#41
"Tim J" wrote in message . net... Perhaps I am wrong (as so many of you are pointing out) but if I make a descent rate to arrive at a step down higher than published, it seems as though my descent rate has a good chance to not get me to the MDA when the time is up (or distance) and I have to go missed. So eventually I would have to do the dreaded "dive and drive" later anyway. As long as you are at the LAST stepdown fix at the minimium altitude and correct airspeed then what difference does it make what altitudes you crossed the other stepdowns? Mike MU-2 |
#42
"Mike Rapoport" wrote in message nk.net... "Tim J" wrote in message . net... Perhaps I am wrong (as so many of you are pointing out) but if I make a descent rate to arrive at a step down higher than published, it seems as though my descent rate has a good chance to not get me to the MDA when the time is up (or distance) and I have to go missed. So eventually I would have to do the dreaded "dive and drive" later anyway. As long as you are at the LAST stepdown fix at the minimium altitude and correct airspeed then what difference does it make what altitudes you crossed the other stepdowns? Quite -- think of what the word "minimum" means. |
#43
Stan Gosnell me@work wrote
The pilots made an error. Dive and drive is dangerous. So is instrument flying in general. If we all just waited for CAVU, I bet there would be fewer accidents. Tradeoffs are made between safety and cost/utility all the time, and dive and drive is one of them. I'm in no particular hurry to get out of the clouds - at MDA is fine. Why would anyone be in a huge hurry to get out of the clouds? Being in a hurry is almost always dangerous, sometimes fatal. It's not about being in a hurry to get out of the clouds - it's about reaching MDA well before reaching the MAP. In other words - it's not about rate of descent (I couldn't care less about spending an extra couple of minutes in the clouds) but about angle of descent (I don't want to reach MDA only seconds before reaching the MAP). This is simply another one of those areas where the checkride diverges from real life. On the checkride, as long as you reach MDA prior to the MAP, you're good to go. In real life, you actually want to land. When ceilings are close to MDA (or broken such that they are above MDA in places and below in other places) and visibility is limited by haze, mist, and/or rain (especially at night), you're going to need some time to pick the runway out of the murk - especially if the runway environment (such as the beacon) is not correctly depicted on the plate. Otherwise, you're going to be shooting the missed approach not because you didn't break out prior to MDA but because you couldn't find the runway - at all or until it was too late to land on it using normal flight maneuvers. In limited visibility (especially at night) finding the runway is best accomplished while the airplane is in level flight at MDA, and configured and trimmed to fly hands off. To get to that state, it's necessary to descend to MDA expeditiously (dive and drive), power up and level off, and configure the airplane - all before reaching the MAP - so you can devote most of your time to looking out the window. If you must rush something, you're better off rushing the relatively straightforward descent to MDA (flown purely as an instrument maneuver) rather than the more complex visual segment, which often requires at least some reference to instrument for aircraft control and at the same time requires significant 'outside' time to find the runway. Of course CANPA (which is what the industry is moving to) is safer - in the sense that it allows a less competent pilot to fly the approach without putting too much strain on his less-than-stellar skills. The cost is increasing the probability of a missed approach when weather is at or close to mnimums AND requiring additional equipment that the average small airplane lacks. An excellent article on this topic was written by John Deakin, and is available fromm AvWeb he http://www.avweb.com/news/columns/182091-1.html Michael Please do not send email replies to this posting. They are checked only sporadically, and are filtered heavily by Hotmail. If you need to email me, the correct address is crw69dog and the domain name is this old airplane dot com, but remove the numbers and format the address in the usual way. |
#44
#45
nk.net... "Tim J" wrote in message . net... Perhaps I am wrong (as so many of you are pointing out) but if I make a descent rate to arrive at a step down higher than published, it seems as though my descent rate has a good chance to not get me to the MDA when the time is up (or distance) and I have to go missed. So eventually I would have to do the dreaded "dive and drive" later anyway. As long as you are at the LAST stepdown fix at the minimium altitude and correct airspeed then what difference does it make what altitudes you crossed the other stepdowns? Well, that was a given in the theoretical scenario. The smooth descent is calculated to arrive at the last stepdown altitude well before its fix (a couple of miles at least), not to hit it exactly. I'm not trying to avoid that last level-off. Someone did mention unplanned winds, and that has made me rethink the setup a little. Given time to plan in advance, a constant-rate descent, so long as it clears all the minimums, seems to me to be better, and nicer to your passengers. However, factoring in actual wind seems to break the no-math-in-the-cockpit rule. There are now multiple constraints on your chosen descent rate, while "dive and level off" leaves more margin for wind-induced error. -- David Brooks |
#46
"David Brooks" writes:
