fiberglass repair?
Old August 10th 15, 01:47 AM posted to rec.aviation.soaring
Default fiberglass repair?
When attempting to modify my battery tray (and suffering from dehydration) I mistakenly cut through the outer skin of the fuselage.
The damage is approx 2" x 1/32nd".
Is this structural or cosmetic?
https://drive.google.com/file/d/0B79...ew?usp=sharing
How would the fiberglass guru's here repair the damage?
Advice is much appreciated,
Nick
Old August 10th 15, 01:55 AM posted to rec.aviation.soaring
Bill T
I'm not a fiberglass expert. But a through and through cut needs to be repaired properly just like an impact that would have cracked the hull.
Directions are in the maintenance manual, to include scarfing to widen the repair area, laying in epoxy, cloth, etc. Sanding and refinishing.
A simple repair, not done properly, could crack and get longer as the fuselage flexes in turbulence and with temperature changes.
BillT
Old August 10th 15, 03:29 AM posted to rec.aviation.soaring
I respectfully suggest that someone who cuts through the fuselage in an attempt to repair a batter tray should not be repairing the fuselage.
Just a thought.
Old August 10th 15, 03:31 AM posted to rec.aviation.soaring
Lots of people have done it jackass. Ask around. It ain't that uncommon
Old August 10th 15, 04:37 PM posted to rec.aviation.soaring
Eric Munk
And don't forget the correct curing temperatures of the repair. Cutting
corners there significantly reduces strength in the affected area.
Old August 10th 15, 08:50 PM posted to rec.aviation.soaring
BillT
What is the context of this thread?
UH
Old August 10th 15, 09:12 PM posted to rec.aviation.soaring
Andreas Maurer
Definitely structural. Major. Pretty bad spot for such a damage.
A proper repair is going to require about one square ft of multilayer
skin replacement and some practice.
Get the glider into a repair shop if you haven't done such a major
repair yet.
Best of luck
Andreas
Old August 10th 15, 10:16 PM posted to rec.aviation.soaring
repair yet.
Best of luck
Andreas
"Major ARRRRGGGHHHHH......"
Where did your text come from?
This thread showed very little.
"Prepare for sanding/grinding...... glass & resin, more sanding, Gelcoat, finishing & polish/wax......
"Ehhhh..... cover it in '150 MPH tape', placard the ASI to 149MPH and call it a day......"
Just kidding folks......
Old August 10th 15, 10:31 PM posted to rec.aviation.soaring
Brad[_2_]
the OP should seriously consider finding a wrecked ASW-19 with a good forward fuselage, and graft it on to the tail boom of the original glider. everybody knows that older generation glass used such skimpy and poor quality materials......and a 2" x 1/32" slit is asking for severe structural failure......perhaps even causing the fuselage to buckle by just rolling it out of the trailer.
Brad
Old August 11th 15, 01:59 AM posted to rec.aviation.soaring
repair yet.
Best of luck
Andreas
Original poster- contact me off line and I will give you some guidance without the panic mongering.
UH
Fiberglass glider repair in Southern California? Roger Worden[_2_] Soaring 4 September 2nd 12 03:37 AM
this guy doesn't believe in fiberglass rwhughe Aviation Photos 0 February 27th 10 07:05 AM
Fiberglass revisited Lou Home Built 3 October 31st 06 01:50 PM
Fiberglass seperation Lou Home Built 7 September 25th 06 05:03 AM
Fiberglass/gelcoat repair question Kilo Charlie Soaring 9 April 19th 05 04:30 PM
