Glider Crash - Minden?
Old September 6th 06, 12:23 AM posted to rec.aviation.soaring
W.J. \(Bill\) Dean \(U.K.\).
Default Mode S Transponders....
news:XygLg.26301$CL6.23010@trnddc06...
W.J. (Bill) Dean (U.K.) wrote:
After two or three days, with his ship not going as well compared with
the others as he expected, he removed it. The difference was immediate
and obvious, he described to me the difference with it fitted as turning
the ASW27 into an ASW20! Remember, he had been flying with the antenna
for some time, it was only in contest against other similar gliders with
good pilots that he saw the difference.
I remain sceptical: I sure didn't see any difference at all when I fitted
a transponder antenna to my ASH 26 E, flying against gliders I'd flown
with for years, nor have I heard of anyone else noticing a difference.
Perhaps something unusual was occurring in his case.
He was flying in a very competitive Nationals (entry of 35) against 11 other
gliders of identical type. Some 5 of the competitors have represented the
UK in Worlds, including one current world champion. See
http://www.cotswoldgliding.co.uk/com...ts/15m2006.htm . The antenna
was fitted on the port side underneath, close to the wheel door. It was
the type with a short wire and a sphere on the end.
Please do not talk as if flying in UK contests involves the same
collision risk with CAT as flying in the high skies around Minden (I have
never done that, alas!).
I won't, and I didn't. My remarks were directed at a Std Cirrus pilot
who felt he needed every crumb of performance, and that was why he
wouldn't consider a transponder. My belief the drag increase is
insignificant, so it shouldn't be a factor in his decision. The need for
it and the cost are the most important factors, I think.
To anyone buying a new modern machine from Schleicher, Schempp or the
others, the cost of fitting a transponder is only a small percentage of
the total cost, but would still involve finding panel space, and
sufficient power (particularly if the transponder is to be on whenever
airborne). But there are still a lot of low value gliders in use in
the UK, and a lot of gliding being done where the actual collision risk
where a transponder would make a difference is very small.
Also the situation in much of the USA. Though, I don't think the value
of the glider should be a factor in the decision to install a transponder.
I realize you are using the glider value as a proxy for the spare cash the
owner has, but I'd rather the focus was on the collision risk, the value
of reducing it, and the cost of installing a transponder.
It is the cost of the instrument, of the cabling and antenna, of the extra
battery power, and of the installation. It is not only the cost in cash,
but also the cost in space needed, and in loss of disposable weight.
It also has to do with how the glider will be flown. Fitting a transponder
would do hardly anything to reduce collision risk for most gliding in the
UK. It will only help those who can and want to fly high in wave. From
the posts I have been reading the situation is quite different in the Minden
area, though even there it seems that the routeing of CAT into and out of
airfields could be improved.
In the USA, I wonder how many of the 1-26 fleet are fitted?
I don't know, but some do have them in the Minden area.
Are you allowed to fly in airways in the UK (as we do in the US), and
would having a transponder give you greater access to them?
For UK ATS Airspace Classifications see
http://www.caa.co.uk/docs/64/ATS_Classifications.pdf , one page.
For the CAA publication "Guide to Visual Flight Rules in the UK" see
http://www.caa.co.uk/docs/64/DAP_ACD_VFR_Guide.pdf 40 pages.
The section "Gliders" is on page 23.
Note that nowhere is there any mention of transponders. In class A and B
airspace the controller will be helped if a transponder is fitted and used,
which is why some UK pilots are carrying them. Obviously a controller is
more likely to help if the glider can squawk.
Note: email address new as of 9/4/2006
"Transponders in Sailplanes" on the Soaring Safety Foundation website
www.soaringsafety.org/prevention/articles.html
"A Guide to Self-launching Sailplane Operation" at www.motorglider.org
W.J. (Bill) Dean (U.K.).
Remove "ic" to reply.
Old September 2nd 06, 12:00 PM posted to rec.aviation.soaring
Derek Copeland
Whether I would be able to mount the aerial internally
or not would depend on the engineer certifying the
installation. I understand that the latest generation
sailplanes with carbon fibre fuselages will have to
have externally mounted aerials, probably top or bottom
so that they will transmit both up tp TCAS equipped
airliners and down to Air Traffic Control. Although
the aerials are quite short, they do produce a significant
amount of drag. Remember that a 500 kg glider with
a 50:1 glide angle will only have a drag of 10 kg at
best glide speed.
I am not a tehnofreak, but I understand that Transponder
aerials have to be base loaded and require a metal
ground plane to work properly. Obviously not a problem
for a spam can or a metal Schweitzer glider, but something
else that has to fitted into the already crowded centre
section of a FRP sailplane.
