Newps wrote:
Not sure of the exact amount but that is a certification requirement. My 182 got pretty sporting if you had to do a go around. Since I mostly flew alone it was a nose heavy airplane and I always landed with full nose up trim. Not sure how to characterize how much force was required. Let's say significant. I don't know the exact force either, but I could easily hold down the nose of my 182 with full nose-up trim and full throttle. I'd guess 30-40 lbs of force, but that is just a guess. I can bench press probably 160 lbs (I haven't lifted in 20 years so I'm getting wimpy), which is 80 lbs per arm. I'm sure I wasn't using even half of my arm strength to hold the nose at climb attitude hence my guess of it being no more than 40 lbs and likely less than that. Matt |
Newps wrote:
Full nose up trim is immediately apparent on the application of power. The fact that he let it get away from him says it all. It doesn't take a lot of forward stick after takeoff to put the nose where it needs to be. One more non-aviator question here - is upset recovery training not normally part of the licensing procedure? What Larry described seems a good example of upset. Ramapriya |
oups.com... Newps wrote: Full nose up trim is immediately apparent on the application of power. The fact that he let it get away from him says it all. It doesn't take a lot of forward stick after takeoff to put the nose where it needs to be. One more non-aviator question here - is upset recovery training not normally part of the licensing procedure? What Larry described seems a good example of upset. Ramapriya In the United States the emphasis is on Angle of Attack Awareness and Stall Avoidance. You do fly both power on (take off / departure) stalls and power off (landing) stalls as well as turning stalls but full on unusual attitude recovery (in the sense in which I think you are referring) is not a part of the private pilot sylabus, no. Experiencing the pitch authority of full up trim at high power settings and how abrupt can be a Trim Stall should, IMO, be emphasized more stridently than it is (at least in the King Cessna course.) Jay B |
Part 23 establishes maximum stick force requirements. It does not take
superhuman strength to overcome full nose-up trim on takeoff. Bob Gardner "Newps" wrote in message ... Larry Dighera wrote: I once witnessed a Cessna C-172 crash on takeoff at Santa Monica Airport (KSMO) in the early '70s. The aircraft rotated, and rocketed skyward at a very high angle, stalled, and nosed into the runway. The pilot escaped with a broken finger. The cause was a result of the trim being set wrong. Don't forget your check list. Full nose up trim is immediately apparent on the application of power. The fact that he let it get away from him says it all. It doesn't take a lot of forward stick after takeoff to put the nose where it needs to be. |
Bob Gardner wrote:
Part 23 establishes maximum stick force requirements. It does not take superhuman strength to overcome full nose-up trim on takeoff. But part 23 was written before we all became overweight and out of shape couch potatoes! :-) Matt |
Newps wrote:
Larry Dighera wrote: I once witnessed a Cessna C-172 crash on takeoff at Santa Monica Airport (KSMO) in the early '70s. The aircraft rotated, and rocketed skyward at a very high angle, stalled, and nosed into the runway. The pilot escaped with a broken finger. The cause was a result of the trim being set wrong. Don't forget your check list. Full nose up trim is immediately apparent on the application of power. The fact that he let it get away from him says it all. It doesn't take a lot of forward stick after takeoff to put the nose where it needs to be. We had a Duchess crash for the same reason...I've never taken off with full nose up trim, but I'd imagine that if they could have pushed the nose down, they would have, correct? |
Emily wrote: We had a Duchess crash for the same reason...I've never taken off with full nose up trim, but I'd imagine that if they could have pushed the nose down, they would have, correct? No. You can't get a spam can certified if you can't overcome full nose up or down trim. This is the second one I've seen. A couple years ago a Skymaster crashed near here for the same reason. Pilot left full nose up trim after landing, then tried to takeoff. Airplane rotated way too soon and mushed off the end of the runway. Everybody walked away, plane totalled. Pilot got alarmed by the out of trim condition and became a spectator at that point. Dumbass. |
Newps wrote:
Emily wrote: We had a Duchess crash for the same reason...I've never taken off with full nose up trim, but I'd imagine that if they could have pushed the nose down, they would have, correct? No. You can't get a spam can certified if you can't overcome full nose up or down trim. This is the second one I've seen. A couple years ago a Skymaster crashed near here for the same reason. Pilot left full nose up trim after landing, then tried to takeoff. Airplane rotated way too soon and mushed off the end of the runway. Everybody walked away, plane totalled. Pilot got alarmed by the out of trim condition and became a spectator at that point. Dumbass. I just checked the report, and it appears that trim was at 10 degrees in the Duchess case. By the time I did my multi training at the same airport, we were still in a state of paranoia over elevator trim (crash killed three people), so it was something I always checked. How much would a typical light twin pitch up on takeoff with the trim set like that? I know myself, I usually ended up trimming down on climb because the nose was hard to hold down (although I never flew the 76) |
On 27 Aug 2006 08:39:44 -0700, wrote in . com: I was mentioning how illogical a crash-shortly-after-takeoff is, given that beyond V1 takeoff can safely be continued even with just one good engine. I once witnessed a Cessna C-172 crash on takeoff at Santa Monica Airport (KSMO) in the early '70s. The aircraft rotated, and rocketed skyward at a very high angle, stalled, and nosed into the runway. The pilot escaped with a broken finger. The cause was a result of the trim being set wrong. Don't forget your check list. I'd say in a 172 that the cause was a pilot who didn't know how to fly the airplane. It isn't that hard to overcome the trim on a 172. There are probably airplanes where this isn't the case, but the 172 isn't one of them. Matt |
Matt Whiting wrote:
It isn't that hard to overcome the trim on a 172. There are probably airplanes where this isn't the case, but the 172 isn't one of them. In theory, it should be possible on any plane. 14 CFR 23.677 (d) says: "It must be demonstrated that the airplane is safely controllable and that the pilot can perform all maneuvers and operations necessary to effect a safe landing following any probable powered trim system runaway that reasonably might be expected in service, allowing for appropriate time delay after pilot recognition of the trim system runaway. The demonstration must be conducted at critical airplane weights and center of gravity positions." |
| Thread Tools | |
| Display Modes | |
| UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 07:58 PM |
| Approaches and takeoff mins. | jamin3508 | Instrument Flight Rules | 22 | September 14th 05 03:51 AM |
| Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 01:18 PM |
| Overweight takeoff / flight | Koopas Ly | Piloting | 50 | December 4th 03 12:53 AM |