Well, that was a given in the theoretical scenario. The smooth descent is calculated to arrive at the last stepdown altitude well before its fix (a couple of miles at least), not to hit it exactly. I'm not trying to avoid that last level-off. Instead of imagining a ceiling right at MDA (or 50 feet above, so that you have a chance of seeing the runway), let's take a more realistic example, at least for where I live. MDA is 500 ft AGL and the ceiling is 800 ft AGL with 1.5 SM visibility (fluctuating). You're not going to see the runway at the FAF, five six miles back. Do you descend fast to MDA and then level out for a few miles? All the best, David |
#47
Thank you Michael - you seemed to have been able to state more clearly what
I was trying to say since the start of the thread... "Michael" wrote in message om... Stan Gosnell me@work wrote The pilots made an error. Dive and drive is dangerous. So is instrument flying in general. If we all just waited for CAVU, I bet there would be fewer accidents. Tradeoffs are made between safety and cost/utility all the time, and dive and drive is one of them. I'm in no particular hurry to get out of the clouds - at MDA is fine. Why would anyone be in a huge hurry to get out of the clouds? Being in a hurry is almost always dangerous, sometimes fatal. It's not about being in a hurry to get out of the clouds - it's about reaching MDA well before reaching the MAP. In other words - it's not about rate of descent (I couldn't care less about spending an extra couple of minutes in the clouds) but about angle of descent (I don't want to reach MDA only seconds before reaching the MAP). This is simply another one of those areas where the checkride diverges from real life. On the checkride, as long as you reach MDA prior to the MAP, you're good to go. In real life, you actually want to land. When ceilings are close to MDA (or broken such that they are above MDA in places and below in other places) and visibility is limited by haze, mist, and/or rain (especially at night), you're going to need some time to pick the runway out of the murk - especially if the runway environment (such as the beacon) is not correctly depicted on the plate. Otherwise, you're going to be shooting the missed approach not because you didn't break out prior to MDA but because you couldn't find the runway - at all or until it was too late to land on it using normal flight maneuvers. In limited visibility (especially at night) finding the runway is best accomplished while the airplane is in level flight at MDA, and configured and trimmed to fly hands off. To get to that state, it's necessary to descend to MDA expeditiously (dive and drive), power up and level off, and configure the airplane - all before reaching the MAP - so you can devote most of your time to looking out the window. If you must rush something, you're better off rushing the relatively straightforward descent to MDA (flown purely as an instrument maneuver) rather than the more complex visual segment, which often requires at least some reference to instrument for aircraft control and at the same time requires significant 'outside' time to find the runway. Of course CANPA (which is what the industry is moving to) is safer - in the sense that it allows a less competent pilot to fly the approach without putting too much strain on his less-than-stellar skills. The cost is increasing the probability of a missed approach when weather is at or close to mnimums AND requiring additional equipment that the average small airplane lacks. An excellent article on this topic was written by John Deakin, and is available fromm AvWeb he http://www.avweb.com/news/columns/182091-1.html Michael Please do not send email replies to this posting. They are checked only sporadically, and are filtered heavily by Hotmail. If you need to email me, the correct address is crw69dog and the domain name is this old airplane dot com, but remove the numbers and format the address in the usual way. |
#48
#49
We're talking about different things, I think. The OP was talking about intermediate stepdown fixes, and so was I. IME, a constant descent is safer than diving as quickly as possible to an intermediate altitude, leveling off, and then diving again. I agree you want to be at the MDA before the MAP, but it does no real good to hit an intermediate altitude early. I can certainly agree with that. Even the descent to the MDA isn't something I rush. Rushing to the MDA can mean you see the ground far from the airport, go below the MDA, and then encounter IMC again. That's why VDP's exist. If you descend below MDA prior to reaching the VDP, you have only yourself to blame. If no VDP is charted, it's easy enough to compute based on whatever descent angle you want to fly. I prefer to make a stabilized descent to reach the MDA just before the MAP, and continue the descent to landing. In other words, CANPA. Just out of curiosity, do you normally fly with a copilot? Perhaps one whose major responsibility on the descent is spotting the landing area? Michael |
#50
wrote in message ... I guess the stats and industry/government studies are all wet then. Please post the stats and industry/government studies that show aircraft finding granite or trees at correctly published IAP altitudes. The published altitudes weren't wrong at KBDL when the AAL MD80 hit the trees near the stepdown fix. I assume you're referring to AAL1572. The NTSB determined the probable cause of that accident to be a descent below the MDA prior to having the required runway visual references in sight. The impact with trees occurred about 2.2 miles past the step-down fix. |
| Thread Tools | |
| Display Modes | |
| High Price of Flying Wires? | PWK | Home Built | 34 | October 8th 17 09:24 PM |
| Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! | Bruce A. Frank | Home Built | 1 | July 4th 04 08:28 PM |
| high impedance, low impedance? | JFLEISC | Home Built | 5 | April 11th 04 07:53 AM |
| MT. DIABLO HIGH SCHOOL CONCORD, CA PHOTOS | MT. DIABLO HIGH SCHOOL PHOTOS | Home Built | 1 | October 13th 03 04:35 AM |
| High performance homebuilt in the UK | NigelPocock | Home Built | 0 | August 18th 03 09:35 PM |
