Fine example of Tarver Engineering release for service
Old March 2nd 04, 02:33 PM
mah
Tarver Engineering wrote:
The sole reason for using a static port is so the guts can be removed from
the pitot tube, in order to improve reliability. A pitot port produces no
static pressure datum.
Just as an example, when the aircraft is sitting still on the ground -
airspeed = 0. Since the pitot and static ports are in the same state,
doesn't that imply that static pressure is present at the pitot port?
MAH
  #62
Old March 2nd 04, 02:37 PM
mah
Rich Ahrens wrote:
Yes, those static ports are pretty unreliable! :-)
All those moving parts...
Yep, I've got a can of static port grease on the shelf next to my bottle
of horn fluid and the box of muffler bearings.
MAH
  #63
Old March 2nd 04, 06:16 PM
MAH
....and the coil of shoreline, the bottle of propwash and the
paint for the last post?...
-Gord.
  #64
Old March 2nd 04, 06:53 PM
MAH
Sure it's there, but it's there only until the a/c starts to
move. It's then no longer 'static pressure' because it's been
raised by the ram effect of the movement.
That's why you now need a 'static port' to supply the static
pressure to use as a reference. Is it really that difficult to
see?!?
-Gord.
  #65
Old March 2nd 04, 07:36 PM
B2431
MAH
-Gord.
Always good to have about 50 feet of flightline in case something gets loose.
Dan, U.S. Air Force, retired
  #66
Old March 2nd 04, 07:39 PM
B2431
Date: 3/2/2004 11:53 AM Central Standard Time
Message-id:
MAH
see?!?
-Gord.
Should we tell tarver static ports existed before pitot tubes were used in
aircraft?
From my experience most aircraft have static ports separate from the pitot
tube.
  #67
Old March 2nd 04, 08:00 PM
PosterBoy
"B2431" wrote in message
MAH
-Gord.
loose.
Even so, no worries.
Secure it with the skyhook, and give it a turn or two with a left-handed
monkey wrench. Right as rain.
Cheers.
  #68
Old March 2nd 04, 08:53 PM
running with scissors
mah wrote in message ...
MAH
right next to a Splap in an as removed state
  #69
Old March 2nd 04, 11:45 PM
The CO
"mah" wrote in message
Sure, unless:
1) The aircraft is moving
2) The wind is blowing
3) Either 1) or 2)
4) Both 1) and 2)
At that point the pressure is no longer static - so you need a static
port.
IIRC in fact, for an aircraft to be certified for IFR it has to have an
alternate
static source *as well*. Pitot pressure ceases to be equal to static
pressure
once the air is in motion relative to the port.
Whether the air moves on its own or the plane moves
through it is irrelevant.
The CO
MAH
  #70
The CO
"Gord Beaman" wrote in message
ground -
state,
MAH
see?!?
Apparently.
The CO
Fine example of Tarver Engineering release for service running with scissors Instrument Flight Rules 64 March 3rd 04 06:01 AM
Fine example of Tarver Engineering release for service running with scissors Instrument Flight Rules 7 February 28th 04 06:07 PM
To Tarver Engineering fudog50 Military Aviation 2 January 9th 04 08:15 PM
About death threats and other Usenet potpourri :-) Dudley Henriques Military Aviation 4 December 23rd 03 08:16 AM
FS: Aviation History Books Neil Cournoyer Military Aviation 0 August 26th 03 09:32 PM
