Build your own PowerFLARM!
Old August 18th 10, 03:32 PM posted to rec.aviation.soaring
kirk.stant
Default Build your own PowerFLARM!
On Aug 17, 8:10*pm, Mike Schumann
When you get a PCAS alarm, the aircraft could easily be coming from
behind you or another blind spot. *Or you could have two aircraft at the
same range coming from opposite directions. *All PCAS (and PowerFLARM)
gives you is an alert to start looking. *It doesn't come close to giving
you all the information you need to avoid disaster in certain situations.
A classic example of this was a couple of years ago when I was flying a
K-8 south of Mpls. *Earlier in the day, we saw a couple of C-130s
heading south. *About an hour later, I heard them coming up behind me
(low tech audio PCAS+). *What do I do? *If they saw me and were avoiding
me, a sudden turn could put me in their path.
With ADS-B, I could have seen exactly where they were and reacted
accordingly. *With PCAS, I wouldn't be any better off than with my basic
hearing.
Mike Schumann- Hide quoted text -
- Show quoted text -
I still have to disagree. Using your example, with PCAS you would
have been warned well prior to hearing the C-130s. If the warning
continued to show decreasing range, and possible altitude conflict,
and you could not see the threat aircraft in front, then a turn to
check 6 would put you in a position to see them (hard to miss two
Herks). As far as the concern that a turn will put you in their path,
think of the relative speeds and distances involved. Unless the other
plane is right on top of you, your turn is not going to move you in
space very much, but on the other hand may make you visible to the
other plane and allow normal rules of the road to apply.
Mike, I don't disagree that ADS-B, when fully implemented, will be a
wonderful thing - for GA. I've been using the military version
(JTIDS) for years and love it, but unless the hardware requirements
come down to something reasonable it will take a while to get into
gliders. Flarm, OTOH, is here now, and solves some nasty, glider
specific problems (which ADS-B will probably never do, given the
market). Unlike you, I am comfortable with the level of warning that
PCAS gives me for transponder - equipped threats (especially VFR
traffic that won't see your transponder or be talking to Center). I
also am comfortable staying away from airliners - but I'm not flying
near Minden/Reno. Around Phoenix, I know pretty well where the
heavies are and scan accordingly.
I also think the nature of glider flight makes the chance of a midair
with another glider much higher than that of getting hit by an
airliner or GA plane. My experience in 2500 hours of gliding, all
over the US, supports that view.
Kirk
  #52
Old August 19th 10, 07:39 PM posted to rec.aviation.soaring
Dave Nadler
On Aug 17, 6:56*pm, Darryl Ramm wrote:
... In a PowerFLARM environment with lots of gliders also with
transponders what you want to do is correlate the Flarm ID of a glider
with it's transponder signal (and also extend that to ADS-B as well)
and suppress the PCAS warning for that glider. This in principle is be
easy to do for Mode S. You just have have the Flarm transmitter also
transmit the aircraft's Mode S ICAO ID). With Mode C you are pretty
much out of luck. The Flarm box is only going to be able to guess at
best. And there is the trade off between suppression a duplicate alert
and suppressing a real alert. It is so insurmountable that personally
I'd not bother trying if I was developing the box. And to be clear, I
have no idea what Flarm does inside their PCAS system in PowerFLARM.
Sorry I missed this earlier, to amplify one of Darryl's points...
You can set the aircraft ICAO ID in the FLARM config file,
in which case this is used instead of the distinct FLARM unit ID.
Hope that helps,
Best Regards, Dave
Can I build one of you items? Gig 601XL Builder Home Built 3 December 23rd 06 09:21 AM
Build an RV of ??? William Snow Owning 12 September 8th 06 04:12 AM
Build an RV of ??? Jim Logajan Home Built 1 September 8th 06 04:12 AM
How to build a P-38 ? ? ? Hans-Marc Olsen Home Built 42 December 11th 04 05:06 PM
RV Quick Build build times... [email protected] Home Built 2 December 17th 03 04:29 AM
