PowerFLARM updates and installation notes
Old May 31st 12, 06:07 PM posted to rec.aviation.soaring
Dave Nadler
Default PowerFLARM updates and installation notes
Hi All - I've posted some notes about
PowerFLARM at Mifflin, and encourage
pilots to post their experiences he
http://powerflarm.us/2012/05/powerfl...and-elswehere/
Also, I posted some notes on installations,
including the "Hall of Shame" which you may
find entertaiing. Hopefully this will answer
some of the ~100 emailed questions I have been
unable to personally respond to yet...
http://powerflarm.us/powerflarm-installation-notes/
Hope you find these helpful,
Old May 31st 12, 08:50 PM posted to rec.aviation.soaring
Three Uniform
Good news !!
And good initiative about the "Hall of Shame". It cannot be expected
that everybody has a reasonable understanding of radio wave
propagation. So, the illustrations of "How Not To" are very usefull.
Now the most important question: What about Brick delivery schedule
(for non-contest folks that often fly together in close proximity on
convergence lines) ?
3U
Old May 31st 12, 09:32 PM posted to rec.aviation.soaring
Matt McKrell
On May 31, 2:50*pm, Three Uniform wrote:
Good news !!
3U
It looks to me that we're about 6 weeks or more from delivery. My
vendor
just sent out a note to his customers confirming which display they
were
ordering, but he hasn't asked for the up-front payment yet.
I've got a question. It looks like the top of the glare shield is the
best spot.
However, in my plane (ASW-19) the glare shield ejects with the canopy.
If I ever have to bail out installing the antenna up there will keep
the canopy
from coming loose. Is there some kind of breakaway connector I can
use in the antenna cable? Alternately, is there a rubber duck kind of
antenna I can use instead that would poke through a hole in the glare
shield, like Bill Elliot did in this install: http://www.gliderpilot.org/FlarmInstallation
-- Matt
Old May 31st 12, 10:04 PM posted to rec.aviation.soaring
Tim Taylor
Good news !!
3U
It looks to me that we're about 6 weeks or more from delivery. *My
vendor
were
I've got a question. *It looks like the top of the glare shield is the
best spot.
the canopy
from coming loose. *Is there some kind of breakaway connector I can
use in the antenna cable? *Alternately, is there a rubber duck kind of
shield, like Bill Elliot did in this install:http://www.gliderpilot.org/FlarmInstallation
-- Matt
Matt,
I helped install many different FLARM units at Mifflin. On the AS and
LS planes we would attach the antenna from under the glare screen and
use Velcro or similar so that it would pull loose if you need to
eject. There should be no metal interference under the glare screen
like in a SH, so you can just put the top half of the antenna up
through the screen and have the wire just below. We did this on an
LS-6 and I believe it worked fine. The alternative is to cut a hole
large enough for the entire antenna to come through but still attach
it on the underside so it will pull loose.
Old May 31st 12, 10:26 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Good news !!
3U
vendor
were
best spot.
the canopy
-- Matt
Matt,
I helped install many different FLARM units at Mifflin. *On the AS and
eject. *There should be no metal interference under the glare screen
through the screen and have the wire just below. *We did this on an
LS-6 and I believe it worked fine. *The alternative is to cut a hole
For Schleicher (I'm not familiar with LS gliders), I strongly
recommend supporting the antenna from something other than the glare
shield. I suggest a non-conductive (plastic, G-10, phenolic
laminate...) rail mounted to the canopy/instrument panel supporting
structure below the glare shield, with a hole in the glare shield that
allows positioning the tip of the dipole antenna close to but not
touching the canopy. I did this on my ASW-20 such that I can easily
remove and replace the canopy without disturbing the flarm antenna.
I'd go nuts if I had to mess with that antenna every time I pulled the
canopy off... and even more so if I forgot about the antenna and
damaged something.
-Evan Ludeman / T8
Old May 31st 12, 11:17 PM posted to rec.aviation.soaring
John Cochrane[_2_]
pilots to post their experiences hehttp://powerflarm.us/2012/05/powerfl...fflin-and-elsw...
unable to personally respond to yet...http://powerflarm.us/powerflarm-installation-notes/
You have to admit that the huge honking dipole antenna, coax cable,
and mount, right in the middle of where you want to look on the
glareshield amounts to Chinese torture. Or at least will not make for
any cool industrial design awards.
http://powerflarm.us/wp-content/uplo..._dipole_SH.jpg
I hope to heaven you guys can work out a prettier antenna and
installation.
Old June 1st 12, 01:47 AM posted to rec.aviation.soaring
installation.
Thanks to Dave and PowerFLARM US for the hard work at Perry and Mifflin to improve the PowerFLARM range issue. However I totally agree with John regarding the uglyness and size of the dipole antenna in the above URL. Forgive me for being reckless with my opinion but that installation sucks and is just not acceptable in the middle of one's vision field. My PowerFLARM order is "on hold" until a "no restricted vision" antenna is available. Please, please come up with something better.
Old June 1st 12, 02:21 AM posted to rec.aviation.soaring
Ramy
installation.
I second that. As much as I am advocating for powerflarm, I did not envision having to look through something like that, nor even through 2 rubber duckies that going all the way to the canopy. I sure hope there is less intrusive solution, even if it will reduce the range a little. BTW, I flew with my MRX PCAS antenna horizontally for years from the same reason and there was no noticable reduction in range, but I understand that powerflarm is much more sensitive to antenna installation. I sure hope a clean installation which does not interfere with visibility is available. After all, a powerflarm is no good if it reduces forward visibility.
Ramy
Old June 1st 12, 02:52 AM posted to rec.aviation.soaring
Tim Taylor
installation.
Ramy
I was involved with installing about seven units and all were much
more elegant than what you see on the web page. Mine is installed
about 4" in front on my compass that is on top of the glare screen. I
only see the top 1.5 inches of the antenna which is very small and
narrow. Many others put the bulk below the glare screen with only
the top 1.5 inches showing.
It would be nice to see the antenna have the cable come in from one
end rather than at the middle. Remember what you see so far were done
in a loaned hanger on a rainy day in the midst of a contest. Evan's
is installed below and mine is very unobtrusive in flight.
Old June 1st 12, 03:16 AM posted to rec.aviation.soaring
Evan Ludeman[_4_]
http://powerflarm.us/wp-content/uplo...dipole_SH..jpg
installation.
Ramy
more elegant than what you see on the web page. *Mine is installed
narrow. * Many others put the bulk below the glare screen with only
in a loaned hanger on a rainy day in the midst of a contest. *Evan's
In a Schleicher installation, about 50% of the dipole will be below
the glare shield. What's visible in my case may not be pretty, but I
don't find it distracting or obstructing, any more so than my yaw
string. I'll get some pics next opportunity. This really isn't a big
deal, imo. If you think it might be a big deal, please keep an open
mind until you see a good installation in a cockpit similar to what
ever you fly.
Evan Ludeman / T8
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 26th 12 12:58 AM
If your bored, think about this and notes about Ely, Nv. [email protected] Soaring 15 February 10th 07 12:30 AM
Notes from the RAP pre-OSH party Viperdoc Piloting 2 July 23rd 06 07:24 PM
DG500 AD notes Sailplane Mechanic Soaring 2 August 27th 04 06:35 PM
A few notes from Uvalde Dave Nadler YO Soaring 0 August 13th 04 06:26 PM
