More LED's - Again
Old March 19th 06, 12:33 AM posted to rec.aviation.homebuilt,sci.electronics.design
Default More LED's - Again
RST Engineering (jw) wrote:
The secret is HIGH GLOSS, LOW QUALITY photo paper. The high gloss means
that the toner won't diffuse into the pores of the paper and the low quality
means that the backing paper will soak off easily in hot sudsy water.
I can hold long 10 mil lines and 10 mil gaps with relative ease.
MUCH easier than press-n-peel.
Well, you da man, Jim.
I'll give it a try.
http://www.home.earthlink.net/~tp-1/rcatest.jpg
Not as crisp as the original tiff file, but...
  #32
Old March 20th 06, 03:33 PM posted to rec.aviation.homebuilt
The Sealing of anodized aluminum is very simple... Steam!
"RST Engineering" wrote in message
"flybynightkarmarepair" wrote in message
RST Engineering wrote:
Now you can etch the board in the usual way.
Or you can use the new, improved way without that nasty ferric chloride.
Plain old swimming pool etchant (muriatic acid -- 28% HCl) from the home
store plus plain old hydrogen peroxide (3%) from the drug store mixed
2:1
respectively does an admirable job at room temperature. Plus, when you
get
done, you have metallic copper (not a hazmat), hydrochloric acid (not a
hazmat), and the hydrogen peroxide which, within half an hour, has
broken
down into oxygen (which has escaped into the air) and water. If you
want to
be totally environmentally friendly, you can neutralize the HCl with
baking
soda ($5.99 for ten pounds at the Charlie's Club places) before pouring
it
down the sink.
Ferric Chloride may be safer than Muratic Acid
http://www.artmondo.net/printworks/articles/ferric.htm
Spent ferric chloride can be neutralized with soda as well.
Plus, I THIINK Ferric Chloride is the commonly available de-smuting
solution you need to anodize 2000 series aluminum.
For dyeing anodized aluminum, try RIT, or page through this catalog:
http://dharmatrading.com/html/eng/2934904-AA.shtml Sealing, I guess
you'll have to use clear lacquer.
  #33
Old March 20th 06, 05:47 PM posted to rec.aviation.homebuilt
You mean like holding it over a pan of boiling water on the kitchen stove?
How long in time?
Any more details or a point to a url?
"Cy Galley" wrote in message
news:AXzTf.39602$oL.16416@attbi_s71...
  #34
Old March 21st 06, 04:20 AM posted to rec.aviation.homebuilt
The steam method is how ALCOA found out that steam seals the anodizing.
Seems they had plain anodized cafeteria trays. Coffee would be spilled on
the tray. The coffee stain could be washed off most except for a few.
Alcoa was perplexed until they found that if the tray was set over the steam
table, then the coffee stain became permanent. Got this from an ALCOA movie
when I was trying to teach science to non-believers.
Cy Galley - Chair,
AirVenture Emergency Aircraft Repair
A Service Project of Chapter 75
EAA Safety Programs Editor - TC
EAA Sport Pilot
How long in time?
  #35
Old March 21st 06, 06:24 AM posted to rec.aviation.homebuilt
news:qaLTf.836270$x96.260249@attbi_s72...
steam
movie
So if it was steam sealed, and coffee got spilled on it, then steamed after
the spill, would the coffee wash off of it?
  #36
Old March 22nd 06, 02:24 AM posted to rec.aviation.homebuilt
Yes, After steaming, it would not stain
"Morgans" wrote in message
on
steam
movie
after
  #37
Old March 22nd 06, 05:26 AM posted to rec.aviation.homebuilt
Cool! Now, there is some information (like a transmission jack) that I can
use! g
It makes you wonder why anyone would put on any sealer, that could just chip
off, later.
KX-155 LEDs Steven Barnes Owning 21 July 11th 13 09:04 AM
Nav Lights using Luxeon LEDs Andrew Sarangan Home Built 28 March 7th 06 09:18 PM
More LED's Veeduber Home Built 19 June 9th 04 10:07 PM
LEDs for Nav Lights - Jim Weir Scott Gettings Home Built 3 February 17th 04 01:53 AM
LEDs Morgans Home Built 6 August 19th 03 03:49 AM
