#51
Guess we will never know...
Airspace in question is 500-17999 07:15 to 23:30 (local) 7 days a week including holidays. Ramy Yanetz wrote: Maybe the airspace was cold? If so, the pilot should add a comment about it. Ramy wrote in message ups.com... Forget Class A, how about the guy that infringes on restricted airspace and STILL submits the flight on OLC in order to win a major contest!! Pressure differences etc can be explained but ploughing through restricted airspace in this time of GPS is not excusable. Al Stewart Kissel wrote: Before data loggers and the OLC...pilots had no record of how high they flew other then a barograph, and no doubt Class A was getting busted. What irks me is not someone close to Class A...but those that deliberatley violate and then post their flights. This behaviour is bad for our sport on a couple of levels...so I whole-heartedly support Doug and the OLC bunch on keeping an eye on it. We are much to small a group to be nothing but dust-in-the-wind if a glider brings down an airliner. An those flying in busy airspace are to be commended for using transponders... Within reason I think a little self-policing can go a long way, because we as pilots have a much better idea of what is going on then the FAA(for the most part). Flame shield activated. But the pilot community is responsible for reinforcement, and rewarding pilots who break the rules gives negative reinforcement. Aside from the regulatory issues, it is also unsportsmanlike conduct. So, we will remove OLC flight claims that show ovbious violation of Class-A airspace without a reasonable explanation. This is not Orwell's 'Big Brother' it's more like Big Brothers and Big Sisters. I'm with you, Doug, but what is 'obvious'? Sounds like a sticky little detail. Let us know when the SSA/OLC bunch get it figured out, will you? Jack |
#52
Yes he should.
Al Ramy Yanetz wrote: Maybe the airspace was cold? If so, the pilot should add a comment about it. Ramy wrote in message ups.com... Forget Class A, how about the guy that infringes on restricted airspace and STILL submits the flight on OLC in order to win a major contest!! Pressure differences etc can be explained but ploughing through restricted airspace in this time of GPS is not excusable. Al Stewart Kissel wrote: Before data loggers and the OLC...pilots had no record of how high they flew other then a barograph, and no doubt Class A was getting busted. What irks me is not someone close to Class A...but those that deliberatley violate and then post their flights. This behaviour is bad for our sport on a couple of levels...so I whole-heartedly support Doug and the OLC bunch on keeping an eye on it. We are much to small a group to be nothing but dust-in-the-wind if a glider brings down an airliner. An those flying in busy airspace are to be commended for using transponders... Within reason I think a little self-policing can go a long way, because we as pilots have a much better idea of what is going on then the FAA(for the most part). Flame shield activated. But the pilot community is responsible for reinforcement, and rewarding pilots who break the rules gives negative reinforcement. Aside from the regulatory issues, it is also unsportsmanlike conduct. So, we will remove OLC flight claims that show ovbious violation of Class-A airspace without a reasonable explanation. This is not Orwell's 'Big Brother' it's more like Big Brothers and Big Sisters. I'm with you, Doug, but what is 'obvious'? Sounds like a sticky little detail. Let us know when the SSA/OLC bunch get it figured out, will you? Jack |
#53
#54
NOW, BOYS!
