#51
karl gruber wrote: No. You can just get one from tower, JUST lke special VFR. So all towers can issue SVFR and contact approach clearances? |
#52
Jose wrote: Right, they are just not allowed to land if the viz requirements aren't met. Routinely disregarded. Yes, but for 91, it's flight visibility. The pilot can evaluate that. Exactly, routinely disregarded. |
#53
Jim Macklin wrote: Once past the FAF, the pilot becomes the sole authority on the landing since only the pilot can determine flight visibility. An aircraft using an N number can be issued an approach clearance right down to zero-zero. A Tango November or airline call sign will prompt a denial or query about the legal status of the flight. No, it won't. If you want an approach clearance you will get one. The legality is not ATC's problem. |
#54
Steven P. McNicoll wrote: wrote: So did approach control screw up? I'm sure they had the last ATIS report some 70 to 80 minutes old at the time of my request, and the weather was good in that report. If the tower had closed just fifteen minutes earlier approach may have had a weather observation less than 30 minutes old. Well, the tower doesn't issue a new ATIS (on the recording) just before they leave, but I suppose they probably do make a weather report that goes to FSS. I'm not sure if that ends up at the ARTCC or not. But they are not there to issue a special observation after they leave, which is when the fog rolled in. So I'd guess that for this clearance to have been "proper" the weather observers would have to still be there and ready to issue a special regardless of how old the last scheduled observation was. But, from the discussion so far, it appears that such a requirement is not actually spelled out in the regs. Interestingly, both the AIM and the 7110.65 say that a requirement for ATC authorization of a contact approach is that "The reported ground visibility is at least 1 statute mile." But the AIM starts out by saying: "Pilots operating in accordance with an IFR flight plan, provided they are clear of clouds and have at least 1 mile flight visibility and can reasonably expect to continue to the destination airport in those conditions, may request ATC authorization for a contact approach." Well, a reported ground visibility of at leats one statute mile and a flight visibility of at least one statute mile are not mutually exclusive. While ground visibility can be determined quite accurately, flight visibility is just a guess. Yes, but I found it interesting that the AIM specifically says that a pilot may request a contact approach (flight viz 1) in conditions when the controller may not approve it (ground viz 1). I suppose that wording is left over from the days when the controller had more access to weather observations than the pilot? |
#55
Newps wrote: A class C tower could easily do that. Call up about 6 miles out and if there's no traffic I can issue you a clearance as the tower controllers at class C's are approach controllers. However you still have to meet the normal constraints of an IFR clearance. That makes sense with a traditional Class C (dedicated approach control). Is this still the case at facilities like SJC and BUR where the ARTCC is located in another metropolitan area? |
#56
"Steven P. McNicoll" wrote in message oups.com... karl gruber wrote: No. You can just get one from tower, JUST lke special VFR. So all towers can issue SVFR and contact approach clearances? I believe all towers can issue SVFR, and I know for sure that PDX tower can issue a contactapproach. Karl "Curator" |
#57
#59
karl gruber wrote: I believe all towers can issue SVFR, All towers cannot issue SVFR. and I know for sure that PDX tower can issue a contactapproach. How can you tell if a tower is issuing a clearance for an IFR operation or if it is relaying the clearance received from whatever facility has responsibility and authority for IFR operations? |
#60
| Thread Tools | |
| Display Modes | |
| VFR position reporting | Mxsmanic | Piloting | 154 | November 26th 06 05:45 PM |
| OLV GPS 36 approach question | A Lieberma | Instrument Flight Rules | 59 | August 15th 06 01:32 AM |
| Trust those Instruments.... Trust those Instruments..... | A Lieberman | Instrument Flight Rules | 1 | May 2nd 06 04:54 PM |
| Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 03:37 AM |
| "Cleared Straight-In Runway X; Report Y Miles Final" | Jim Cummiskey | Piloting | 86 | August 16th 04 07:23 PM |
