I had an interesting experience the other day. To some degree I was testing
the theory that a local Class-C facility would invariably vector VFR aircraft outside the lateral boundaries of their airspace. I've seen this at a few different airports where I transition through with flight following, but underneath (or overtop) the vertical limits. Basically, about 15 miles east I called up approach at 2500' westbound. I was going to fly underneath the class-C which extends 5-miles from the airport SFC to 5000', and 10-miles out from 3400-5000'. My on-course track would put me about 6 miles from the airport. Sure enough, they issued vectors and told me to stay outside 10 miles from the airport. I replied that I would stay outside the Class-C. They *again* issued me vectors and said to stay outside 10 miles. I reponded, "NXXXX would like to terminate radar services." I never received the "radar service terminated, squawk 1200," so I inquired as to whether or not they acknowledged my request to terminate. The controller replied, "I want you to stay with ME until west of the airport, continue on present heading." To which, I replied, "NXXXX outside the Charlie, 2500, on-course, as I was planning." I thought this particularly aggressive and unnecessary, so I was going to try to find the official regs as far as flight following goes. I'm convinced that's the reason why a lot of VFR pilots never want to talk to ATC unless absolutely necessary. I pretty much use flight following on any cross-country when I'm not IFR, but it aggravates me when they vector VFR traffic when outside (especially above/below) their airspace anyway. -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
: I have never had this in Charlie airspace in my five years of flying.
It's not at all of them, just a few here and there. They do tend to be fairly consistent on it though. : My question is where were you in relationship to the airport? Were you : under an approach or departure path? Where you near an initial approach : fix for IFR traffic? : Seems to me, that you may have been a traffic conflict for the approach : phase of the airport near these fixes (if you were indeed near one) that : ATC had the need to on to you / vector you around the Charlie airspace. As Doc Brown in "Back to the Future" said, "You're just not thinking 4th-dimensionally." Told them I would stay clear the Charlie... no need to get vectored around it IMO. : Naturally,, every airport is different, but my experience with Charlie : airspace has been quite different then yours. Maybe so, but I've flown underneath the Bravo in Chicago at least a dozen times. Now *THEY* have something to worry about, but don't make an issue of it. They'll even provide radar services for you VFR if you don't sound like an idiot on the radio and can communicate quickly and suscinctly enough. The guys working a podunk Charlie shouldn't get themselves worked up over traffic 2 miles and 1000' under their airspace limits. (In their defense though, I know that there are a lot of bumpkin' pilots around here that might have troubles flying within that tolerance). My thoughts are if there is a traffic conflict, than the FAA needs to expand the boundaries of the Charlie to cover it. -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
A Lieberma wrote: My question is where were you in relationship to the airport? Were you under an approach or departure path? Where you near an initial approach fix for IFR traffic? Irrelavant. He was below the class C which puts him well away from traffic at those points. |
Newps wrote in
: Irrelavant. He was below the class C which puts him well away from traffic at those points. Not quite sure I agree with this. Looking back on his post, he was OUTSIDE class C flying straight and level. He didn't give his altitude, but if he was 2000 feet or higher, he could have easily been in an approach fix altitude that is located outside charlie airspace. Case in point around my area. Wouldn't be a good idea to fly around the JAN VOR that is located outside KJAN charlie airspace with is an initial approach fix at 2000 feet for incoming IFR traffic. I'd sure want to be squawking and talking in that area! Could make for a very bad day for the arrival and enroute traffic if one wasn't talking. Allen |
I've had this happen over Milwaukee. Granted, it's a busy class C, but the like to vector me 10 miles out over Lake Michigan, which I do NOT like. |
Paul kgyy wrote:
: I've had this happen over Milwaukee. Granted, it's a busy class C, but : the like to vector me 10 miles out over Lake Michigan, which I do NOT : like. Funny you mention MKE... that's one of the Charlies that *always* does it to me. I generally fly into Capitol (02C) just to the northeast of Waukesha coming from Chicago. Again, I'm generally flying 1000' under their Charlie, about 2-3 miles from the inner SFC veil. *IF* I talk to them, they try to vector me to the west to get outside the lateral boundaries. If they tried to run me over the lake, it would be a definite "unable." -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
to me. I generally fly into Capitol (02C) just to the northeast of Waukesha coming from Chicago. Again, I'm generally flying 1000' under their Charlie, about 2-3 miles from the inner SFC veil. *IF* I talk to them, they try to vector me to the west to get outside the lateral boundaries. If they tried to run me over the lake, it would be a definite "unable." We fly in that area a lot. Coming from the Southwest, MKE will usually not take a hand-off from Rockford Approach, which is always aggravating. If they DO take the hand-off (or if you're able to catch them on your own, they usually won't vector you around if you stay to the south of their airspace. If you head to the north (to Timmerman or Waukesha, for example), they will vector you around as needed, but not excessively, IMHO. If you fly past them along the lake shore, however, they WILL try to send you way out over the lake. I always tell them "unable", and with one exception they have always let me stay in tight to shore. The one exception resulted in being vectored all the way around Class C to the west, which really sucked. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On 10/27/06 13:49, Jay Honeck wrote:
Funny you mention MKE... that's one of the Charlies that *always* does it to me. I generally fly into Capitol (02C) just to the northeast of Waukesha coming from Chicago. Again, I'm generally flying 1000' under their Charlie, about 2-3 miles from the inner SFC veil. *IF* I talk to them, they try to vector me to the west to get outside the lateral boundaries. If they tried to run me over the lake, it would be a definite "unable." We fly in that area a lot. Coming from the Southwest, MKE will usually not take a hand-off from Rockford Approach, which is always aggravating. If they DO take the hand-off (or if you're able to catch them on your own, they usually won't vector you around if you stay to the south of their airspace. If you head to the north (to Timmerman or Waukesha, for example), they will vector you around as needed, but not excessively, IMHO. If you fly past them along the lake shore, however, they WILL try to send you way out over the lake. I always tell them "unable", and with one exception they have always let me stay in tight to shore. The one exception resulted in being vectored all the way around Class C to the west, which really sucked. So was that a punishment for being unable to fly out over the lake? .... I hope not ;-\ -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 07:58 PM |
| Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 05:40 AM |
| terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 10:39 PM |
| Real World Specs for FS 2004 | Paul H. | Simulators | 16 | August 18th 03 10:25 AM |
