#51
"Peter Duniho" wrote in message ... "Mike Rapoport" wrote in message nk.net... I don's see that I've overlooked something relative to the Caravan. The Caravan has a 940hp engine. There is currently no suitable piston engine to power such a large, single engine airplane. It couldn't be anything other than a turbine. As you yourself pointed out, that 940hp engine is derated to 675hp. You don't need a 940hp piston engine to provide the equivalent power, and a 675hp piston engine is not out of the question (for example, the Orenda V8 turbine replacement engines are in that ballpark, if I recall correctly). Large snip. I agree that it is difficult to compare different types of engines apples to apples since the power and specific fuel consumption curves are so different.. I have two airplanes, one turbine and one piston. Both engines are well suited for their applications. In the Helio, power is often set to 15"MP to keep the speed down in turbulent, low altitude mountain flying. A turbine would be horribly inefficient operated like this. In the MU-2, power is set close to the torque or temp limits from takeoff until reaching about 16,000' on the descent. A piston engine operated flat out like this wouldn't last long, particularly at high altitude. Both powerplanes have their place although I think that diesels will eventually replace gasoline piston engines because of their efficiency, long life and simplicity. Mike MU-2 |
#52
#53
... If gasoline hadn't risen to twice the price of Jet-A (at least in parts of Europe) 3 times. At least for avgas. Paul |
#54
... Turbines do suffer from manufacturing defects (if I recall, there was an uncontained failure in the 90's on some rear-engine jet -- 727, DC-9 or something like that -- where the blade failure was due to some metallurgical problem). Sioux City DC10. Paul |
#55
... Turbines do suffer from manufacturing defects http://www.tc.faa.gov/its/cmd/visito...30/turbine.pdf |
#56
Howdy!
In article , Roy Smith wrote: In article , ) wrote: Think of it this way - a model airplane engine can be made to run with 1/20 of a cubic inch (.049 cu inch to even .010 cu inch), but piston engine aircraft became impractical above a few thousand HP. That is the range of practicality for a piston concept. It is certainly possible to build much larger piston engines than that. How about http://www.bath.ac.uk/~ccsshb/12cyl/ But it is a *little bit* impractical as an *aircraft* engine... yours, Michael -- Michael and MJ Houghton | Herveus d'Ormonde and Megan O'Donnelly | White Wolf and the Phoenix Bowie, MD, USA | Tablet and Inkle bands, and other stuff | http://www.radix.net/~herveus/ |
#57
Roy Smith wrote:
It is certainly possible to build much larger piston engines than that. How about http://www.bath.ac.uk/~ccsshb/12cyl/ Ah! I've always wondered how that Antonov 225 Mrija was powered... Stefan |
#58
"Paul Sengupta" wrote in message
... Turbines do suffer from manufacturing defects (if I recall, there was an uncontained failure in the 90's on some rear-engine jet -- 727, DC-9 or something like that -- where the blade failure was due to some metallurgical problem). Sioux City DC10. Not actually the accident I'm thinking of. But yes, that's another example of blade failure (did they eventually determine it was a manufacturing defect, or a maintenance problem?). The accident to which I was referring only involved one or two fatalities, of a passenger or of passengers sitting right next to the engine. Pete |
#59
I believe you are referring to a Delta MD-80/88 that
was taking off from Pensacola. I think there were two killed and a couple of injuries. Mike Pvt/IFT N44979 PA28-181 at RYY Peter Duniho wrote: "Paul Sengupta" wrote in message ... Turbines do suffer from manufacturing defects (if I recall, there was an uncontained failure in the 90's on some rear-engine jet -- 727, DC-9 or something like that -- where the blade failure was due to some metallurgical problem). Sioux City DC10. Not actually the accident I'm thinking of. But yes, that's another example of blade failure (did they eventually determine it was a manufacturing defect, or a maintenance problem?). The accident to which I was referring only involved one or two fatalities, of a passenger or of passengers sitting right next to the engine. Pete |
#60
"Peter Duniho" writes:
Not actually the accident I'm thinking of. But yes, that's another example of blade failure (did they eventually determine it was a manufacturing defect, or a maintenance problem?). The accident to which I was referring only involved one or two fatalities, of a passenger or of passengers sitting right next to the engine. I recall it as well. DC-9, I believe... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
| Thread Tools | |
| Display Modes | |
