#31
Larry Dighera wrote:
On Mon, 21 Jan 2008 19:55:03 GMT, wrote in : Larry Dighera wrote: On Mon, 21 Jan 2008 17:45:03 GMT, wrote in : Larry Dighera wrote: On Mon, 21 Jan 2008 08:32:09 -0800, C J Campbell wrote in 2008012108320950073-christophercampbell@hotmailcom: The FAA probably had nothing to do with a crash at Corona. Wasn't it the FAA who created Class B, C, and D airspace? To the extent that this concentrates aircraft not in contact with ATC in the limited airspace outside of Bravo, Charlie, and Delta airspace, the FAA can perhaps be seen as contributory. But it's a stretch. Here's a TAC: http://skyvector.com/#32-24-2-4488-3214 Yeah, look at it closely. The non-ATC controlled airspace around Corona is hardly limited. I suppose that depends on how one characterizes 'limited.' What I see is: Class D with a ceiling of 2,700' within a mile north TPA at Corona is 1533 and the pattern is to the south. The only way to get to Corona through the CNO class D is to first go through the ONT class C, and almost nobody does that except students being shown how to use the radio. The floor of outer ring of the KONT Class C is 2,700', so there's no need to transition the KONT Class C from the north though the KCNO Class D if you stay below 2,700', but that's not at issue here. Or in other words, there is a huge area around the class C, so it is hardly airspace limiting. Class Charlie with a floor of 2,700' overhead See above. If you are under the Class C and going to or coming from Corona, you would never be that high anyway. If remaining in VMC required it, you might. Not unless your A/C climbs like a fighter or has airbrakes for the decent. However, if it is not VMC below you, you certainly aren't going VFR to Corona Another Class Charlie a few miles to the SE The floor of the SNA class C in that area is 3500 feet. There is no reason to go in that direction unless you are actually going to SNA. Of course, there is the reciprocal to that statement, when you are arriving at KAJO. So how would the presence of SNA be a limitation on getting to Corona from SNA? You can't go down the coast that way as you would have to go through a restricted areas around Camp Pendleton. All you have to do to fly down the coast is stay a mile or two off shore, and you'll be clear of R2503 A & D. SNA is to the west; if you were going down the coast to one of the San Diego airports starting from Cornoa, the direct route is between SNA and Camp Pendleton. [...] And then there are the ~4,000' mountains ~5 miles to the southeast and the Paradise VORTAC ~3 miles NW that tend to concentrate aircraft. And on the other side of those hills (the mountains are to the north) is SNA and two restricted areas. You aren't going that way unless you are going to either SNA or Hawaii. I can think of no reason to anywhere near Paradise VORTAC either departing or arriving VFR at Corona. KAJO is located 3 miles from Paradise VORTAC; you don't get a choice. Traffic over Paradise is +/- 3 miles, and again I can think of no reason to be near Paradise. I find those as limiting the airspace available to flights not in contact with ATC. You say 'tomato'... I find the Pacific Ocean and the 10,000 foot mountains far more limiting than any controlled airspace area. Agreed. But that wasn't part of what we were discussing. I thought were discussing the limitations of controlled airspace. Most of the airports in the basin are towered. The only ones that are not are CCB, AJO, L67 (going away to developers), SBD, RIR and REI. What is your point? The point is that if you are going to controlled airspace on purpose, the fact that the airspace is controlled is hardly limiting as you have to talk to ATC and going no-radio isn't an option. Of course, this is a non-issue for IFR flights and those receiving Radar Traffic Advisory Service from ATC. Though in some places it is a very good ideo to have flight following, one can fly for hours in the basin without turning on the radio. -- Jim Pennino Remove .spam.sux to reply. |
#32