Perhaps class A and R has nothing to do with gliders losing use of airspace. See posts about the Minden midair. Nobody badly hurt, that's fantastic! Jim |
#55
Yes, and fortunately the accident apparently did not happen in Class-A
airspace. If something like this did happen in Class-A, the repurcussions could be wide ranging. Even if the glider pilot thinks he's at 17,999' the FDR and ATC tapes are going to be given more weight. So this points out the need to leave some buffer altitude as well. You are not goiing to get the benefit of the doubt. JS wrote: NOW, BOYS! Perhaps class A and R has nothing to do with gliders losing use of airspace. See posts about the Minden midair. Nobody badly hurt, that's fantastic! Jim |
#56
Doug Haluza wrote:
Yes, and fortunately the accident apparently did not happen in Class-A airspace. If something like this did happen in Class-A, the repurcussions could be wide ranging. Even if the glider pilot thinks he's at 17,999' the FDR and ATC tapes are going to be given more weight. So this points out the need to leave some buffer altitude as well. You are not goiing to get the benefit of the doubt. I disagree about the repercussion issue. If a glider was involved in a midair in Class A airspace without appropriate clearance, then the pilot is in clear violation of the FARs, subject to enforcement action (assuming he survives), and there is no need for further rule making. It is precisely this sort of situation, a conflict between aircraft legally present in the same airspace, that sometimes leads to undesirable (from our perspective) changes in airspace classification and rules. What is truly fortunate was that it was not an airliner... Marc |
#57
Marc Ramsey wrote:
It is precisely this sort of situation, a conflict between aircraft legally present in the same airspace, that sometimes leads to undesirable (from our perspective) changes in airspace classification and rules. What is truly fortunate was that it was not an airliner... A couple of years ago, there was a midair over the French alps (possibly the best known (as well as the best) glider area in Europe), between an airliner which approached Lyon (France) and a glider. (I forgot further details.) Luckily, both aircraft landed safely. It was clearly the airliners fault, as the collision occured in airspace class E and the glider had the right of way. Problem was, the airliner pilots thought they were in class D, because the Jeppesen map which they used was wrong. Anyway, before this accident, all airspace over the French alps was class E up to FL195, i.e. freely usable by everyone without a clearance. As a consequence of this accident, it's no more. Stefan |
#59
The date in question was not subject to GPS testing.
http://www.navcen.uscg.gov/gps/gpsno...terference.pdf Al Brian wrote: Have you read the Notam's on GPS accuracy. It is entirely possible the pilot was clear of the Restricted airspace. I have observed GPS to be off by as much as 5 miles when these notams are in effect. Very disconcerting when your GPS says you are at the airport and all you can see is sage brush. Brian wrote: Forget Class A, how about the guy that infringes on restricted airspace and STILL submits the flight on OLC in order to win a major contest!! Pressure differences etc can be explained but ploughing through restricted airspace in this time of GPS is not excusable. Al Stewart Kissel wrote: Before data loggers and the OLC...pilots had no record of how high they flew other then a barograph, and no doubt Class A was getting busted. What irks me is not someone close to Class A...but those that deliberatley violate and then post their flights. This behaviour is bad for our sport on a couple of levels...so I whole-heartedly support Doug and the OLC bunch on keeping an eye on it. We are much to small a group to be nothing but dust-in-the-wind if a glider brings down an airliner. An those flying in busy airspace are to be commended for using transponders... Within reason I think a little self-policing can go a long way, because we as pilots have a much better idea of what is going on then the FAA(for the most part). Flame shield activated. But the pilot community is responsible for reinforcement, and rewarding pilots who break the rules gives negative reinforcement. Aside from the regulatory issues, it is also unsportsmanlike conduct. So, we will remove OLC flight claims that show ovbious violation of Class-A airspace without a reasonable explanation. This is not Orwell's 'Big Brother' it's more like Big Brothers and Big Sisters. I'm with you, Doug, but what is 'obvious'? Sounds like a sticky little detail. Let us know when the SSA/OLC bunch get it figured out, will you? Jack |
#60
The restriction of the airspace in the French Alps has nothing to do with
this accident which happened over the Massif Central (an A319 inbound Montpellier hitting a Grob Twin III). "Stefan" wrote in message ... Marc Ramsey wrote: It is precisely this sort of situation, a conflict between aircraft legally present in the same airspace, that sometimes leads to undesirable (from our perspective) changes in airspace classification and rules. What is truly fortunate was that it was not an airliner... A couple of years ago, there was a midair over the French alps (possibly the best known (as well as the best) glider area in Europe), between an airliner which approached Lyon (France) and a glider. (I forgot further details.) Luckily, both aircraft landed safely. It was clearly the airliners fault, as the collision occured in airspace class E and the glider had the right of way. Problem was, the airliner pilots thought they were in class D, because the Jeppesen map which they used was wrong. Anyway, before this accident, all airspace over the French alps was class E up to FL195, i.e. freely usable by everyone without a clearance. As a consequence of this accident, it's no more. Stefan |
| Thread Tools | |
| Display Modes | |
| Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 05:40 AM |
| terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 10:39 PM |
| Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 03:37 AM |
| Carrying flight gear on the airlines | Peter MacPherson | Piloting | 20 | November 25th 04 01:29 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
