Punctured pressure cabin.
Old January 2nd 04, 08:35 PM
Keith Willshaw
"Emmanuel.Gustin" wrote in message
M. J. Powell wrote:
There is also the risk of bullets bouncing around inside
the plane and doing damage to power lines, fuel systems,
etc. Historically, fire has been the major killer of
aircraft following projectile damage.
The chances of bullets bouncing around is pretty low especially
if low velocity and/or frangible rounds are used. I doubt anyone
has shot down an aircraft larger than a Sopwith Camel using
a pistol
Seems to me that although loss of cabin pressure is serious
concern (IIRC military aircraft were designed to maintain
lower cabin pressure than airliners, to limit the damage
amplification following a hit) but not the most serious one.
The worst problem is the prospect of a gun battle in a cabin
packed with people. Almost every stray bullet is going to
hit someone; even if the sky marshall hits the right man
(or woman) the bullet seems likely to hit others as well.
This is going to require very fine judgment by the sky
marshall. He or she also has to distinguish between a
conventional hijack best dealt with by negotiation (are
sky marshalls trained to conduct hostage-release
negotiations?)
I'm afraid since Sept 11 all hijackings have to be considered
suicide actions and treated accordingly. The hijackers that
day acted as would be expected of conventional hijackers
right up to the last minute.
Keith
Old January 1st 04, 08:20 PM
Mary Shafer
On Wed, 31 Dec 2003 23:06:55 +0000, "M. J. Powell"
There has been a bit of a furore over here concerning the new US
requirement to airlines to supply air marshals when requested. The
concern is mainly over the possible puncture of a pressure cabin.
What do readers think is the result of decompression via a bullet hole?
A little more noise in the cabin, at least near the hole.
Mary
Mary Shafer Retired aerospace research engineer
Old January 2nd 04, 05:06 AM
WaltBJ
When you consider the source of the air for pressurization, LP/HP air
bled from the engines' compressors, and note that just one engine or,
on most transports, the APU as a last resort, can supply enough air
for normal operation of the pressurization system, it becomes obvious
several bullet holes will not materially affect cabin altitude. Note
also that there is constant flow through the pressurization/dump
valves; they will normally never be fully closed. In sum, the valves'
normal open area could be compared to the aggregate area of the bullet
holes so that when the p/d valves do fully close trying to maintain
pressure one could calculate the number of bullet holes they could
compensate for. A nice experiment waiting to be accomplished. BTW keep
your seat belt fastened and carry a nice sharp 6H drafting pencil in
your kit.
Walt BJ
Old January 2nd 04, 06:23 AM
While I try to never say never, I think there's no such
thing...or damned near no such thing at least.
-Gord.
Old January 4th 04, 08:15 PM
Ad absurdum per aspera
Yeah, one is reluctant to say "never" when random violence and complex
systems come together. The obvious counterexample to the
"convertible 737" that landed safely is the DC-10 that didn't do so
after loss of its cargo door.
However, with bullet holes, hopefully we're not talking about
catastrophic failures of large chunks of airplane.[1] And as for air
loss through bullet holes or even a failed window, consider WaltBJ's
calculation in light of the fact that you don't have to maintain
pressure in a holed cabin[2] *indefinitely* -- just long enough to
keep everybody breathing while you divert.
Finally, consider all this in post 9/11 perspective. We now know that
the bad guys' goal might be to destroy a ground target with the
aircraft. If the consequence of doing nothing is the loss of the
aircraft and all souls aboard anyway, PLUS great death or destruction
on the ground, that changes the sorts of risks you are willing to take
in the name of prevention.
If there is an armed marshal on board, you open the door not only for
cases of intermediate severity (e.g., plane crashes but does not
strike its target), but also for the best case -- he stops the bad
guys, maybe if you're lucky one or more of them survive (dead people
are hard to interrogate), and the aircraft makes a safe landing with
all the good guys still in one piece. And it strikes me as a better
than hand-to-hand by unarmed passengers -- which is still Plan B
should the marshal fail.
