New Oudie Photos
Old April 20th 10, 06:06 AM posted to rec.aviation.soaring
Paul Remde
Default New Oudie Photos
Hi,
I just took a bunch of photos of the new Naviter Oudie and all the included
accessories. I also show photos of an optional modification to the Oudie's
cradle which allows it to work well with a RAM cradle or GNeck2 gooseneck.
Below are links to the updated pages.
I now have Oudie units in stock that have not been sold yet. They are
selling incredibly fast. It is a great product. I love the hardware and
the new software features.
Of course, Goddard cables will be available very soon for connecting the
Oudie to a wide variety of soaring instruments.
http://www.cumulus-soaring.com/pdagps.htm#Oudie
http://www.cumulus-soaring.com/seeyou.htm#Naviter-Oudie
http://www.cumulus-soaring.com/seeyo...e-Modification
http://www.cumulus-soaring.com/flightrecorders.htm
http://www.cumulus-soaring.com/flightcomputers.htm
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
Old April 29th 10, 03:58 PM posted to rec.aviation.soaring
John Scott[_3_]
I measured the ball on the suction cup base. It is 16mm or 5/8".
McMaster-Carr sells a variety of 5/8" plastic balls, but they come in packs
of 25 or more and I didn't have much use for the extra 23-24 pieces, I
looked locally.
I was able to find 5/8" wood balls at Hobby-Lobby and Michaels for a couple
of dollars They fit well into the socket on the back of the Oudie cradle.
They are an alternative to modifying the cradle that comes with the Oudie,
allowing a ball to be put on the end of whatever arm you currently use. The
pieces at Hobby lobby have the ball on the end of a 5/8" cylinder making
them particularly easy to mount. Painted black, no-one will know they are
wood.
John
Old April 30th 10, 01:16 PM posted to rec.aviation.soaring
NG[_2_]
Another option is to use the RAM 9/16 ball (or any other similar
product), dipped twice into liquid plastic made for tool handles, and
allowed to dry thoroughly. RAM makes a two-ended 9/16 ball piece, and
also separate threaded 1/4-20 balls so you can mix and match sizes. I
just tried this last night, works like a charm.
NG
Old April 30th 10, 05:17 PM posted to rec.aviation.soaring
Richard[_9_]
allowed to dry thoroughly. *RAM makes a two-ended 9/16 ball piece, and
also separate threaded 1/4-20 balls so you can mix and match sizes. *I
NG
If you purchase the Oudie & a ram arm from Craggy Aero the cradle
modification is free and a tilt swivel is include with the Ram Arm.
This allows you to tilt the Oudie easily without loosening the arm.
A small tilt take the glare away.
http://www.craggyaero.com/oudie.htm
Richard
www.craggyaero.com
Naviter Oudie Units Shipping Soon Paul Remde Soaring 5 April 7th 10 03:05 PM
Naviter Oudie Should be Available in April 2010 Richard[_9_] Soaring 15 February 6th 10 11:40 PM
PHOTOS: ARCHIVE PHOTOS - Posted July 13, 2009 Hormel Canned Meat Aviation Photos 1 July 14th 09 12:44 AM
HMS Warrior - 1950s Flightdeck Photos [7 photos, 'bout 350kb) Andrew[_5_] Aviation Photos 13 August 13th 08 05:36 PM
