Leaning Procedure for a Carbureted 182
Old June 25th 05, 06:39 PM
Jeffrey
Default Leaning Procedure for a Carbureted 182
Greeting to all;
I own a 1964 Cessna 182 with a Continental O-470-R25 engine. This is
equipped with an E.I. 6 pt EGT gauge. Typical cruise power setting is 20"
manifold pressure 2300 RPM. I seem to have a plug fouling issue.
Can someone please give me the proper leaning procedure for both cruise
flight and ground operations (taxing)?
I'd really appreciate some experienced input. Thanks in advance!
Jeffrey
Old June 25th 05, 06:48 PM
RST Engineering
Are you running 100LL or mogas?
Old June 25th 05, 10:29 PM
Jeffrey
Running with 100LL.
"RST Engineering" wrote in message
Old June 25th 05, 10:51 PM
RST Engineering
Then you will have plug fouling issues with the O-470 for the rest of your
airplane's life.
"Jeffrey" wrote in message
. com...
Running with 100LL.
Old June 26th 05, 12:57 AM
Scott Skylane
airplane's life.
Bulls**t. I've put almost 500 exclusively 100LL hours on my O-470R with
nary a single plug fouled.
Happy Flying!
Scott Skylane
N92054
Old June 26th 05, 01:43 AM
Jeffrey
What's your technique Scott?
"Scott Skylane" wrote in message
your airplane's life.
Happy Flying!
Scott Skylane
N92054
Old June 26th 05, 09:19 AM
Dale
airplane's life.
Same here....around 800 hours and no fouling problems.
Usually leaned on the ground. Leaned at cruise regardless of altitude.
Had an EI engine scanner/monitor with 6 leads EGT/CHT.
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
Old June 25th 05, 07:41 PM
Thomas Borchert
Jeffrey,
Wow! Why so low?
For taxi: lean right after start-up and stabilized RPM very aggresively
until a slight rise in RPM occurs. If you lean any further, the engine
should quit. The RPM rise should be around 25 RPM. If it is higher, have
your idle mixture adjusted. If you advance the throttle for the mag check,
the engine will stumble because it is so lean. That's GOOD because it
reminds you to enrichen again for take-off power. You cannot hurt the
engine by leaning at taxi power.
For flight: Lean whenever the power is below 75 percent. Lean until the
first cylinder peaks (that's not identical with the cylinder having the
highest EGT, it is the first cylinder whose EGT goes down again during
leaning). Then leave the mixture there if the engine runs smoothly or
enrichen until abojut 100 F rich of peak.
Have you read John Deakin's columns on engine management at www.avweb.com?
Thomas Borchert (EDDH)
Old June 25th 05, 07:47 PM
RST Engineering
One reason and one reason only. With anything but a direct headwind, this
will get the fuel consumption down below 10 gallons of $3.50 fuel an hour.
20" and 2200.
"Thomas Borchert" wrote in message
Jeffrey,
Wow! Why so low?
Old June 25th 05, 08:57 PM
Thomas Borchert
RST,
20" and 2200.
If it's any help, I'm paying 7.75. However, your trip time will be much
longer. You'll reach hour-based maintenance intervals sooner, too. Are you
sure you're saving money on this?
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
Leaning for taxi Jim Rosinski Piloting 28 September 12th 04 04:53 AM
Procedure Turn Bravo8500 Instrument Flight Rules 65 April 22nd 04 04:27 AM
Unusual Procedure at DFW Toks Desalu Piloting 9 December 17th 03 06:27 PM
O-320 leaning Roger Long Piloting 5 November 9th 03 12:40 AM