Hoping the deterrent effect will be enough,
--Joe
[1] I wonder how much of the popular imagination on this subject comes
straight from "Goldfinger," whose eponymous villain (if memory serves)
goes through the shot-out cabin window of a Lockheed Jetstar. I'd have
thought someone of his luxuriant specifications would've self-patched
almost anything short of complete loss of a door, but no. Whereupon
our hero and the lady du jour set some kind of record for egress under
duress. But I digress.
[2] I think a reasonable further assumption is that the amount of ammo
involved is modest. If there are a LOT of bad guys in one plane, or
they have guns of their own and can fort up for an extended shootout,
we have bigger problems than calculating the number of holes you can
poke in an airplane before somebody hits something important that the
flight crew can't settle with switchology.
Old January 4th 04, 10:01 PM
Keith Willshaw
"Ad absurdum per aspera" wrote in message
om...
hole?
The problem here was not the depressurisation but the collapse
of the floor through which control cables were routed. Subsequent
to that incident changes were mandated to prevent such
recurrences.
Not even that long, just long enought to reduce altitude to
10,000 ft or so.
Keith
Old January 5th 04, 07:16 AM
Pete
And one of the "Airplane" disaster movies. George Kennedy describing loss of
a window, or hole in the skin as 'catastrophic'.
Pete
Old January 1st 04, 09:19 PM
N329DF
The notion that the pilots could defend
the cockpit as a kind of fortress seems far too simplistic to me.
Emmanuel Gustin
it is very simple, the pilots have the ULTIMATE control, you cannot fight if
you cannot stand, and it is very hard to stand in a plane being thrown around
the sky, also, it is hard to fight when there is no air in the cabin, there is
another use for the cabin pressurization system, bleed off the pressure, and
everyone goes to sleep.
Matt Gunsch,
A&P,IA,Private Pilot
Riding member of the
2003 world champion drill team
Arizona Precision Motorcycle Drill Team
GWRRA,NRA,GOA
Old January 2nd 04, 03:23 PM
Johnny Bravo
Boeing engineers estimate that a 9-inch diameter hole would be
necessary before the automatic pressurizing equipment of a 767 would
be unable to maintain cabin pressure.
Or roughly 650 holes, each 9mm across. I can't imagine a gunfight
inside an airliner that would end up with 650 holes in the outer skin
of the plane since most of the rounds are going to be fired to the
front or rear. Even so, most of those holes can easily be plugged for
the short duration of the flight to the nearest airport, just put one
of those stupid platic covered "In case of Emergency" cards over them.
That would take care of about 250 of them on a 767, I'm sure the
in-flight magazines would easily take care of 600-700 more. Bubble
gum would be good for another 100 or so. What's that, about 5,000
total rounds fired (assuming 1/3 of them hit a wall and leave a hole)?
An average of 20 per passenger, two whole post-ban clips before the
air pressure of the cabin becomes compromised and requires a decent,
which would be in progress anyway once the flight crew becomes aware
of 5,000 rounds fired inside the plane.
"The most merciful thing in the world, I think, is the inability
of the human mind to correlate all its contents." - H.P. Lovecraft
Old January 2nd 04, 04:35 PM
M. J. Powell
In message , Johnny Bravo
writes
Wow!
M.J.Powell
Attn: Hydraulic experts - oil pressure relief fix? MikeremlaP Home Built 7 November 6th 04 09:34 PM
Attn: Hydraulic experts - oil pressure relief fix? MikeremlaP Home Built 0 November 2nd 04 06:49 PM
Vacuum pressure Peter MacPherson Instrument Flight Rules 1 May 30th 04 05:01 PM
Greatest Altitude without pressure cabin/suit W. D. Allen Sr. Military Aviation 12 July 26th 03 05:42 PM
Pressure Differential in heat Exchangers Bruce A. Frank Home Built 4 July 3rd 03 06:18 AM
