1) "The spin is caused primarily by the position of the controls" - True,
but spins can also be cause by external factors. 2) "...Stick in the aft stop is the 'Stall' position" - Not exactly true. It is true only with the wings level. It is possible to fly regularly in a thermal with the stick against the full aft position, as long as there is some angle of bank (15-20 degrees, depending on the aircraft). With the wings level, it will always produce a stall, that's what it is designed to do. Any competent flight instructor can demonstrate this if you're too affraid to try it yourself. 3) "Always fly flatter close to the ground" - Now here is one that REALLY bothers me. This is probably the WORST misconception that insists in lingering around hangar talk, internet talk and in other media with many "experts". It should be replaced with "Always fly coordinated !" or "Fly with the right amount of bank for the turn you want to make". That's the simple, naked, honest truth. Instilling fear of banking close to the ground is one of the worst things you can do to your students. I really hate people who insist on this one. Gliders will not Stall or Spin due to bank angles. They will do so because of angle of attack (pitch) not angle of bank. Since most of us don't have an AOA indicator in our gliders, we use Speed as an easy way to determine it. Therefore, if you're maintaining the correct Speed in the traffic pattern, you can (and SHOULD) bank the glider as appropriate for the turn. ALWAYS. There is no exception. A glider will not Stall/Spin from a coordinated turn with the proper speed. It will do so always from an uncoordinated turn, usually with the Wings close to level in a skidding turn and the stick aft. Remember what I said about Wings level and the stick full aft. Tom Knauff has some excellent material on the subject, published in many different places, internet, SOARING Magazine, articles, etc. |
Arnold,
I agree. It is quite clear, and frightening to be honest, that there are many 'Experienced' people on this site that need to seek remidial spin training immediately. Before they fly again and certainly before they fly with students! The misinformation on this site, particularly on this subject (not to mention others) should be regarded as criminal. Owain |
Arnold Pieper wrote:
Therefore, if you're maintaining the correct Speed in the traffic pattern, you can (and SHOULD) bank the glider as appropriate for the turn. ALWAYS. There is no exception. A glider will not Stall/Spin from a coordinated turn with the proper speed. It will do so always from an uncoordinated turn, usually with the Wings close to level in a skidding turn and the stick aft. Remember what I said about Wings level and the stick full aft. How true! I have NEVER spun unintentionally in many years of practising gliding doing that. Learning how to recover from spin will not save a single life when 99% of accidents are close to the ground, either landing or ridge flying. Learning to fly perfectly coordinated in ALL circumstances will save lifes. Learning to keep speed and not stupidly thermalling at slower speed than necessary will both increase climb rate and save lifes. I can unfortunately say that i have seen instructors learning to fly both too slow and with the rudder inside the turn, on a ridge. This is criminal. The argument was that the aileron produces more drag, that inverse effects suffice to bank the glider and other bull****. I always wondered how the instructor didn't kill himself. When i became more proficient, i discovered i could exploit small lift exactly as efficiently flying a little faster and with correct banking of the glider than he was doing with these dangerous techniques. -- Michel TALON |
Arnold Pieper wrote: 3) "Always fly flatter close to the ground" - Now here is one that REALLY bothers me. This is probably the WORST misconception that insists in lingering around hangar talk, internet talk and in other media with many "experts". It should be replaced with "Always fly coordinated !" or "Fly with the right amount of bank for the turn you want to make". That's the simple, naked, honest truth. Instilling fear of banking close to the ground is one of the worst things you can do to your students. I really hate people who insist on this one. I was actually taught from the beginning to always do well-banked turns to base and final. The instructor explained, and demonstrated how it is much more difficult to stall, or get close to the stall, with a good bank on. Then it may be a different matter if you are _just_ making it back from a cross country and are so low that you might hit the ground with the wingtip. Though I have never been there myself I have heard about people making their final turn "with the rudder" in that situation. I just wonder whether it would help at all, since there'd be quite a penalty in height for the unclean flying involved. (Apart from the fact that there will have been some fairly poor airmanship involved to end up in that situation in the first place.) CV |
Ok, Here is to Mike and CV. Apparently both of you aren't listening.
