About forward slips
Old November 2nd 06, 11:07 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default About forward slips
Ron Wanttaja writes:
Yep. Here's another video that should answer most of the above questions:
http://www.bowersflybaby.com/slip3.wmv
Very cool. Your aircraft must be awash in cameras.
It does make it much more clear.
Considering I designed the Fly Baby MSFS model, it's my fault either way. :-)
If you say so. I don't know how the models are implemented
internally.
Actually, the problem is more the limited throw of the yaw control. The Fly
Baby has a very powerful rudder, but the pedals have a fairly long travel. That
makes it easy to input the precise amount of yaw. On the computer, the stick
only wiggles ~10 degrees left and right. I can run the rudder scalars up on the
MSFS config file, but then the rudder control gets too sensitive for normal
operations. Even a set of rudder pedals (older Thrustmasters) didn't give
enough control throw.
The twist rudder on the throttle is definitely a problem with any
aircraft. But it's better than the keyboard.
Would require some SERIOUS wriggling on a computer control
stick....
All rudder movements are difficult with a twisting joystick.
Old November 2nd 06, 04:22 PM posted to rec.aviation.piloting,rec.aviation.student
No, just one cheap camera installed in different places on different flights.
It's apparent on the longer versions of the video, as while all three weekends I
shot video were sunny, the Saturday when the camera was mounted on the rudder
was fairly hazy and the other two days weren't.
The whole tale is at...
http://www.bowersflybaby.com/pix/video.html
The smell of a decomposing mouse somewhere forward of the firewall Peter R. Owning 23 February 1st 06 04:52 AM
What is a "Forward Skip"? Gary G Piloting 57 January 7th 05 11:09 PM
Dennis Fetters Mini 500 EmailMe Home Built 70 June 21st 04 10:36 PM
B-17 forward guin positions zxcv Military Aviation 13 March 16th 04 01:04 AM
Forward Swept Wings Canuck Bob Home Built 16 October 3rd 03 06:50 PM