Derek Copeland
At 01:12 02 September 2006, Eric Greenwell wrote:
Derek Copeland wrote:
Jack,
I know that a UK pilot removed a transponder aerial
from his glider part way through a Nationals competition
because he was losing too much performance in relation
to his competitors in similar gliders. Also I fly
a
Standard Cirrus, so I need all the performance I can
get!
You can't measure the performance loss that a transponder
antenna on
your Std Cirrus, the drag is so little; nonetheless,
the fiberglass
fuselage will let you mount one internally. The big
advantage is it's
protected from ground and handling damage.
Change 'netto' to 'net' to email me directly
www.motorglider.org - Download 'A Guide to Self-launching
Sailplane
Operation'
Old September 2nd 06, 04:46 PM posted to rec.aviation.soaring
Default Transponder antenna drag
best glide speed.
Here is what an aeronautical engineer wrote on our ASH 26 E newsgroup,
responding to the same concern of another owner:
"As a sanity check assume 1/8" by 2" wire (projected area .25 square
inch) with a drag coefficient of 1 (normally a round wire is less) then
drag is (.25/144)*1*60*60/295 = 0.02 lbs at 60 knots or 0.08 lbs at 120
kots. (At 60 knots the flat plate drag is about 12 lbs per square
foot).
Even if the antenna was twice as long or twice as thick we are still
looking
at around .04 pounds at 60 knots or 0.16 lbs at 120 knots."
That's very small compared to 10 kg, and it's at 120 knots!
The ground plane can be as small a 6" in diameter, and internal
antennas have been installed sucessfully in gliders with less room and
tighter access than the Std Cirrus. Drag is not a valid concern for
your situation, but it sounds like you can't/won't afford the
considerable cost.
www.motorglider.org - Download 'A Guide to Self-launching Sailplane
Operation'
Old September 2nd 06, 05:06 PM posted to rec.aviation.soaring
Mike the Strike
..... and it creates a lot less drag than will occur when your wing is
ripped off by a bizjet!
foot).
looking
Old September 5th 06, 10:21 PM posted to rec.aviation.soaring
best glide speed.
foot).
looking
But it is not the drag, but the drag relative to the lift.
NO Antenna
500 kg glider
10 kg drag
L/D = 50.0
Antenna
500.2 kg glider (add antenna weight, liberal guess)
assume shape of antenna is straght wire, no tip (as above)
assume drag is 0.16 lbs = 0.073 kg
assume no interferance drag
L/D = 500.2/10.073 = 49.66
A third of a point loss is significant for those who know how to use it
(I am told).
Fine tune these results with a real antenna and try again.
(Standard Cirrus
330 kg
L/D = 35
9.43 kg drag
L/D w/antenna:
330/(9.43+0.073)=34.73
Noticable if you have done all your gap work, sealing, airfoil tuning,
etc...?)
John Gilbert - Washington State, USA
Std. Cirrus s/n 266
Operation'
Old September 6th 06, 03:12 AM posted to rec.aviation.soaring
Eric Greenwell
best glide speed.
foot).
looking
NO Antenna
500 kg glider
10 kg drag
L/D = 50.0
Antenna
(I am told).
(Standard Cirrus
330 kg
L/D = 35
9.43 kg drag
L/D w/antenna:
etc...?)
The .073kg is at 120 knots, so at 60 knots best L/D, it would be 0.01825
for an L/D of 34.927. At thermalling speeds, where induced drag
dominates, it's insignifcant (one extra bug may cause more loss!), but
perhaps that's a good enough calculation for the UK, where you probably
aren't batting along in a Std Cirrus fast enough to make profile drag
the dominant factor.
Old September 6th 06, 05:21 AM posted to rec.aviation.soaring
Paul Remde
Hi,
If I remember my fluid dynamics courses correctly, spheres and round rods
produce a relatively large amount of drag when compared with teardrop or
flared objects. The low cost "stub" antennas are popular transponder
antennas because of their low cost. However, it is my belief that the more
expensive "shark fin" or "blade" antennas will produce much less drag, even
though they are a bit larger. They also look much nicer on a glider. You
can see examples he
http://www.soarmn.com/cumulus/comant.htm
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
news:2gpLg.4072$%k5.472@trnddc08...
best glide speed.
foot).
looking
NO Antenna
500 kg glider
10 kg drag
L/D = 50.0
Antenna
(I am told).
(Standard Cirrus
330 kg
L/D = 35
9.43 kg drag
L/D w/antenna:
etc...?)
for an L/D of 34.927. At thermalling speeds, where induced drag dominates,
it's insignifcant (one extra bug may cause more loss!), but perhaps that's
a good enough calculation for the UK, where you probably aren't batting
along in a Std Cirrus fast enough to make profile drag the dominant
factor.
