Engine pre heater identification
Old November 2nd 07, 07:25 PM posted to rec.aviation.owning
nick name
Default Engine pre heater identification
The logbooks for our newly purchased A36 Bonanza has an entry "E2 Heat
Engine Heater" installed. No other documentation on this AC powered
heater (attached to oil sump) appears anywhere. Any ideas on who the
manufacturer is? I want to get an owners manual and specs (e.g.
current draw). Any help is appreciated.
Old November 2nd 07, 07:31 PM posted to rec.aviation.owning
Steven P. McNicoll
"nick name" wrote in message
Not E2, EZ, as in "easy".
http://www.e-zheat.com/specs.htm
Old November 2nd 07, 11:44 PM posted to rec.aviation.owning
Newps
You can't get a mirror and see the pad? There's nowhere on there that
says how many watts it is? Most of the heating pads on aircraft are
bought at the Farm and Ranch store, that's where I got mine and
everybody around here does the same thing. Why spend $200 when a $35
one works the same?
Old November 3rd 07, 04:59 PM posted to rec.aviation.owning
David Lesher
Newps writes:
one works the same?
You can buy a Kill-o-Watt for $25 or so; it will tell you how much
power it's using. Then you can measure everything else in your house
to find the energy hogs..
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Cherokee Heater Controls? Bob Chilcoat Owning 1 July 9th 06 03:50 PM
Heater Smell O. Sami Saydjari Owning 4 May 1st 05 04:21 AM
Heater problem fixed! Jim Burns Owning 14 December 17th 04 10:38 PM
Aztec heater update Jim Burns Owning 0 November 27th 04 03:28 PM
Tanis Pre-heater with Engine Analyzer O. Sami Saydjari Owning 12 January 29th 04 12:50 PM
