Hawker vs. Glider Midair - with photo!
Old August 30th 06, 09:41 PM posted to rec.aviation.piloting
Darkwing
Default Hawker vs. Glider Midair - with photo!
http://www.nevadaappeal.com/article/...0025/-1/REGION
DW
Old August 30th 06, 11:26 PM posted to rec.aviation.piloting
.Blueskies.
"Darkwing" theducksmail"AT"yahoo.com wrote in message ...
: http://www.nevadaappeal.com/article/...0025/-1/REGION
: DW
wow, good thing the glider guy was wearing a parachute...
Old August 30th 06, 11:27 PM posted to rec.aviation.piloting
Kingfish
What is a glider doing up at an oxygen altitude of 16,000ft? Isn't that
a tad close to the Class A?
Old August 30th 06, 11:33 PM posted to rec.aviation.piloting
Stefan
Probably breathing oxygen and enjoying his freedom to fly.
Isn't that a tad close to the Class A?
It's outside of class A.
Stefan
Old August 30th 06, 11:36 PM posted to rec.aviation.piloting
Steven P. McNicoll[_1_]
"Kingfish" wrote in message
Probably sucking oxygen.
So what?
Old August 30th 06, 11:40 PM posted to rec.aviation.piloting
Ron Natalie
Flying. What makes you think gliders can't or shouldn't be that high?
We have a word for tad close to the class A, we call it class E airspace
and it ain't reserved for bizjets.
I'll also give you a clue. Gliders can get authorization and do fly
in class A airspace as well.
What we apparently have here (from preliminary data) is a massive
failure of see-and-avoid on the behalf of both parties.
Old August 30th 06, 11:44 PM posted to rec.aviation.piloting
Stefan
Agreed. But, while no glider pilot I know would insist on his right: The
glider had the right of way.
Stefan
Old August 31st 06, 12:33 AM posted to rec.aviation.piloting
Ron Natalie
Who the hell said anything about right of way here. Both aircraft have
a duty to see and avoid. The category preference only applies to
aircraft converging from other than head on (apply directly to the
forehead). I'm sure the NTSB will give study as to what the actual
tracks were and what the visual vantages were from both ships.
Old August 31st 06, 02:09 AM posted to rec.aviation.piloting
Stefan
The glider had the right of way.
It was meant to be an indirect answer to Kingfish who asked what a
glider did up there.
Stefan
Old August 31st 06, 03:57 AM posted to rec.aviation.piloting,rec.aviatoin.gliding
Larry Dighera
On Wed, 30 Aug 2006 18:33:09 -0400, Ron Natalie
wrote in :
The category preference only applies to aircraft converging from
other than head on (apply directly to the forehead).
That's not what it says he
http://ecfr.gpoaccess.gov/cgi/t/text... .1.3.10.2.4.7
§ 91.113 Right-of-way rules: Except water operations.
(a) Inapplicability. This section does not apply to the operation of
an aircraft on water.
(b) General. When weather conditions permit, regardless of whether an
operation is conducted under instrument flight rules or visual flight
rules, vigilance shall be maintained by each person operating an
aircraft so as to see and avoid other aircraft. When a rule of this
section gives another aircraft the right-of-way, the pilot shall give
way to that aircraft and may not pass over, under, or ahead of it
unless well clear.
(c) In distress. An aircraft in distress has the right-of-way over all
other air traffic.
(d) Converging. When aircraft of the same category are converging at
approximately the same altitude (except head-on, or nearly so), the
aircraft to the other's right has the right-of-way. If the aircraft
are of different categories—
(1) A balloon has the right-of-way over any other category of
aircraft;
(2) A glider has the right-of-way over an airship, powered parachute,
weight-shift-control aircraft, airplane, or rotorcraft.
(3) An airship has the right-of-way over a powered parachute,
However, an aircraft towing or refueling other aircraft has the
right-of-way over all other engine-driven aircraft.
(e) Approaching head-on. When aircraft are approaching each other
head-on, or nearly so, each pilot of each aircraft shall alter course
to the right.
(f) Overtaking. Each aircraft that is being overtaken has the
right-of-way and each pilot of an overtaking aircraft shall alter
course to the right to pass well clear.
(g) Landing. Aircraft, while on final approach to land or while
landing, have the right-of-way over other aircraft in flight or
operating on the surface, except that they shall not take advantage of
this rule to force an aircraft off the runway surface which has
already landed and is attempting to make way for an aircraft on final
approach. When two or more aircraft are approaching an airport for the
purpose of landing, the aircraft at the lower altitude has the
right-of-way, but it shall not take advantage of this rule to cut in
front of another which is on final approach to land or to overtake
that aircraft.
[Doc. No. 18334, 54 FR 34294, Aug. 18, 1989, as amended by Amdt.
91-282, 69 FR 44880, July 27, 2004]
Midair near Minden Fred Soaring 52 September 1st 06 12:41 PM
Cloud Flying Shawn Knickerbocker Soaring 48 August 30th 06 08:21 AM
Refinish a Glider in Europe Jim Culp Soaring 0 November 18th 05 05:00 PM
Bad publicity David Starer Soaring 18 March 8th 04 04:57 PM
Newbie seeking glider purchase advice Ted Wagner Soaring 19 January 2nd 04 08:00 PM