On Mon, 21 Jan 2008 19:55:03 GMT, wrote See above. If you are under the Class C and going to or coming from Corona, you would never be that high anyway. If remaining in VMC required it, you might. If you're remaining in VMC by climbing, you're not arriving VFR at AJO, and you wouldn't transit the area that low to begin with (see: mountains). Of course, there is the reciprocal to that statement, when you are arriving at KAJO. But no one flies SNA-AJO (even students; why fly all the way out there when you're practically standing on a perfectly good Class C?), and there's no other conceivable scenario that would involve the SNA Class C and arriving at AJO. You're either higher than the top, or have gone around it as a more efficient path. I can think of no reason to anywhere near Paradise VORTAC either departing or arriving VFR at Corona. KAJO is located 3 miles from Paradise VORTAC; you don't get a choice. All the traffic that transits the area over Paradise does so much higher than the ONT Class C, for obvious reasons, and becomes a non-issue to local AJO traffic. TheSmokingGnu |
#33
On Tue, 22 Jan 2008 02:05:39 GMT, TheSmokingGnu
wrote in Tbclj.3438$hk4.3134@trnddc03: But no one flies SNA-AJO (even students; why fly all the way out there when you're practically standing on a perfectly good Class C?), ... The cost of fuel is considerably cheaper at AJO than at SNA (and many other places in the nation). That's enough to motivate some folks with aircraft with considerable fuel capacity such as the PA28-235 (85 gallons) to fill up at AJO. |
#34
On 2008-01-21 08:57:00 -0800, Larry Dighera said:
On Mon, 21 Jan 2008 08:32:09 -0800, C J Campbell wrote in 2008012108320950073-christophercampbell@hotmailcom: The FAA probably had nothing to do with a crash at Corona. Wasn't it the FAA who created Class B, C, and D airspace? To the extent that this concentrates aircraft not in contact with ATC in the limited airspace outside of Bravo, Charlie, and Delta airspace, the FAA can perhaps be seen as contributory. But it's a stretch. Here's a TAC: http://skyvector.com/#32-24-2-4488-3214 In any event, I doubt if the FAA's affirmative action program had anything to do with it. -- Waddling Eagle World Famous Flight Instructor |
#35
On Tue, 22 Jan 2008 02:05:39 GMT, TheSmokingGnu wrote in Tbclj.3438$hk4.3134@trnddc03: But no one flies SNA-AJO (even students; why fly all the way out there when you're practically standing on a perfectly good Class C?), ... The cost of fuel is considerably cheaper at AJO than at SNA (and many other places in the nation). That's enough to motivate some folks with aircraft with considerable fuel capacity such as the PA28-235 (85 gallons) to fill up at AJO. While you are correct in that fueling at AJO will, in the PA-28's case, save you about $25 (over closer services at FUL, and ~$135 per at SNA), you have to take into account the added wear and tear on the aircraft; AJO is 19nm straightline, and the PA-28 will need something like 0.4 hours roundtrip to fuel at AJO (under perfect, traffic-less conditions and ideal flight path and no winds; don't forget time-on-ground, too). Assuming a TBO of 1500 hours (wild guess, am I ballpark?), you're looking at a savings of ~$43,000; can you overhaul an O-540 with that much money? What will it cost you in oil, tires and time to fly all the way out there and back each time for fuel? Also consider that this is relying on the only available supplier at SNA on AirNav; I'm almost certain there are more FBO's at SNA than one (been a long time). Consider that LGB is closer than AJO to SNA, and has self-serve fuel just 30 cents more expensive than AJO. Besides, I don't even think there are any good hamburger joints at AJO. I mean really! What's the point? :P TheSmokingGnu |
#36
On Tue, 22 Jan 2008 06:20:14 GMT, TheSmokingGnu
wrote in yWflj.3634$hk4.200@trnddc03: Larry Dighera wrote: On Tue, 22 Jan 2008 02:05:39 GMT, TheSmokingGnu wrote in Tbclj.3438$hk4.3134@trnddc03: But no one flies SNA-AJO (even students; why fly all the way out there when you're practically standing on a perfectly good Class C?), ... The cost of fuel is considerably cheaper at AJO than at SNA (and many other places in the nation). That's enough to motivate some folks with aircraft with considerable fuel capacity such as the PA28-235 (85 gallons) to fill up at AJO. While you are correct in that fueling at AJO will, in the PA-28's case, save you about $25 (over closer services at FUL, and ~$135 per at SNA), you have to take