If you make a turn with just the rudder and the wings level or almost level, in other words, an uncoordinated turn, close to the ground, THAT will be your last turn. If you don't have height abouve the ground enough to perform a coordinated turn, you SHOULD NOT be turning. Here's the bottom-line : THAT level turn with the rudder-only, performed at 10 or 15ft height, is what produces the first part of a Spin and results in gliders hitting the ground with the nose and wingtip first, usually crippling the pilot. My gosh, you guys don't seem to get it, or read enough accident reports. "CV" wrote in message ... Arnold Pieper wrote: 3) "Always fly flatter close to the ground" - Now here is one that REALLY bothers me. This is probably the WORST misconception that insists in lingering around hangar talk, internet talk and in other media with many "experts". It should be replaced with "Always fly coordinated !" or "Fly with the right amount of bank for the turn you want to make". That's the simple, naked, honest truth. Instilling fear of banking close to the ground is one of the worst things you can do to your students. I really hate people who insist on this one. I was actually taught from the beginning to always do well-banked turns to base and final. The instructor explained, and demonstrated how it is much more difficult to stall, or get close to the stall, with a good bank on. Then it may be a different matter if you are _just_ making it back from a cross country and are so low that you might hit the ground with the wingtip. Though I have never been there myself I have heard about people making their final turn "with the rudder" in that situation. I just wonder whether it would help at all, since there'd be quite a penalty in height for the unclean flying involved. (Apart from the fact that there will have been some fairly poor airmanship involved to end up in that situation in the first place.) CV |
On Tue, 27 Jan 2004 19:06:15 UTC, "Arnold Pieper"
wrote: : Ok, Here is to Mike and CV. Apparently both of you aren't listening. : : If you make a turn with just the rudder and the wings level or almost level, : in other words, an uncoordinated turn, close to the ground, THAT will be : your last turn. CV was reporting this as something that other people claim to do. And we all know, from the accident statistics, just how safe competition pilots are, don't we? In |
Arnold Pieper wrote: Ok, Here is to Mike and CV. Apparently both of you aren't listening. Hmmm. Surprising reaction, considering my post mainly supported your views. If you make a turn with just the rudder and the wings level or almost level, in other words, an uncoordinated turn, close to the ground, THAT will be your last turn. If you don't have height abouve the ground enough to perform a coordinated turn, you SHOULD NOT be turning. Here's the bottom-line : THAT level turn with the rudder-only, performed at 10 or 15ft height, is what produces the first part of a Spin and results in gliders hitting the ground with the nose and wingtip first, usually crippling the pilot. My gosh, you guys don't seem to get it, or read enough accident reports. As Ian already pointed out I reported this as something that other people claim to do, and I was in fact questioning it. On the other hand your claim that any uncoordinated flying automatically leads to a spin is just ridiculous. It rather detracts from your credibility and otherwise sensible views. And I must say, in all kindness, that you would benefit by trying not to be so pompous. These discussions are much more interesting and helpful if we can air our views and experiences on an equal footing rather someone dishing out "bottom-lines" and "simple, naked, honest truths" from their preacher's pulpit. Cheers CV |
3) "Always fly flatter close to the ground" - Now here is one that REALLY bothers me. This is probably the WORST misconception that insists in lingering around hangar talk, internet talk and in other media with many "experts". It should be replaced with "Always fly coordinated !" or "Fly with the right amount of bank for the turn you want to make". That's the simple, naked, honest truth. Instilling fear of banking close to the ground is one of the worst things you can do to your students. I really hate people who insist on this one. Gliders will not Stall or Spin due to bank angles. They will do so because of angle of attack (pitch) not angle of bank. Since most of us don't have an AOA indicator in our gliders, we use Speed as an easy way to determine it. OTOH if you do a well banked turn close to the ground and there is a steepish wind gradient, its liable to be the last one you ever do. -- Mike Lindsay |
Mike Lindsay wrote:
OTOH if you do a well banked turn close to the ground and there is a steepish wind gradient, its liable to be the last one you ever do. Lack of speed? I have flewn places with very steep wind gradient and i am still here. Number one assurance against problems is keeping speed, and rather more speed than not enough when there is strong wind. -- Michel TALON |
I know at least one pilot who was saved from serious
injury or death by his ability to quickly recover from an incipient spin at very low altitude (probably below 50 m). I watched it happen. I am probably also in that category myself, having once unintentionally started to spin a LS7 when flying a very turbulent thermal close to a mountainside near Orcierres in the Alps, and being saved by quick recovery action. As we are not perfect, we should try to have two (or more) lines of defence whenever possible: First line of defence: Have sufficient airspeed and fly coordinated when you are low. Second line of defence: Be able to quickly recognise and recover from an incipient spin. Regarding the value of training fully developed spins: I think the main benefits are to (hopefully) eliminate the panic effect in a spin, and also to learn how to avoid overspeeding or overstressing the sailplane in the pull-out phase. The pull-out is normally very different after a fully developed spin vs. after the typical quarter-turn incipient spin. Geir At 10:12 27 January 2004, Michel Talon wrote: Arnold Pieper wrote: Therefore, if you're maintaining the correct Speed in the traffic pattern, you can (and SHOULD) bank the glider as appropriate for the turn. ALWAYS. There is no exception. A glider will not Stall/Spin from a coordinated turn with the proper speed. It will do so always from an uncoordinated turn, usually with the Wings close to level in a skidding turn and the stick aft. Remember what I said about Wings level and the stick full aft. How true! I have NEVER spun unintentionally in many years of practising gliding doing that. Learning how to recover from spin will not save a single life when 99% of accidents are close to the ground, either landing or ridge flying. Learning to fly perfectly coordinated in ALL circumstances will save lifes. Learning to keep speed and not stupidly thermalling at slower speed than necessary will both increase climb rate and save lifes. I can unfortunately say that i have seen instructors learning to fly both too slow and with the rudder inside the turn, on a ridge. This is criminal. The argument was that the aileron produces more drag, that inverse effects suffice to bank the glider and other bull****. I always wondered how the instructor didn't kill himself. When i became more proficient, i discovered i could exploit small lift exactly as efficiently flying a little faster and with correct banking of the glider than he was doing with these dangerous techniques. -- Michel TALON |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Puchaz Spinning thread that might be of interest in light of the recent accident. | Al | Soaring | 134 | February 9th 04 04:44 PM |
| Puch spin in | Mike Borgelt | Soaring | 18 | January 24th 04 10:29 PM |
| Spinning Horizon | Mike Adams | Owning | 8 | December 26th 03 02:35 AM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 02:27 PM |
