1 Fatal ...r.a.h or r.a.p?
Old February 5th 06, 09:50 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Default 1 Fatal ...r.a.h or r.a.p?
Al wrote:
I was tempted once, but the temptation went away with the
altitude...quickly.
I lost an engine on a C210 at about 300 ft, on departure. The thing quit
like someone had pulled the throttle, which turned out to be very close to
reality. In the shock of the moment, I thought about trying a turn, but
decided to plant it off the end of my departure runway(I was 3000' down a
4000' runway), instead. The clearway at the end was level and had no large
trees. I had already cleaned up the departure flaps, was climbing at 80kts,
and the gear doors were just closing when the thing quit. I immediately
selected the gear back down, and was flat amazed at the sink rate that
developed, no power, windmilling, with the gear in transit. At about 20',
still over the runway, I had to hold it off using flaps, to wait for the
gear to finish extending. The main gear came over center in the saddles,
just as I ran out of elevator, we touched down on the mains, and had to hold
the nose gear off long enough for it to extend. I slid onto the numbers at
the far end with the gear pump still running to close the doors, and got it
stopped. The engine lit off, and we taxied back to the tiedown, and
deplaned.
It turns out that this aircraft had recently come out of 100hr., and for
some reason they had the Airquipt(sp?) hose that runs from the air cleaner
to the turbo-charger off. When the mechanic put it back on, he didn't know
what to do with the ends of the metal wire that winds around the inside of
the hose. He bent each wire end into a little "U" shape, and hooked them
together in the middle of the hose. (They should have been placed under the
hose clamp at each end) A couple of hours later, with vibration, the glue
holding the wire failed, and hooked in the middle the wire collapsed like a
slinky, allowing the hose to collapse, shutting off all air to the turbo.
What really amazed me was how fast the altitude and airspeed went away.
When the thing first quit, I would have sworn I could not get down to my
departure runway before going off the end. I was wrong. Wrong by over a
thousand feet.
Al CFIAMI
"kd5sak" wrote in message
m...
"Dave S" wrote in message
link.net...
JJS wrote:
The SQ2000 guy was flying a rotary (mazda derivative) engine that had
what the rotary community believes was an intermittent fuel supply
program and was in flight test at the time. The aircraft had made one
dead-stick due to what the community assumed was a vapor lock. This was a
fairly low altitude turn back and landing on-field but off-runway. After
some re-work on the fuel system he went up again, and on one of the
subsequent flights weeks later lost power very low, and tried to make
another low turn back to the runway. He ended up in trees.
Same tactic killed Wiley Post and Will Rogers. Don't fly myself, but in a
lifetime of reading
I've seen several references to crashes occuring from pilots trying to
turn back to a runway I
I just read (somewhere fairly recently) that Will & Wileys floats were
leaking,took on enough water that ran to the rear on take-off creating
a BAD rear CG, that they couldn't recover from. (sounds reasonable to
me, they could have been getting by with it, draining the floats after
they were airborne each time)
when they had a reasonably flat bit of terrain in front of them. It's been
said that Post knew better, but had the family fortune tied up in the
plane he and Will were traveling in and just let that drive his decision
making. What do some of you actual pilots think?
Harold
KD5SAK
  #82
Old February 5th 06, 10:39 PM posted to rec.aviation.homebuilt
Bryan Martin wrote:
It's a good idea as long as you keep in mind that a turn back actually
requires way more than 180 degrees of turn to complete the "teardrop"
reversal.
Thats if you want to land on the runway. In many cases, simply being
able to return to within the perimeter of the airport is the object.
Landing on the runway you departed from is icing on the cake.
Dave
  #83
Old February 5th 06, 10:39 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
"Vaughn" wrote in message
Aerial tow is hard even when you have an experienced pilot at each
end of
the rope. Take a couple of glider lessons (at a field where they use
aerial tow
for launch) and you will quickly see what I mean. Hint: the glider does
not
willingly follow the tow plane like a trailer follows a car; you gotta fly
it
every second , and it is a learned skill.
Vaughn
As Vaughn mentioned, "it is a learned skill." From the gliders viewpoint it
is a type of formation flying, or wing-matching-tail-chase. The low tow
position (flying below the tow plane's wake) gives a look and feel similar
to the U.S Naval aviation version of air-to-air refueling.
When you tie two aircraft together both are at an increased risk when the
other aircraft has a problem. The tow plane is at a much higher risk than
the glider. The glider getting out of position close to the ground can
easily put the tow plane in a position from which it can not recover. If
the tow plane has a power failure shortly after becoming airborne, again the
glider is less at risk. An experienced pilot flying a glider with 35 to 1
or better glide ratio shouldn't have a problem doing a 180 and landing
down-wind. (I've done it from 250 feet with room to spare.)
HP-14 N990 "6F"
http://www.soaridaho.com
  #84
Old February 5th 06, 10:52 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
--------snip---------
There are two schools of thought on first flights.
Both have merit.
One is to "go for it!". Take off and climb to altitude where you can
become
safely aquatinted with her "personality" safely.
The other is to make several short hops down the runway to get the feel
first.
The latter, at first, scared the dickens out of me - just on principle.
Going from low and slow lift off to low and slow landing *seemed* like a
bad
idea. But in the end, I've come to think this is safer than I originally
thought, and had become my standard approach to testing a new plane.
I like it because 1) we are low and slow and if anything does go wrong, at
least we are low and slow. And 2) we are expecting to "abort" the take off
soon after lift off. We will not have the danger of the engine possibly
quitting on climb out, and the attendant difficulties that presents.