into account the added wear and tear on the aircraft; AJO is 19nm straightline, and the PA-28 will need something like 0.4 hours roundtrip to fuel at AJO (under perfect, traffic-less conditions and ideal flight path and no winds; don't forget time-on-ground, too). Assuming a TBO of 1500 hours (wild guess, am I ballpark?), You're only off by 33%: Lycoming O-540 TBO = 2,000 hours. you're looking at a savings of ~$43,000; can you overhaul an O-540 with that much money? What will it cost you in oil, tires and time to fly all the way out there and back each time for fuel? Also consider that this is relying on the only available supplier at SNA on AirNav; I'm almost certain there are more FBO's at SNA than one (been a long time). Two. Newport Jet Center, and Signature Flight Support. Consider that LGB is closer than AJO to SNA, and has self-serve fuel just 30 cents more expensive than AJO. Besides, I don't even think there are any good hamburger joints at AJO. The fare at Bob's Chili & Chow Hall is good for dinner food. I'd rate it above Flo's at Chino. I mean really! What's the point? :P Bragging rights about havening purchased the cheapest fuel for $4.10 / gallon instead of $6.01? That's nearly a 33% ($1.91/gallon) savings, or say $143.25 savings for 75 gallons. |
#37
Wow, what are the odds of two Cessnas hitting each other at the same
airport within a ten year peiod? Bad Karma! denny |
#38
#39
In article yWflj.3634$hk4.200@trnddc03,
TheSmokingGnu wrote: Also consider that this is relying on the only available supplier at SNA on AirNav; I'm almost certain there are more FBO's at SNA than one (been a long time). Yup. There are two: Signature and Atlantic Aviation. Current fuel prices for both are about $6.00/gal at the moment. No self serve. OTOH, AJO's fuel price is currently $4.10. Besides, I don't even think there are any good hamburger joints at AJO. WHAT?!? Bob's Chili and Chow Hall is quite possibly one of the best greasy-spoon airport restaurants in the entire LA Basin! You need to get away from your home airport a little more often. We're talkingclassic $100 hamburger fare here folks. -- Dane |
#40
http://www.venturacountystar.com/new...-collision-in/ Investigators seek cause of midair collision in Corona By Greg Risling The Associated Press Tuesday, January 22, 2008 ... There were bodies falling out of the sky," witness Hector Hernandez told KCBS-TV. "One of them crashed into the top of a Ford Mustang, and another one fell not too far behind that one on the parking lot." In one of the car lots, the twisted hull of a plane rested against two vehicles. Witnesses told authorities that one of the planes slammed into the other. One of the aircraft shattered on impact, while the other spiraled to the ground, left mostly intact. Authorities haven't released the planes' origins or destinations. The crash occurred about a mile south of the Corona Municipal Airport, which doesn't have a manned control tower. The crash is the sixth in the area over the past 10 years. ... The Riverside County Coroner's Office identified the dead as Scott Gayle Lawrence, 55, of Cerritos; Paul Luther Carlson, 73, also of Cerritos; Brandon William Johnson, 24, of Costa Mesa; Anthony Joel Guzman, 20, of Hesperia; and Earl Smiddy, 58, of Moreno Valley. Smiddy was crushed in the car dealership. http://www.signonsandiego.com/news/s...escollide.html ... One of the planes was a Cessna 172 registered to William A. Reinke of La Habra, according to aircraft databases. Reached at his home Sunday night, Reinke declined to say who was flying his plane or who might have been on board. The second plane, a Cessna 150, is registered to Air Corona Inc., based in Dover, Del. Many plane owners register their aircraft in Delaware even if they are not based there because of the state's low taxes. |
| Thread Tools | |
| Display Modes | |
| CAlifornia | Maple1 | Aviation Photos | 0 | August 3rd 07 06:04 AM |
| Wierd TFR in Mid California | Flyin'[email protected] | Piloting | 28 | May 26th 07 08:05 PM |
| Wierd TFR in Mid California | kevmor | Piloting | 3 | May 19th 07 06:07 AM |
| FS AS-W20 California | [email protected] | Soaring | 0 | September 14th 06 09:08 AM |
| California corp. | Robert M. Gary | Piloting | 39 | March 7th 04 01:49 AM |
