying in a Velocity once, I am glad I decided on a more traditional tractor design. Nothing concrete to say against the canards other than my personal preference. I just didn't like the ground handling and the transition to and from flight mode of the canards. True, most of the flight reports I read about the canards leave me not so excited about the way they fly and handle. Nice flying qualities sometimes seem to get forgotten. Several pilots that have flown the Lancairs (2 seat versions) say they have a dead feel and not much fun to fly. I've been building a Glasair for many years, and just a couple of years ago I finally got to fly one. The ailerons were nice, but the elevator felt kind of dead. Makes me want to keep the plane I have and sell it when it's finished. No one will talk about that subject much, probably out of fear of making their planes hard to sell. But it's not such a great system to spend years on end building a plane, only to find out it flies bad. |
#29
On May 22, 7:19*pm, Sliker wrote:
On Thu, 22 May 2008 15:02:03 -0700 (PDT), BobR wrote: I looked at the Velocity and the Cozy a long time ago before I started on my project. *I loved the look of the planes but after getting an opportunity to flying in a Velocity once, I am glad I decided on a more traditional tractor design. *Nothing concrete to say against the canards other than my personal preference. *I just didn't like the ground handling and the transition to and from flight mode of the canards. True, most of the flight reports I read about the canards leave me not so excited about the way they fly and handle. Nice flying qualities sometimes seem to get forgotten. Several pilots that have flown the Lancairs (2 seat versions) say they have a dead feel and not much fun to fly. I've been building a Glasair for many years, and just a couple of years ago I finally got to fly one. The ailerons were nice, but the elevator felt kind of dead. Makes me want to keep the plane I have and sell it when it's finished. *No one will talk about that subject much, probably out of fear of making their planes hard to sell. But it's not such *a great system to spend years on end building a plane, only to find out it flies bad. I have flown two versions of the Kis Cruiser which I am building and found it to be a very predictable but not the most exciting plane to fly. On the other hand, I wasn't really looking for an exciting plane so much as a good cross country plane. Even at that, the performance figures are good and it is not so large that it flys like a big boat either. With homebuilts though, you may find measurable differences in flying qualities between copies of the same aircraft. An example can be found with different builders of the KIS. Some have determined that they wanted more elevator control and added a couple of inches to the trailing edge of their elevators. I agree with you that spending years building only to find out the plane you built is not the plane you expected is a very bad deal. I know at least one RV-6 builder who spent years building a very beautiful airplane. He put on about a dozen hours of the initial flight testing and immediately put the plane up for sale. The aircraft was everthing it was supposed to be but it scared the s__t out of him and he went back to his Cub. Seemed that what he really enjoyed flying was low and slow. |
Questions about homebuilding, and the Sportman 2+2 in particular | Paul Tomblin | Home Built | 7 | April 29th 06 06:57 PM |
New Aircraft Homebuilding Forum | VP2Flyer | Owning | 0 | January 11th 05 04:22 AM |
New Aircraft Homebuilding Forum | VP2Flyer | Home Built | 0 | January 11th 05 03:57 AM |
Homebuilding Killed John Denver | never_moore352 | Home Built | 36 | September 4th 04 03:38 AM |
Problems with homebuilding: bad manual | MINIWI | General Aviation | 3 | January 27th 04 10:53 PM |
