Gageteers, we need a digital heading sensor
Old June 23rd 04, 06:39 AM
tango4
JLR-10 GPS Compass
http://www.jrcamerica.com/product.asp?Product_Id=17778
Furuno SC-50
http://www.maritech.com/satellite_compass.htm
both around US$ 3500.
And we complain about the cost of loggers!
Ian
"Bill Daniels" wrote in message
news:eb3Cc.94362$Sw.26496@attbi_s51...
"Dave Houlton" wrote in message
Derrick Steed wrote:
Isn't there some form of flux gate compass which can be used? The
GPS's
we use originated in the maritime market (after NMEA is a maritime
standard), surely there is a flux gate compass with NMEA output.
Rgds,
Derrick.
Hi, Bill.
The Garmin eTrex Vista includes GPS, barometric altitude, and electronic
compass. IIRC all the above data are output on the serial interface as
NMEA or Garmin sentences.
Can you get by with +- 2 degrees heading accuracy? No idea how big the
dip error is when wings banked, but maybe your flight computer could be
smart enough to use the compass when straight & level and switch to
turning-base wind calculation when banked?
http://www.garmin.com/products/etrexVista/spec.html
Dave
The "compass" on many handheld GPS units really shows ground track
although
I think some of them have electronic flux gate compasses. To compute true
wind data you need four inputs: True Heading, True Airspeed, Ground Speed
and Ground Track. We only need to add heading to get true wind info.
There are fluxgate and other magnetoresistive sensors that use the earth
magnetic field to determine heading. The $500 NMEA marine units would
probably work but they suffer from all the problems that any magnetic
compass has. There are other clever devices that detect the magnetic
field
in three axes and, with the GPS position data and a look-up table,
subtract
the variation and dip errors to output true north.
I still like the idea of a double-headed GPS receiver with two antennas a
meter apart on the fuselage centerline. These should be good to a half
degree accuracy. If you add MEMS gyros for a "coast through" in the event
of a GPS signal interruption, you have an elegant heading sensor.
Bill Daniels
  #32
Old June 26th 04, 05:36 AM
Scott
Here is what you are looking for.
http://www.filser.de/main.php?dat=e_...7000pi#compass
  #33
Old June 26th 04, 07:07 AM
tango4
Nope, thats a fluxgate compass and subject to all the normal magnetic
compass influences. What was suggested was a dual antenna GPS heading
sensor, a completely different beast.
Ian
"Scott" wrote in message
Coupled approach? Roy Smith Instrument Flight Rules 22 September 29th 04 10:46 PM
GPS/Flight Planner/ATC/Auto Pilot Dave Schwartz Simulators 11 May 11th 04 03:05 AM
FA: 10 Watt - Solid State Digital VHF- Transceiver Unicom OH Aviation Marketplace 0 March 30th 04 03:29 PM
KAP140 Autopilot Details News Instrument Flight Rules 27 October 22nd 03 03:01 AM
Great circle formulae, True cource and actual heading Sims Piloting 27 October 11th 03 02:55 PM
