Why are headings still magnetic?
Old September 2nd 06, 07:56 PM posted to rec.aviation.piloting
Mxsmanic
Default Why are headings still magnetic?
Like AM radio, magnetic headings are still with us, even though
navigation in general has advanced by leaps and bounds. When will
true headings be used? The magnetic poles are in continuous motion;
the rotational poles are stable.
Eventually, the magnetic poles will move so far that every station and
aircraft everywhere will have to be recalibrated to account for it,
and all charts will have to be changed. And the poles occasionally
reverse, which would also be somewhat of a disaster for
magnetically-based aviation.
Old September 2nd 06, 08:14 PM posted to rec.aviation.piloting
Stefan
Mxsmanic schrieb:
When will true headings be used?
Never, I hope, as it would render the whisky compass as a reliable
navigation aid near to useless.
I'm hoping you fly with the newest maps.
And the poles occasionally reverse,
Occasionally... :-)))
Stefan
Old September 9th 06, 08:54 PM posted to rec.aviation.piloting
John[_2_]
Mxs doesn't fly except in the back of an Airbus or with a computer
monitor/Microsoft flight simulator. Take his remarks in that context.
Stefan
Old September 2nd 06, 08:31 PM posted to rec.aviation.piloting
RST Engineering
" Like AM radio, magnetic headings are still with us, even though
There is one, and ONLY one instrument in the aircraft that does not require
a power source or have a common catastrophic failure mode. The sucker will
work and get you home even after it has poured a few tablespoons of kerosene
all over the instrument panel.
Charts are in constant revision for magnetic pole movement. Runway numbers
are reassigned and painted on a regular basis. We can take a pole reversal
and in a week's time have a method of compensating for it.
Why are you posing these old chestnuts here? Can't you google on past
discussions on the matter(s)?
Old September 2nd 06, 08:32 PM posted to rec.aviation.piloting
Grumman-581[_1_]
On Sat, 2 Sep 2006 11:31:55 -0700, "RST Engineering"
Although after losing the kerosene, it tends to jiggle around a bit
more... Been there, done that...
Old September 2nd 06, 09:05 PM posted to rec.aviation.piloting
Kyle Boatright
"Grumman-581" wrote in message
require
will
kerosene
Lose even more kerosene and it'll stop tracking. Done all of the above...
KB
Old September 2nd 06, 09:11 PM posted to rec.aviation.piloting
RST Engineering
"Kyle Boatright" wrote in message
Only if the turbulence is so bad that it jumps the needle off the pivot.
Otherwise, as stated, it just jiggles around a bit.
Done it more than once.
Old September 2nd 06, 09:30 PM posted to rec.aviation.piloting
Grumman-581[_1_]
On Sat, 2 Sep 2006 15:05:55 -0400, "Kyle Boatright"
Not quite so sure about that on my compass... The best I could tell,
it had lost all of the kerosene by the time I got around to fixing it
*right*... I tried a couple of quick fixes prior to getting a repair
kit for it, but they ended up eventually leaking also...
Old September 2nd 06, 09:09 PM posted to rec.aviation.piloting
Mxsmanic
RST Engineering writes:
I was wondering about that. Seems like the airports around me have
had the same runway numbers for quite a while, but maybe my memory is
poor, or maybe I'm in a lucky position with respect to the magnetic
pole.
If you don't want to answer or participate, you don't have to.
Old September 2nd 06, 09:55 PM posted to rec.aviation.piloting
Thomas Borchert
Mxsmanic,
The direction has to change by up to 10 degrees for a change in
numbering.
Thomas Borchert (EDDH)
terminology questions: turtledeck? cantilever wing? Ric Home Built 2 September 13th 05 10:39 PM
Magnetic reversal Everett M. Greene Instrument Flight Rules 12 April 9th 05 10:40 AM
Dynon EFIS D-10 Magnetic heading Paul Lee Home Built 3 November 15th 04 09:41 PM
Aircraft Magnetic Compass Quilljar Simulators 5 July 11th 04 04:08 PM
Do you use your magnetic compass? Roger Long Piloting 42 May 25th 04 01:08 PM
