#21
Not shown are the dozens of switches and buttons on the overhead panel. -- Jim Pennino Remove .spam.sux to reply. Apart from lighting controls the overhead panel isn't required much during flight and only necessary for pre-flight and engine start. It of course requires monitoring with fuel systems being configured for tank/engine when required but apart from that no real input from the pilot. Most of the work is via the MCP on the glareshield and the FMC Ibby |
It's been two hours staring at that screen (NOT) and I am still
looking for the altitude hold button LOL *I'za along with the 100's of passengers would have been dead 118 minutes ago looking for that durn thing. See the '10000' on the MCP (the linear panel along the length of the window) Below that is a knob rotate it left to assign a lower altitude and right to increase, below this knob is a button which clearly says 'HOLD' There is also a 'HOLD' button below Heading too which means the aircraft can retain a set heading or altitude whilst you change to the next desired, pressing Heading Select will result in the aircraft turning at a time of your choosing rather than the second you touch the knob and VS (Vertical Speed) switch will start the aircraft climbing or descending at a choosen rate when this is pressed too. Ibby |
Your statement was obvious nonsense from looking at the picture of a real airplane. Afraid MX is correct on this one. The overhead panel on 737's and 747's handle the IRS's (Inertial Referencing System, these are like GPS), Hydraulics Systems, Battery and Electrical power system, fuel control systems, engine autostart systems and continuous ignition if visible moisture is present,anti-ice, pressurisation and air conditioning systems, fire control system and internal and external lighting controls. They do NOT control the atitude and etc of the aircraft and require little input after takeoff. The Flight Management Computer controls the majority of the flight by taking control of the autopilot and autothrottle systems. The Mode Control Panel which has 13 buttons, 4 knobs and 2 switches for the Flight Director and Autothrottle are really all that is required for input to manually over-ride the active flightplan in the FMC. Airline pilots use this method when vectored into an airport by ATC, or when given specific headings to follow or altitude and speed restrictions Ibby |
No one can reguilarly crash and die. True. *It's a different pilot each time. Sorry but that is funny observation ;-) Ibby |
Ibby wrote:
Your statement was obvious nonsense from looking at the picture of a real airplane. Afraid MX is correct on this one. His original statement was there are only a dozen or so switches and buttons. If you look at the entire panel, there are a lot more then that. The overhead panel on 737's and 747's handle the IRS's (Inertial Referencing System, these are like GPS), Hydraulics Systems, Battery and Electrical power system, fuel control systems, engine autostart systems and continuous ignition if visible moisture is present,anti-ice, pressurisation and air conditioning systems, fire control system and internal and external lighting controls. They do NOT control the atitude and etc of the aircraft and require little input after takeoff. The Flight Management Computer controls the majority of the flight by taking control of the autopilot and autothrottle systems. The Mode Control Panel which has 13 buttons, 4 knobs and 2 switches for the Flight Director and Autothrottle are really all that is required for input to manually over-ride the active flightplan in the FMC. Airline pilots use this method when vectored into an airport by ATC, or when given specific headings to follow or altitude and speed restrictions Ibby -- Jim Pennino Remove .spam.sux to reply. |
Ibby wrote:
Not shown are the dozens of switches and buttons on the overhead panel. -- Jim Pennino Remove .spam.sux to reply. Apart from lighting controls the overhead panel isn't required much during flight and only necessary for pre-flight and engine start. It of course requires monitoring with fuel systems being configured for tank/engine when required but apart from that no real input from the pilot. Most of the work is via the MCP on the glareshield and the FMC Ibby No one said it was required during flight. The point of contention is how many switches and buttons are present and have to be looked at to find a particular one, not what they do. -- Jim Pennino Remove .spam.sux to reply. |
"Mxsmanic" wrote in message ... I'm talking to a pilot who largely admits having no clue about 747s, but that doesn't stop him from talking about them. As opposed to a dumb assed, non-pilot that has no clue about a 747. |
"Mxsmanic" wrote in message ... writes: Yeah, so what? So I'm better informed than most of the people arguing with me. I noticed you snipped the part where you were wrong, i.e. where you stated there were only a dozen of so switches and buttons. It depends on which part of the panel you are looking at. Should I count everything back to the cockpit door? God you're stupid. |
#29
"Mxsmanic" wrote in message ... -b- writes: Fortunately, safe pilots are not so brazen. Instead of testosterone to assert knowledge, they rely on documentation and they cross-check. They can do that with simulation alone. Prove it moron. |
#30
"Mxsmanic" wrote in message ... BeechSundowner writes: Some people will, but they have to start with an open mind. Waaaaaaaaaaaaaa, says the poster child for those with a closed mind. There goes another irony meter. |
| Thread Tools | |
| Display Modes | |
| [email protected] | Glenn Alderton[_2_] | Aviation Photos | 14 | January 5th 07 03:35 AM |
| UK Defence Shakeup | Ian MacLure | Military Aviation | 0 | July 22nd 04 04:40 AM |
| U.S. pilot has new defence | Otis Willie | Military Aviation | 0 | June 30th 04 11:50 PM |
| Bulldozing US Homeland Defence. | Tamas Feher | Military Aviation | 44 | June 13th 04 11:12 PM |
| USA Defence Budget Realities | Stop SPAM! | Military Aviation | 17 | July 9th 03 03:11 AM |
