#31
I couldn't get the pics tocome up!
Richard Lamb wrote: "Capt. Doug" wrote: Badwater Bill wrote in messageI built a 36x36 shop this spring too. I put a 10 foot high garage door on it that's 18 feet wide too. I'm all set. I can wheel an R-22 in and out of there. 10' high doors work for the R-22, but I'm wondering if an R-44 can fit by tilting the machine backwards or maybe sideways on a trick dolly. D. While we are on this particular drift, I really need ground gear for my lawn ornament. http://home.flash.net/~lamb01/rvn.htm/v_loh01c.jpg A dolly won't work due to low doors... I need to be able to move it around easier. Pipe rollers and a bunch of helpers is not convenient. Anybody have a clue? Richard |
#32
I got there doing this goto http://home.flash.net/~lamb01/, then click
on the Viet Nam Service Ribbon/Medal Bill HIgdon Warren & Nancy wrote: I couldn't get the pics tocome up! Richard Lamb wrote: "Capt. Doug" wrote: Badwater Bill wrote in messageI built a 36x36 shop this spring too. I put a 10 foot high garage door on it that's 18 feet wide too. I'm all set. I can wheel an R-22 in and out of there. 10' high doors work for the R-22, but I'm wondering if an R-44 can fit by tilting the machine backwards or maybe sideways on a trick dolly. D. While we are on this particular drift, I really need ground gear for my lawn ornament. http://home.flash.net/~lamb01/rvn.htm/v_loh01c.jpg A dolly won't work due to low doors... I need to be able to move it around easier. Pipe rollers and a bunch of helpers is not convenient. Anybody have a clue? Richard |
#33
"Richard Lamb" wrote in message
... While we are on this particular drift, I really need ground gear for my lawn ornament. http://home.flash.net/~lamb01/rvn.htm/v_loh01c.jpg A dolly won't work due to low doors... I need to be able to move it around easier. Pipe rollers and a bunch of helpers is not convenient. Anybody have a clue? Richard Air skids. http://www.hovair.com/air-bearings/a...ther-terms.htm Rich S. |
#34
In article , Ken Sandyeggo
says... Yes Bernie it does. With centerline thrust, there is no force above the vertical center of gravity to push it over. You need thrust above the vertical center of gravity in order to experience (once-in-a-lifetime only) a buntover. Once you do it, at least you don't ever have to worry about doing it again. Actually, Ken, you could still manually bunt the thing over with the stick. Can't think of why anyone would. The AAI redesign does seem to eliminate power pushover (the most common cause of bunting), and reduces the divergent pitch-recovery mode that leads to PIO (the next most common cause). It also takes out that long slow oscillation that RAF's have. I have been following the AAI thing for a while... spent a couple hours with Jim Mayfield at Mentone... spent more time at Fondy during OSH... flew it slightly (not much). The demonstrators they have been using are not their new gyro but modified RAF's like yours. Theirs is going to have a slightly larger cabin as well. I have a big story I'm working up on the whole AAI vs RAF thing... RAF is demoralised, and many of their dealers have bailed. But others are standing by out of loyalty. It's kind of a mess. RAF's answer is a sort of a trim vane mounted to the rotor mast, behind the cabin. They call it the Rotor Stabilator. Seen it? cheers -=K=- Rule #1: Don't hit anything big. |
#35
What the F__k, over?"
-- Bob Copyright 2002 Permission given for nonprofit use only. Badwater Bill wrote in message ... On Mon, 04 Aug 2003 05:28:30 GMT, "Bob" wrote: Hey Billy- You got all them pile-it letters but not the good ones. A & P and WTFO. You got me. What is WTFO? White, tar and feathers officer? What is it? Something ending with Flight Officer? BWB |
#36
Kevin O'Brien wrote in message ...
In article , Ken Sandyeggo says... Yes Bernie it does. With centerline thrust, there is no force above the vertical center of gravity to push it over. You need thrust above the vertical center of gravity in order to experience (once-in-a-lifetime only) a buntover. Once you do it, at least you don't ever have to worry about doing it again. Actually, Ken, you could still manually bunt the thing over with the stick. Can't think of why anyone would. The AAI redesign does seem to eliminate power pushover (the most common cause of bunting), and reduces the divergent pitch-recovery mode that leads to PIO (the next most common cause). It also takes out that long slow oscillation that RAF's have. I have been following the AAI thing for a while... spent a couple hours with Jim Mayfield at Mentone... spent more time at Fondy during OSH... flew it slightly (not much). The demonstrators they have been using are not their new gyro but modified RAF's like yours. Theirs is going to have a slightly larger cabin as well. I have a big story I'm working up on the whole AAI vs RAF thing... RAF is demoralised, and many of their dealers have bailed. But others are standing by out of loyalty. It's kind of a mess. RAF's answer is a sort of a trim vane mounted to the rotor mast, behind the cabin. They call it the Rotor Stabilator. Seen it? cheers Kevin, I'm not a real technical bug, but you're right, I should have said "power-pushover." I've seen photos of it. Minds that are more scientific and knowledgeable than mine analyzed the RAF "stabilator" and pronounced it basically worthless on the gyro forum. RAF says that it "stabilizes the rotor." The gyro forum is down right now. When it comes back up, I'll copy and paste the analysis of the RAF stabilator. As far as I know, they only have 3 dealers left in the U.S. There were four left, but the one in Florida got all his tickets suspended for a year. (They had around a dozen just a few years ago. They lost their New Zealand and Australian dealers also.) It was for instructing in an illegal gyro, but he's the one that had about 4 students and a passenger die in unstabbed RAFs after taking lessons from him in less than a year. I think you have to read between the lines on the FAA's findings. I think that they needed to get him on the ground for awhile someway. My converted gyro flies like a dream now. It was a great investment on the conversion. No more pitching and yawing all over the place. Ken J. - Sandy A. Ghowe -=K=- Rule #1: Don't hit anything big. |
#37
A less formal version of the interogative, The F comma What.
Bob wrote: What the F__k, over?" -- Bob |
#38
pac plyer wrote:
In my opinion this is a motocross term; WTFO: Wide Throttle, Full Open. It is not used in aviation. The definition given previously is common in Naval aviation. Can't say I've heard it alot WRT GA, but I've done *my* part :-) http://www.hazegray.org/faq/slang2.htm Dave 'fubar' Hyde |
#39
Dave Hyde wrote in message ...
pac plyer wrote: In my opinion this is a motocross term; WTFO: Wide Throttle, Full Open. It is not used in aviation. The definition given previously is common in Naval aviation. Can't say I've heard it alot WRT GA, but I've done *my* part :-) http://www.hazegray.org/faq/slang2.htm Dave 'fubar' Hyde Gee Mr Fubar, I use that term all the time. Never heard anybody include "WTFO" as a rating before! Really took the polar route on me. I mangled the dirt bike WFO to get someone to react and spell it out for me. Next time, I'll RTFQ closer (clever secret airline term) pac "spoof" plyer |
#40
Dave Hyde wrote:
pac plyer wrote: I mangled the dirt bike WFO to get someone to react and spell it out for me. Here's another one for you: MOTO Mewing Of The Orphans? :-) Dave 'AMF, YOYO' Hyde I always heard it as KMAGYOYO |
[Fwd: Why I'll never build a kit plane.] | Corky Scott | Home Built | 16 | July 28th 03 01:56 AM |
Why I'll never build a kit plane.] | Larry Smith | Home Built | 25 | July 25th 03 01:27 PM |
British Homebuilt Aeroplane needs Identifying | Phillip Rhodes | Home Built | 3 | July 11th 03 04:10 PM |
