FAR Part 97: Aircraft Approach Categories - IAS vs Ground Speed
Old July 18th 05, 03:13 AM
Jose
Yes he did.
No he didn't.
Say, is this the five minute argument, or did you want the full half hour?
Jose
Nothing takes longer than a shortcut.
  #52
Old July 18th 05, 06:44 AM
Steven P. McNicoll
"Jose" wrote in message
news
No he didn't.
Of course he did.
This isn't an argument at all.
  #53
Old July 18th 05, 05:44 PM
Everett M. Greene
"Steven P. McNicoll" writes:
"Jose" wrote
No he didn't.
Of course he did.
And with no context, the casual reader has no idea
what the quibbling is about...
  #54
Old July 19th 05, 05:51 PM
Gary Drescher
wrote in message ...
Gary Drescher wrote:
"Steven P. McNicoll" wrote:
You are correct. There is no end to what some flight
instructors will dream up or invent. Everything the FAA
does in the world of charting is predicated on IAS.
Not quite everything. The approach timing table uses ground speed.
More correctly, the Jeppesen timing table states ground speed.
NACO does not.
Whether they state it or not, there's nothing but ground speed that they
*could* be using to calculate the time to traverse the stated distance.
For the best accuracy, it obviously has to be ground speed. But, there is
no
requirement to make the necessary calculations to arrive at ground speed.
A
lot of folks over many years have simply treated the timing table values
as
indicated airspace,
Whatever shortcuts pilots may take, the fact remains that the NACO timing
tables do use GS, just as the Jepp tables do. If wind is negligible and CAS
is close to IAS, then of course IAS closely approximates GS, but it's still
GS that's given in the tables.
on the premise there are a lot more important things to do
in the final approach segment than attempt to make conversions.
But why would you wait until the final approach segment to make the
conversion? I consider it part of the approach-briefing to calculate GS from
IAS and reported wind, and to write down the appropriate time to the MAP.
In recent years, RNAV has all-but-eliminated any need to use the timing
table
in any case.
Even if your RNAV is certified for IFR, I think it's still a good idea to
pre-compute your time to the MAP in case your RNAV fails during the
approach.
--Gary
  #55
Old July 19th 05, 09:54 PM
Harlo Peterson
CAS is close to IAS, then of course IAS closely approximates GS,
Only for sea level airports. You will be off by about 20% landing at a
6000msl airport.
but it's still GS that's given in the tables.
  #56
Old July 19th 05, 10:34 PM
Gary Drescher
"Harlo Peterson" wrote in message
6000msl airport.
Yup, density altitude is a factor too; my flatlander assumptions were
showing. But even at 6000', the discrepancy is less than 10%, not 20%.
Still, you're right that the discrepancy is large enough to matter.
--Gary
  #57
Old July 20th 05, 07:01 PM
Stan Gosnell
20%. Still, you're right that the discrepancy is large enough to
matter.
Not to mention that your assumed GS for the approach will only be a WAG
anyway. The winds on the approach can be greatly different from the
winds at your cruise altitude, and from the reported surface winds.
TERPS gives you enough protection so that it really doesn't matter much
anyway. Using the ARP or the runway in the GPS for the MAP will be much
more precise than timing anyway.
Regards,
Stan
"They that can give up essential liberty to obtain a little temporary
safety deserve neither liberty nor safety." B. Franklin
  #60
Old July 21st 05, 07:20 PM
Dan Malcolm
Mike,
Actually, niether Vbg nor minimum sink is correct in all circumstances. Vbg
will yield the greatest distance by definition, and minimum sink will yield
the greatest time. Which one is the most beneficial? Gotta look at the
circumstances. There is a good discussion at
http://www.auf.asn.au/emergencies/aircraft.html#vbg
Dan Malcolm
ink.net...
I had a primary instructor who insisted that the best speed to use in the
event of an engine failure was the published best glide speed. I said that
it must depend on the wind and pointed out that if there was a headwind
equal to Vbg that any speed over the Vbg was better. I also pointed out
that with a strong tailwind that the minimium sink speed would get more
distance. He continued to insist that Vbg was the speed to use. That was
our last flight.
We all harbor misconceptions but there is no excuse for being too stubborn
to learn.
MU-2
"Mark Hansen" wrote in message
No, Actually, he's not (unfortunately).
Well, he had to get the idea they were ground speeds somewhere. The
timing table is pretty much the only possible source.
His reasoning is that the faster we're moving across the ground,
the faster we'll move outside of the protected area, for example,
on the circling maneuver, and that to use the higher minimums
'just made good common sense'.
However, he's interpreting the rule using this 'common sense'
and claiming that this is what the rule implies.
He made it clear to me that he was talking about the approach category
minimums and not just the time from FAF to MAP (which, of course,
is based on ground speed).
Mark Hansen, PP-ASEL, Instrument Student
Sacramento, CA
This CFII is stupid. Once you start circling the winds change and will
become a headwind at some point.
Ya know ... I mentioned this to him as well. However, I think he's
stuck on the Ground Speed reported by the GPS during the final
approach as being the speed used to determine the approach category...
That's just not what the FARs say.
MU-2
Sacramento, CA
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 11:33 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 04:07 AM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
