The rudder waggle signal does not work
Old July 23rd 11, 07:39 AM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
Quote:
Originally Posted by vaughn[_3_] View Post
Blaming the signal for the pilot doing the wrong thing is just like shooting the messenger. It's encumbent on the individual pilots to actually engage their brains and study and review different aspects of operating a sailplane safely.
If you only engage your brain when in the cockpit you are missing out on reviewing your own flight performances and missing the benefits of visualising and mentally rehearsing vital actions before they are needed.
Colin
  #42
Old July 23rd 11, 07:50 AM
Senior Member
Quote:
Originally Posted by View Post
Isn't everyone missing the cause of this accident and ones like it?
Written, Pre-take-off checklist is all that is needed to prevent this
accident from ever happening. It is the most basic of pilot
duties........
The pilot made at least 5 obvious (easily preventable) errors leading
up to the accident.
1. preflight inspection (usually states spoilers/flaps to take off
position)
2. pre take off check list..."spoilers closed and locked"
3. During tow, Left hand should be on, near, behind, spoiler handle to
sense unwanted spoiler opening
4. Situational awareness of poor climb should result in immediate
spoiler check
5. Pilot should be familiar with signals
Pilot should also include "enmergency plan" in take off check
list ....planning for emergencies such as rope break, tow plane wave
off signal, canopy opening, tow plane loss of power, and spoilers
opening (and signal form tow plane)....none of these should cause any
major concern if they happen...If the pilot is properly prepared..
Cookie
Well said
It takes discipline to do all that and some people just don't do discipline well. It won't catch every problem or save everyone but it's better than not following a rigorous and proven procedure.
Airline flying for example is one of the safest forms of transport going and it is highly procedural.
I come from a place where we do CBSIFTCB as checks and the best thing that happened while I spent some years away from soaring was the additiion of E for Eventualities to the end of the checks to review briefly before the launch the 'what ifs'
Colin
  #43
Old July 23rd 11, 11:21 AM posted to rec.aviation.soaring
Default The rudder waggle signal does not work
On Jul 22, 7:39*pm, Darryl Ramm wrote:
On Jul 22, 3:49*pm, "
accident from ever happening. *It is the most basic of pilot
duties........
up to the accident.
position)
spoiler check
Cookie
I appreciate the comment, but broadening the discussion is more a
distraction to this than a help. One way of making sure something
really broken is not fixed is to keep making the problem bigger. Bad
things happen and when they do there needs to be a mechanism,
hopefully a practiced plan of action, to handle them. The causes of
these fatalities is really releasing low/in an a bad position. Fix
that problem and people won't get killed. In may cases (with powerful
enough tow planes) they might just be embarrassed and the glider pilot
ends up having to buy the tow pilot a beer that night because the tow
plane had to struggle to tow them for a while.
We all need the radio and signal procedure chain to work as
effectively as it can possibly do. That includes getting radios
properly installed in gliders and tow planes and properly using them,
tow pilots being trained to think when to most safely to use a radio
and signal followup if needed, and us community of glider pilots to
get our heads out of our collective asses on the broad lack of
proficiency with in-flight signals.
Darryl- Hide quoted text -
- Show quoted text -
You guys are simply amazing....
So far you have "blamed" the accident on
lack of radio
the rudder signal
The lack of good instruction
the topilots' use of the signal
everything to divert responsibility away from the glider pilot and on
to something/someone else
Cookie
  #44
Old July 23rd 11, 11:23 AM posted to rec.aviation.soaring
On Jul 23, 5:21*am, "
duties........
up to the accident.
position)
spoiler check
Cookie
*lack of radio
the rudder signal
Cookie- Hide quoted text -
Just re read.......not powerful enough tow plane is also a problem..
  #45
Old July 23rd 11, 11:33 AM posted to rec.aviation.soaring
There are only two possible in-flight signals initiated by the tow
pilot.....wing rock, rudder waggle...that's it.
I learned these in about lesson two of my training and have remembered
them ever since . I teach these to my students and they seem to have
no trouble remembering. It's not hard.
To me, a visual signal is a far better form of communication than a
radio braodcast.
The visual signal is quick, simple, to the point, obvious, etc....
Somebody already stated the possible "possible problems with relying
on radio"...there are many....
The low tech solution wins out by far!
Cookie
  #46
Old July 23rd 11, 01:26 PM posted to rec.aviation.soaring
T8
On Jul 23, 5:33*am, "
them ever since . * I teach these to my students and they seem to have
no trouble remembering. *It's not hard.
Cookie
Right. And that part of the lesson might start out, "there are two
things the tow plane can signal you about, 1) something's wrong with
the tow plane, 2) something's wrong with your glider...."
This is simple as dirt.
-Evan Ludeman / T8
  #47
Old July 23rd 11, 01:34 PM posted to rec.aviation.soaring
T8
On Jul 22, 10:18*pm, Pat Russell wrote:
The towplane rudder waggle has been directly
responsible for two fatalities!
A typical aviation accident chain of events happens and you conclude
this? Really?
-Evan Ludemn / T8
  #48
Old July 23rd 11, 06:32 PM posted to rec.aviation.soaring
Darryl Ramm
On Jul 23, 2:33*am, "
radio braodcast.
Cookie
The low tech solution is not "winning by far"-it's a blatant failure
and why we are talking about this.
It's great how things should be clear and should work. Except they are
not and don't and people are being repeatedly killed by the same
problem.
Darryl
  #49
Old July 23rd 11, 09:33 PM posted to rec.aviation.soaring
akiley
A few thoughts.
Assuming any human has the potential to panic and become dumb during a
stressful situation, why don't we do what the airlines do? They
practice the emergency over and over until it is muscle memory and
becomes an "abnormal", not an emergency. How? Personally I think
Condor flight simulator can help a lot. After not soaring for a week,
I always use Condor to aerotow with strong crosswinds from various
direction. With full water it is very difficult. I release when I
get in trouble on the ground, and I talk to myself out loud. "No
remaining runway, field to the right, right 180 etc." I do all the
checklists out loud. Condor does a wing rock for release, so that
burned in pretty well. A sim set up with random failures helped me
with my multi rating. After the sim, I was always waiting for that
failure anticipating and expecting it to happen. I wish Condor could
be programmed for failures to help with safety like other home sims
can.
On the radio thing, I find it fairly hard to hear radios in gliders,
and I miss calls too often. Power planes with headsets are
wonderful. I'm considering some kind of headset that works for
soaring. (suggestions appreciated)
Many of us look at accidents and think "I would never do that", but
that's dangerous thinking. You have to train for the time when Mr.
Panic is at the helm. Aaron
  #50
Old July 24th 11, 01:08 AM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
lack of radio
the rudder signal
Cookie[/quote]
Well, at least no one has blamed George Bush for this yet.
Walt
Rudder waggle toad Soaring 33 November 21st 07 06:44 AM
DG Rudder AD - DONE! - Notes from my work ContestID67 Soaring 0 March 30th 06 08:36 PM
CH Rudder pedals, why don't they work wan2fly99 Simulators 2 January 12th 06 01:30 PM
signal splitter Tri-Pacer Home Built 2 November 5th 05 10:47 PM