Old September 5th 06, 07:20 PM posted to rec.aviation.soaring
Derek Copeland
In the UK we are not allowed to fly Gliders in Class
A or Airways, full stop, period! We can sometimes access
Class B and Class D with an ATC clearance by radio.
The vast majority of gliding is done in Glass G airspace
where we are largely segregated from commercial air
traffic. However the latter are increasingly starting
to use the Class G around the smaller regional airports,
which is probably why the CAA wants the compulsory
fitting of Mode S transponders. The other issue is
the use of the open airspace by UAVs (mostly by the
US Military as far as I can find out). There is no
mandatory requirement for fitting airband radios at
the moment, so I don't expect to get any improved access
to controlled airspace by fitting transponders.
In the US the fitting of transponders appears to be
voluntary, if the owners/pilots consider it necessary
in their local airspace. If the CAA gets its way, Mode
S will be compulsory for all aircraft in the UK, including
low value vintage machine that only occasionally fly,
and even when they do stay local to the airfield. Basically
these beautiful machines will probably have to be placed
in museums or scrapped, which in my opinion would be
a great shame. We currently have a thriving vintage
glider movement in the UK.
The UK is a damp little island with far too much cloud,
often with a very low base. To successfully fly cross-country
you really do need all the glide performance you can
get.
Mode S transponders can only give collision warnings
to ACAS/TCAS equipped aircraft, or via radio messages
from radar equipped ATC. They are virtually useless
for preventing collisions between gliders or GA aircraft.
If we have to fit anything, I would prefer to wait
for ADS-B or some development of FLARM, which is of
general use to all pilots. Transponders are crude,
old fashioned, WW2 technology!
Derek Copeland
At 15:24 05 September 2006, Eric Greenwell wrote:
well compared with the others as he expected, he removed
it. The
difference was immediate and obvious, he described
it fitted as turning the ASW27 into an ASW20! Remember,
he had been flying
with the antenna for some time, it was only in contest
gliders with good pilots that he saw the difference.
I remain skeptical: I sure didn't see any difference
at all when I
fitted a transponder antenna to my ASH 26 E, flying
against gliders I'd
flown with for years, nor have I heard of anyone else
noticing a
difference. Perhaps something unusual was occurring
in his case.
the same collision
(I have never done
that, alas!).
a Std Cirrus pilot
that was why he
increase is
insgnificant, so it shouldn't be a factor in his decision.
The need for
Schempp or the
a small percentage of the
space, and sufficient
whenever airborne). But
in the UK, and a lot of
think the value
install a
transponder. I realize you are using the glider value
as a proxy for the
spare cash the owner has, but I'd rather the focus
risk, the value of reducing it, and the cost of installing
a transponder.
fitted?
do in the US), and
to them?
'Transponders in Sailplanes' on the Soaring Safety
Foundation website
'A Guide to Self-launching Sailplane Operation' at
www.motorglider.org
Old September 6th 06, 11:08 AM posted to rec.aviation.soaring
Rory O'Conor[_1_]
Oh really?
Please read
http://www.scottishglidingcentre.co....20MoU%20BGA%20
2005%20lores.pdf
And then re-comment.
Rory
Newsgroup: rec.aviation.soaring
Subject: Mode S Transponders....
Author: Derek Copeland
Date/Time: 17:20 05 September 2006
In the UK we are not allowed to fly Gliders in Class A or Airways, full
stop, period!
Old September 6th 06, 02:16 PM posted to rec.aviation.soaring
Derek Copeland
OK, OK. So the Jocks have a couple of wave windows
that can be activated in advance by a telephone call
in accordance with a local agreement. We have nothing
like that in Southern England!
I do hope you are not in favour of mandatory Mode S
Transponders in all aircraft (includes gliders, hang
gliders, paragliders and balloons).
Derek Copeland
At 09:12 06 September 2006, Rory O'Conor wrote:
Oh really?
Please read
http://www.scottishglidingcentre.co....space%20MoU%20
BGA%20
2005%20lores.pdf
Rory
A or Airways, full
stop, period!
VQ-1's P4M-1Q crash off China - 1956 Mike Naval Aviation 0 May 7th 06 12:13 AM
Yet another A36 crash H.P. Piloting 10 April 23rd 05 06:58 PM
Seniors Contest Bob Fidler Soaring 68 March 17th 05 04:50 AM
Sport Pilot - School Won't Offer Gary G Piloting 38 February 16th 05 11:41 AM
Announce/USA: FAA Glider Flying Handbook / Bob Wander SoarBooks Soaring 0 August 11th 03 04:55 PM
