"Richard Kaplan" wrote
I would say an overrun cannot happen in a 172 on ILS into the wind or with calm winds as long as the power is cut at decision height. If the airspeed is high as discussed in this thread and the airplane is on the glideslope, then the airplane should be within gliding distance of the runway at decision height. Yes, that's true. However, I consider an immediate power cut at decision height to be poor procedure. The normal ILS is flown on a 3 degree glideslope. However, the power-off glide in anything approaching landing configuration (meaning gear down if retractable and at least some flaps) will be 7-10 degrees. So a power cut at DH means a significant pitch change at low altitude. Since most of the fleet has tractor props and conventional tails, the power cut will also cause a significant out of trim condition - nose down. In good vis and with a Skyhawk-class airplane, it's not a big problem. Try that trick in your C-210 or my PA-30 in less than a mile vis, and unless you've practiced it extensively and recently, the landing is goint to be very, very ugly - possibly ugly enough for maintenance bills. People have been known to drive the gear right through the wings doing this. Since my IFR students are either flying high performance singles or twins or expect to move into them, I just can't see teaching the procedure you seem to be advocating. I instead teach a gradual power reduction with retrim, such that the pitch attitude never really changes and the airspeed bleeds off gradually. Yes, it eats more runway and on short runway may require a speed reduction on the ILS, but it seems like a beter tradeoff. Personally, I slow to about 95-100 mph (not kts) on the ILS at about 300 ft, which seems like the best compromise between retaining the option for a single engine missed approach and allowing a landing with a tailwind on a short ILS runway. In a single engine plane, I see no reason not to slow down further out. I know that an ILS can be flown in a Bonanza at 90 mph in turbulence - I've seen an instrument student do it. As far as flying an ILS with a tailwind, I agree that could cause an overrun. I would also suggest that landing out of an ILS in actual IMC conditions with a tailwind is an exercise which should be attempted only by an experienced, advanced IFR pilot and/or with an experienced CFII on-board. Well, I like to give my student the necessary tools to handle it. Of course since I don't instruct renters and don't deal with FBO's, finishing in the minimum allowable 40 hours is not my highest priority - nor theirs. In particular, a pilot who is uncomfortable flying a high-airspeed ILS with a headwind certainly should not attempt a tailwind ILS. Now that I can agree with. A high speed ILS is certainly something I consider important. It's just that a high speed ILS and a tailwind landing on a short runway simply don't mix. Michael |
"Richard Kaplan" wrote in message ws.com...
ILS runways are usually 5,000 feet or longer. You could dissipate speed over the runway. I suspect if you cross the runway threshold right on the glideslope at 90 knots in a Skyhawk with a 5,000 foot runway, there is no way you could overrun the runway if you tried. I don't know about a Skyhawk, but FWIW, our former home airport used to have only 1 ILS, to Rwy 8 which meant if low wx combined with wind, one might be landing with a tailwind (prevailing winds from west in these parts). As a training exercise, one time I kept my speed up to 90 kts over the threshold. I didn't run off the runway, but I was durn close to my "go around!" point before my plane decided to quit flying and settle down. I definately landed on the last 3rd of a 6,500 ft runway. Dunno what the tailwind was -- nothing too startling (10-12 kts?) Unfortunately, since many training ILS are done to a missed approach, landing from an ILS isn't something at which some instrument pilots get a lot of practice. Cheers, Sydney |
"Snowbird" wrote in message om... the last 3rd of a 6,500 ft runway. Dunno what the tailwind was -- nothing too startling (10-12 kts?) That is a very significant tailwind for landing; it would not surprise me if a 10 knot tailwind doubled your landing roll vs. a 10 knot headwind or if the total landing distance increased between 50% and 100%. -- Richard Kaplan, CFII www.flyimc.com |
"Snowbird" wrote in message om... the last 3rd of a 6,500 ft runway. Dunno what the tailwind was -- nothing too startling (10-12 kts?) That is a very significant tailwind for landing; it would not surprise me if a 10 knot tailwind doubled your landing roll vs. a 10 knot headwind or if the total landing distance increased between 50% and 100%. Hi Richard, As far as I could tell, it didn't do a thing to my landing roll. What it affected, drastically, was the distance it took my plane to slow to landing speed and consent to stop flying. I'm very glad I had a CFI who had me try this. Experience is worth 1000 words. After doing so, I can easily see how an overrun accident (or loss of control if someone tried to force the plane to land) could occur on a long, ILS-served runway. One size definately does not fit all situations for ILS procedures. I don't think it's a great idea to fly ILS routinely at 60 kts -- as someone pointed out, the margin over stall is much lower and the configuration changes needed for correction much larger than at 90 kts. OTOH, a practice of never retarding the throttle until over the threshold (as I believe Rick Durden suggested) would IMHO definately be a bad idea on a shorter runway (say 5000-6000 ft) w/ a tailwind. And my advice to instrument students is: make sure you actually land out of a good number of ILS in a number of different circumstances, preferably ILS in IMC or at night. For that matter, make sure you land out of a variety of approaches. Cheers, Sydney |
On Wed, 21 Jan 2004 21:56:10 -0500, Roy Smith wrote:
The graph doesn't go beyond a 10 kt tailwind; I can only assume Beech figured nobody would want to try a landing with any more :-) I believe that at air carrier airports (and, from personal experience, at BOS) ATC may continue using a runway with up to a ten knot tailwind. My first tailwind landing ever was done out of an ILS at BOS with about a ten knot quartering tailwind. But they have long runways (and I needed to be at the far end anyway to get to the GA ramp). Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Snowbird wrote:
Unfortunately, since many training ILS are done to a missed approach, landing from an ILS isn't something at which some instrument pilots get a lot of practice. That's why I do all my training approaches to a TGL. Which of course, means I don't get a lot of practice at missed approaches. I guess I ought to mix it up a little. Dave Remove SHIRT to reply directly. |
Any thoughts as to why Approach Plates do not list the time for an
approach speed of 75 KIAS? |
In a previous article, said:
Any thoughts as to why Approach Plates do not list the time for an approach speed of 75 KIAS? Because it's hard to land when you've got a Dash 8 embedded in your backside? -- Paul Tomblin http://xcski.com/blogs/pt/ .... industry giant Microsoft Corporation... a company that has become successful without resorting to software testing... -- Unknown, rec.humor.funny |
| Thread Tools | |
| Display Modes | |
| LSA Approach speeds | Ace Pilot | Home Built | 0 | February 3rd 04 06:38 PM |
| How much protection on approach? | Michael | Instrument Flight Rules | 20 | January 15th 04 06:58 PM |
| Completing the Non-precision approach as a Visual Approach | John Clonts | Instrument Flight Rules | 45 | November 20th 03 06:20 AM |
| Which of these approaches is loggable? | Paul Tomblin | Instrument Flight Rules | 26 | August 16th 03 06:22 PM |
| IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 10:03 PM |
