My Modest Proposal to End Global Warming, Revitalize General Aviation, and End Our Dependence on Foreign Oil
Old October 20th 07, 02:28 AM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.owning,rec.aviation.homebuilt
Edward A. Falk
Default My Modest Proposal to End Global Warming, Revitalize General Aviation, and End Our Dependence on Foreign Oil
In article . com,
Jay Honeck wrote:
Sounds good to me.
Me, too.
I could live quite happily without freeways. In fact, given my 6 mile
(round trip) commute each day, I'm considering an all-electric car as
my next vehicle.
All-electric cars have the problem of limited range. I'm thinking of
a plug-in Prius for my next car. It's an electric car for short trips,
and a hybrid for long ones. With solar panels on the roof to charge it,
it becomes pretty green.
-Ed Falk,
http://thespamdiaries.blogspot.com/
  #72
Old October 20th 07, 02:41 AM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.owning,rec.aviation.homebuilt
Jim Macklin
Billions of Li-ion AA batteries in cars will be a
recycling/disposal nightmare.
We need nuclear powered cars and trucks.
Global warming is only the tip of the iceberg, the whole
solar system is getting hotter. Jupiter has a new Red Spot,
Mars ice caps are receding and the Rovers are getting
considerably more power than was predicted. Even Pluto is
getting hot, up to several degree above absolute zero now.
Maybe we now know why the ancient Egyptians worshiped the
Sun.
"Edward A. Falk" wrote in message
| In article
. com,
| Jay Honeck wrote:
| Sounds good to me.
| Me, too.
given my 6 mile
all-electric car as
| my next vehicle.
thinking of
short trips,
to charge it,
| -Ed Falk,
  #73
Old October 20th 07, 04:06 AM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.owning,rec.aviation.homebuilt
Morgans[_2_]
Unless you park it for a few weeks between uses, solar cells don't come
close to providing enough power to make it a viable charging option.
  #74
Old October 20th 07, 05:25 AM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.owning,rec.aviation.homebuilt
Actually, if you covered the entire area of a Prius with the best
solar cells you can buy and parked it for 8 hours in Tucson in the
middle of summer, you could go a few feet.
1 hp = 746 Watts
Get the available sunlight energy from:
http://rredc.nrel.gov/solar/old_data...tlas/serve.cgi
Really good solar cells are about 20% efficient.
You do the math.
Jim Pennino
Remove .spam.sux to reply.
  #75
Old October 20th 07, 11:24 AM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.owning,rec.aviation.homebuilt
Matt Whiting
Default My Modest Proposal to End Global Warming, Revitalize GeneralAviation, and End Our Dependence on Foreign Oil
Edward A. Falk wrote:
In article . com,
Jay Honeck wrote:
Sounds good to me.
Me, too.
my next vehicle.
Have you researched the process of making solar panels? Things aren't
as "green" as they seem...
Matt
  #76
Old October 20th 07, 12:21 PM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.owning,rec.aviation.homebuilt
Scott[_1_]
What voltage do those cars use? I assume it's more than 12V. If so,
you'll have to series connect several solar panels to match what you
need. And then, if it's an oddball voltage, you'll have to build your
own charge controller to keep from overcharging. And then, does the
battery type used require a constant voltage or constant current to
charge them. If constant current, you will have to build your own
current source. None of this is un-doable, just some dinking around.
If the voltage required is quite high, you will have a fair investment
in solar panels...
In article . com,
Jay Honeck wrote:
Sounds good to me.
Me, too.
my next vehicle.
Scott
http://corbenflyer.tripod.com/
Gotta Fly or Gonna Die
Building RV-4 (Super Slow Build Version)
  #77
Old October 21st 07, 12:52 AM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.owning,rec.aviation.homebuilt
Jim Macklin
The current crop of electric hybrids use about 4,000 AA
Li-ion batteries in series-parallel to get 800-1000 VDC for
the motors.
"Scott" wrote in message
12V. If so,
match what you
to build your
then, does the
current to
your own
dinking around.
fair investment
| in solar panels...
| In article
. com,
| Jay Honeck wrote:
| Sounds good to me.
| Me, too.
given my 6 mile
all-electric car as
| my next vehicle.
I'm thinking of
for short trips,
roof to charge it,
| Scott
  #78
Old October 21st 07, 03:26 AM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.owning,rec.aviation.homebuilt
Jim Stewart
the motors.
The specs I've seen on the Honda Accord hybrid
show 120 NiMH cells giving 144 volts at 6.0 Ah
The Prius also uses NiMH cells, a total of 168
and a peak voltage of 201 volts and 6.5 Ah.
  #79
Old October 21st 07, 08:56 AM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.owning,rec.aviation.homebuilt
Roger (K8RI)
On Fri, 19 Oct 2007 20:41:30 -0500, "Jim Macklin"
Most of the market is still using the older NiMH batteris with far
less capacity than the LI-Ion. But they are on the way.
Roger (K8RI)
My Modest Proposal to End Global Warming, Revitalize General Aviation, and End Our Dependence on Foreign Oil Gene Seibel Piloting 58 November 2nd 07 04:50 AM
My Modest Proposal to End Global Warming, Revitalize General Aviation, and End Our Dependence on Foreign Oil Gene Seibel Owning 63 November 2nd 07 04:50 AM
I have an opinion on global warming! Jim Logajan Piloting 89 April 12th 07 12:56 PM
Aviation Conspiracy: CBS Spotlights Aviation's Effect On Global Warming!!! Free Speaker General Aviation 1 August 3rd 06 07:24 PM
House proposal to restrict general aviation C J Campbell Piloting 20 March 3rd 04 02:37 AM
