Like AM radio, magnetic headings are still with us, even though
navigation in general has advanced by leaps and bounds. When will true headings be used? The magnetic poles are in continuous motion; the rotational poles are stable. Eventually, the magnetic poles will move so far that every station and aircraft everywhere will have to be recalibrated to account for it, and all charts will have to be changed. And the poles occasionally reverse, which would also be somewhat of a disaster for magnetically-based aviation. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic schrieb:
When will true headings be used? Never, I hope, as it would render the whisky compass as a reliable navigation aid near to useless. Eventually, the magnetic poles will move so far that every station and aircraft everywhere will have to be recalibrated to account for it, and all charts will have to be changed. I'm hoping you fly with the newest maps. And the poles occasionally reverse, Occasionally... :-))) Stefan |
Stefan wrote:
Mxsmanic schrieb: When will true headings be used? Never, I hope, as it would render the whisky compass as a reliable navigation aid near to useless. Eventually, the magnetic poles will move so far that every station and aircraft everywhere will have to be recalibrated to account for it, and all charts will have to be changed. I'm hoping you fly with the newest maps. Mxs doesn't fly except in the back of an Airbus or with a computer monitor/Microsoft flight simulator. Take his remarks in that context. And the poles occasionally reverse, Occasionally... :-))) Stefan |
" Like AM radio, magnetic headings are still with us, even though navigation in general has advanced by leaps and bounds. When will true headings be used? The magnetic poles are in continuous motion; the rotational poles are stable. There is one, and ONLY one instrument in the aircraft that does not require a power source or have a common catastrophic failure mode. The sucker will work and get you home even after it has poured a few tablespoons of kerosene all over the instrument panel. Eventually, the magnetic poles will move so far that every station and aircraft everywhere will have to be recalibrated to account for it, and all charts will have to be changed. And the poles occasionally reverse, which would also be somewhat of a disaster for magnetically-based aviation. Charts are in constant revision for magnetic pole movement. Runway numbers are reassigned and painted on a regular basis. We can take a pole reversal and in a week's time have a method of compensating for it. Why are you posing these old chestnuts here? Can't you google on past discussions on the matter(s)? Jim |
On Sat, 2 Sep 2006 11:31:55 -0700, "RST Engineering"
wrote: There is one, and ONLY one instrument in the aircraft that does not require a power source or have a common catastrophic failure mode. The sucker will work and get you home even after it has poured a few tablespoons of kerosene all over the instrument panel. Although after losing the kerosene, it tends to jiggle around a bit more... Been there, done that... |
"Grumman-581" wrote in message ... On Sat, 2 Sep 2006 11:31:55 -0700, "RST Engineering" wrote: There is one, and ONLY one instrument in the aircraft that does not require a power source or have a common catastrophic failure mode. The sucker will work and get you home even after it has poured a few tablespoons of kerosene all over the instrument panel. Although after losing the kerosene, it tends to jiggle around a bit more... Been there, done that... Lose even more kerosene and it'll stop tracking. Done all of the above... KB |
"Kyle Boatright" wrote in message . .. Although after losing the kerosene, it tends to jiggle around a bit more... Been there, done that... Lose even more kerosene and it'll stop tracking. Done all of the above... Only if the turbulence is so bad that it jumps the needle off the pivot. Otherwise, as stated, it just jiggles around a bit. Done it more than once. Jim |
On Sat, 2 Sep 2006 15:05:55 -0400, "Kyle Boatright"
wrote: Lose even more kerosene and it'll stop tracking. Done all of the above... Not quite so sure about that on my compass... The best I could tell, it had lost all of the kerosene by the time I got around to fixing it *right*... I tried a couple of quick fixes prior to getting a repair kit for it, but they ended up eventually leaking also... |
RST Engineering writes:
Charts are in constant revision for magnetic pole movement. Runway numbers are reassigned and painted on a regular basis. We can take a pole reversal and in a week's time have a method of compensating for it. I was wondering about that. Seems like the airports around me have had the same runway numbers for quite a while, but maybe my memory is poor, or maybe I'm in a lucky position with respect to the magnetic pole. Why are you posing these old chestnuts here? Can't you google on past discussions on the matter(s)? If you don't want to answer or participate, you don't have to. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic,
Seems like the airports around me have had the same runway numbers for quite a while, The direction has to change by up to 10 degrees for a change in numbering. -- Thomas Borchert (EDDH) |
| Thread Tools | |
| Display Modes | |
| terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 10:39 PM |
| Magnetic reversal | Everett M. Greene | Instrument Flight Rules | 12 | April 9th 05 10:40 AM |
| Dynon EFIS D-10 Magnetic heading | Paul Lee | Home Built | 3 | November 15th 04 09:41 PM |
| Aircraft Magnetic Compass | Quilljar | Simulators | 5 | July 11th 04 04:08 PM |
| Do you use your magnetic compass? | Roger Long | Piloting | 42 | May 25th 04 01:08 PM |
