Transponders
Old January 26th 04, 12:53 PM
Ben Flewett
Kirk,
We use transponders in a very different way in NZ.
I consider them a pain in the ass but many NZ pilots
would disagree. This is a very big generalisation
but... the pilots that don't mind using transponders
are more focused on flying rather than soaring... if
you know what I mean.
However, as I mentioned in an earlier posting... If
you don't call for a clearance there is a chance your
transponder is not transmitting correctly despite what
it may be telling you. If I am flying in the same
airspace as commercial jets I want to know for sure
that ATC can see me.
For me the single biggest risk to our sport is the
possiblity of a commercial airliner being brought down
by a glider. If this happens gliding will loose -
it will not matter who is at fault.
Ben.
At 15:30 23 January 2004, Kirk Stant wrote:
Ben Flewett wrote in message news:...
There are lots of excellent reasons for not requiring
gliders to carry transponders but this study seems
flimsy. In NZ we often have groups of gliders flying
together whilst using transponders - no problem.
As I see it (and this is for the Western US, and may
not apply in NZ
or the UK, etc) there are really only two reasons for
not carrying a
transponder: No place to put it in the glider (I've
been trying to
figure out where to install one in my LS6 (small panel),
it will take
a complete redo of the panel to squeeze it in; and
cost - as soon as I
win the lottery (or get REALLY scared by an airliner)
I will probably
get one.
The main reasons for not requiring gliders to carry
transponders a
- if airspace is managed well they are not required
in most areas. The real problem is that the groups
that draw the lines on the maps give the commercial
airlines more airspace than is required. For example,
Auckland (NZ) airport has more airspace around it
than
Heathrow.
If you fly away from airliners, or airways, then the
midair risk is
obviously low. I fly right next to the Phoenix Class
B and share
airspace with a lot of traffic. I'm still in Class
E, so a
transponder isn't required and I'm not talking to ATC,
but still it
would be nice to be 'seen' by any TCAS-equipped planes
in the
vicinity, especially when cruising (i.e. invisible)
at high altitude
(cloudbase above 18000' is not uncommon out here).
- as a glider pilot I don?t want to spend my day listening
to commercial pilots talking to ATC all day. I prefer
to have the radio tuned to a gliding frequency or
off.
Same here, and since I'm VFR in Class E airspace, the
only time I talk
to ATC is when I think it may help - like during the
week near a busy
military base. Then I let them know where I am, and
the controllers
have always been very receptive - vectoring the fighters
around me if
necessary. Having a transponder would make it easier
for ATC to track
me, and many fighters could see me as well with their
systems. It
doesn't mean I would have to talk to them more. Is
it different in
NZ? (aside from no fighters - a shame about your A-4s
and MB-339s!)
- most (but not all) controllers don?t understand
how
gliders operate. The glider pilot is often required
to provide training to controllers whilst trying to
fly their glider. I don?t like having to do this?
?no, I am a glider which means I have no engine and
thus I cannot maintain 3000ft?.
Again, just having a transponder doesn't mean you have
to talk to ATC
if VFR, it means ATC will see you and know you are
VFR (squawking
1200) and let other traffic know you are there. If
you do decide to
talk to ATC, it's that much easier for them to locate
you. And the
ATC controller is not controlling you, so it isn't
your concern if he
doesn't understand gliders - it's his, since his responsibility
it to
protect the airplanes that he is 'controlling'; those
on IFR
flightplans in his airspace. Trust me, he will appreciate
any
'training' you can give him! (thinks - invite local
ATC for a glider
ride - many of them are pilots anyway and would jump
at the chance!).
- most glider pilots (including me) are not commercial
pilots and are not practiced at talking to ATC. Controllers
are used to speaking to commercial pilots and often
become frustrated with amateur glider pilots. The
also become frustrated with the unpredictable flight
path of gliders.
C'mon, if stinkpot student Cezzna pilots can do it,
even glider
guiders can learn to speak ATC! Try it, if you step
on your johnson
you can always give your buddy's identification and
turn off the
radio! And at the speeds we go, to ATC we aren't unpredictable,
we
are parked!
Once you agree to put transponders in gliders you
are
obliged to use them and they are a pain in the ass.
If you only give commercial operators the airspace
they need there should be plenty left over for gliders.
How are they a pain in the ass? Put in the extra battery,
turn it on
when you takeoff, turn it off when you land, take out
and charge the
extra battery. Again, this may only apply to the US,
but having a
transponder doesn't mean you have to talk to ATC.
It means that when
you do want ATC to know where you are, they will see
you, and that
some airplanes (those equipped with TCAS or similar
systems) will have
a much better chance of seeing and avoiding you. If
you fly (location
or altitude) where there is little commercial, business,
or military
traffic, a transponder will probably not help much,
since most small
planes don't have a TCAS-like capability.
Just like most safety issues, the is a cost and risk
tradeoff. Some
day (unfortunately, probably due to a bad glider-airliner
midair),
transponders will probably be mandated, probably within
certain
altitudes (say, above 10,000ft within 50 miles of Class
B and C, for
example, with no exceptions). When that happens, we
will have to
solve the problem.
Cheers,
Kirk
Non-radar transponder codes Michael Instrument Flight Rules 16 February 13th 04 02:15 PM
Dual Transponders? Scott Aron Bloom Instrument Flight Rules 17 December 14th 03 06:54 AM
Mode S Transponders - Can ATC tell the difference? Doodybutch Owning 2 August 10th 03 07:21 AM
Transponders, Radios and other avionics procurement questions Corky Scott Home Built 5 July 3rd 03 12:27 AM