And 3!) it let's you skip the first flight! When you finally are
comfortable
with the plane and take it around the pattern for the first time, it's
really
not the first flight! (how 'bout that for a plan!)
And, frankly, this turned out not to be the pilot challenge that I first
thought it would be. Although YMMV?
Personally, I agree and plan to use the aborted take-off method as well.
Actually, the plan has had many well known and respected advocates--IIRC,
Molt Taylor was among them.
Also, if the plan is to test a "custom built", or if there is any other
reason to question the weight and balance envelope, I plan to first test a
thrown model--prior to investing time in actual construction of a "real"
airplane. I would first re-read all of part 23 to glean any insight to
accumulated experience in defining the balance envelope. (I know, I really
have no intention to follow everything in part 23 either--for example, there
are specifications for the undercarriage and/or prop clearance that I may
find inappropriate for my application--experimental really is where we plow
the new ground!) Next, would construct a model of the wing only (with
dihedral, and a handle) and throw it with various weights and CG positions.
An excessive variation of airspeed and altitude due to fugoid oscillation,
as subjectively observed, would initially define the "natural" aft CG limit
of the wing by itself. The forward limit would be even more subjective--but
the basic objective of initial testing with something safe, light, simple,
and cheap should be fairly obvious. That should give some indication
whether the design actually has promise. If so, I would add a stick
fuselage and an empennage, and continue my subjective testing. If
satisfied, I could proceed with the main project; otherwise it might be time
to change the design and/or seek assistance.
The reason for this treatise is that I believe a lot really can be gained
from unmanned testing, and that it can be accomplished inexpensively and
with negligible risk of collateral damage.
However, (warning ... warning) the above applied only to conventional
aircraft, and even then does not address the required size of tail surfaces.
I am still looking for a "cheap and dirty" way to accept or reject a design
with regard to the tail's contribution to pitch and yaw stability. Also, I
also have NO intention of designing or building a canard aircraft because I
don't feel that I understand their principals well enough!
Peter
  #85
Old February 5th 06, 10:55 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Thanks for the link, Marc..
For the record I will state that my post regarding this was
unresearched, and from memory alone. I am actually thankful for the time
and work that the rotary community put into investigating his accident.
Dave
  #86
Old February 5th 06, 11:28 PM posted to rec.aviation.homebuilt
ink.net...
reversal.
Dave
Bryan,
You must also keep in mind that the turn radius of a 45 degree bank at 50
kts is only 250 feet. If there is any cross wind and you make your turn
into the wind the effective radius is even less. A five knot cross wind
will cause an aircraft to drift 500 in about one minute. Turning into the
wind is critical to performing the maneuver successfully.
HP-14 N990 "6F"
http://www.soaridaho.com/Schreder/HP-14/N990/N990.html
  #87
Old February 6th 06, 02:22 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
www.X-plane.com
Also, I
because I
Other than making sure that the "elevator" stalls before the main wing
the principals are the same. The final pitch/yaw stability derivative
doesn't care if the numbers came from a canard, a conventional plane ,
or a flying wing.
IMHO the stall resistance of a canard doesn't offset it's other
disadvantages so your not going to miss too much.
Leon McAtee
Quickie builder ........... former Q-2 builder
  #88
Old February 6th 06, 06:29 AM posted to rec.aviation.homebuilt
On Sun, 5 Feb 2006 10:12:53 -0600, "Tater Schuld"
"J.Kahn" wrote in message
For powerplanes, it would be prudent to go to a safe altitude and practice
180s upon chopping power and noting the altitude loss with optimum
You need to do more than reverse direction. You need to get back on
the original centerline. Me? I'll take anything big enough and flat
enough, otherwise I'll take what's there.
technique (although it's murder on the poor cylinders, best to use a
renter...). The least loss is with a hard 45 deg banked turn. If with
some practice you can confidently complete a 180 with say a 400 ft
So you aren't going to try for the runway you just left which is
pretty much the equivalent of a 270. A 180 might get you to the
airport if it's big enough.
altitude loss you can set a defined go-nogo limit of say 500 ft for
turnbacks and you've removed the guesswork from it.
I dont know. doing this at altitude makes the manuver safe, and learning to
perfect it that way can give the pilot overconfidence.
best to make sure your'e never in the situation that call for such a
The only way to do that is to never get in an airplane. Here we only
have one runway out of four that really gives you an out and even then
you are looking at merging with express way traffic, IF you can make
it over, or under the over pass.
manuver, and take the taime to make sur the plane works rather than building
confidence that you can do what others haven't
Engines quit, even new ones. Some times they give warning and a lot
of times they don't. Mine quit on take off with no warning, not even
a hiccup. It went from full power to silence all of a sudden.
www.rogerhalstead.com
  #89
Old February 6th 06, 06:35 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
You bet.
...... I am actually thankful for the time and work that the rotary
Just for the record, the "rotary community" didn't contribute to the
independent investigation - it was the "canard community" that did the
work and wrote up the report.
And we appreciate the thanks.
Marc J. Zeitlin
http://www.cozybuilders.org/
Copyright (c) 2006
  #90
Old February 6th 06, 02:24 PM posted to rec.aviation.homebuilt
But how many aircraft will continue flying at 50 kts in a 45 degree
bank? Not many, I'd wager...
Mark Hickey
Lancaster California: Another Fatal Cirrus Crash Larry Dighera Piloting 63 March 31st 06 10:34 AM
1 Fatal ...r.a.h or r.a.p? Montblack Piloting 81 February 12th 06 09:54 AM
1 Fatal ...r.a.h or r.a.p? Montblack Piloting 38 February 9th 06 03:00 PM
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Piloting 25 September 11th 03 02:27 PM
