How do aircraft manufactures determine the maximum gross weight for a
given plane? I know I've come across articles that mention on a cool day you can go over the max. gross weight by a percentage, I think 20% was thrown out there but not sure. Then again, on a hot day you might not get any where near that. Is it determined by a standard temp? |
Chris wrote: How do aircraft manufactures determine the maximum gross weight for a given plane? The prototype is fitted with a water bladder and is flown in formation with a tanker. The bladder is slowly filled with water until the plane drops out of the sky. A gauge in the tanker indicates the max gross weight of the new design. -- Ben Jackson http://www.ben.com/ |
ROFLMFAO
very funny indeed BT "Ben Jackson" wrote in message news:8xq6d.171917$3l3.101172@attbi_s03... In article , Chris wrote: How do aircraft manufactures determine the maximum gross weight for a given plane? The prototype is fitted with a water bladder and is flown in formation with a tanker. The bladder is slowly filled with water until the plane drops out of the sky. A gauge in the tanker indicates the max gross weight of the new design. -- Ben Jackson http://www.ben.com/ |
"Ben Jackson" The prototype is fitted with a water bladder and is flown in formation with a tanker. The bladder is slowly filled with water until the plane drops out of the sky. A gauge in the tanker indicates the max gross weight of the new design. How would you like to be the lucky pilot during "water test" ...#2? http://www.theknownuniverse.com/comet.htm (bottom half of the piece) The Ministry of Civil Aviation decided upon a unique test to find out. They built a tank large enough to hold one of the grounded Comets. The wings protruded from water-tight slots in the sides of the tank. Then the tank and cabin were flooded with water. The water pressure inside the cabin would be raised to eight and a quarter pounds per square inch to simulate the pressure encountered by a Comet at 35,000 feet. It would be held there for three minutes and then lowered while the wings were moved up and down by hydraulic jacks. The hydraulic jacks would simulate the flexing that naturally occurs in aircraft wings during flight. This process continued non-stop, 24 hours a day. Montblack |
"Chris" wrote in message ... I know I've come across articles that mention on a cool day you can go over the max. gross weight by a percentage, I think 20% was thrown out there but not sure. You should NEVER go over max GW.. that is a limit, not a buffer zone. The aircraft may be able to support the extra weight on a smooth day.. but not in turbulence, and when the accident investigation computes your actual GW and finds a "causal factor in the accident is exceeding the Max GW allowed".. your insurance company may find your policy invalid. BT |
"your insurance company may find your policy invalid"
bull "BTIZ" wrote in message news:uYq6d.114$mS1.39@fed1read05... "Chris" wrote in message ... I know I've come across articles that mention on a cool day you can go over the max. gross weight by a percentage, I think 20% was thrown out there but not sure. You should NEVER go over max GW.. that is a limit, not a buffer zone. The aircraft may be able to support the extra weight on a smooth day.. but not in turbulence, and when the accident investigation computes your actual GW and finds a "causal factor in the accident is exceeding the Max GW allowed".. your insurance company may find your policy invalid. BT |
Isn't there a 15% tolerance allowed for certain types of flights in Alaska?
-- Jim Carter "BTIZ" wrote in message news:uYq6d.114$mS1.39@fed1read05... "Chris" wrote in message ... I know I've come across articles that mention on a cool day you can go over the max. gross weight by a percentage, I think 20% was thrown out there but not sure. You should NEVER go over max GW.. that is a limit, not a buffer zone. The aircraft may be able to support the extra weight on a smooth day.. but not in turbulence, and when the accident investigation computes your actual GW and finds a "causal factor in the accident is exceeding the Max GW allowed".. your insurance company may find your policy invalid. BT |
"Jim Carter" wrote: Isn't there a 15% tolerance allowed for certain types of flights in Alaska? Part 135 only. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
"Dale" wrote in message ... In article , "Jim Carter" wrote: Isn't there a 15% tolerance allowed for certain types of flights in Alaska? Part 135 only. And even then it's not just an "automatic" increase. |
Thanks, its been many years since I flew out of Boeing Field and up the
coast, so I wasn't sure that kind of thing was still allowed up there. -- Jim Carter "Ron Natalie" wrote in message m... "Dale" wrote in message ... In article , "Jim Carter" wrote: Isn't there a 15% tolerance allowed for certain types of flights in Alaska? Part 135 only. And even then it's not just an "automatic" increase. |
| Thread Tools | |
| Display Modes | |
| Apache Alternate Gross Weight | Jim Burns | Owning | 1 | July 6th 04 06:15 PM |
| Dutch Roll | SelwayKid | Piloting | 31 | June 20th 04 12:43 AM |
| homebuilt safety | anonymous coward | Home Built | 96 | June 3rd 04 05:34 AM |
| Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 05:03 AM |
| F35 cost goes up. | Pat Carpenter | Military Aviation | 116 | April 11th 04 08:32 PM |
