Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
oddball Radio - FM / data on Airband frequencies
Old February 10th 20, 10:59 AM
jhh jhh is offline
Junior Member
First recorded activity by AviationBanter: Oct 2009
Default oddball Radio - FM / data on Airband frequencies
I have a Motorola XTS3000 hand-held transceiver which I purchased some years ago. The radio has a Federal gov't history.
The radio has about 10 frequencies/channels programmed. When the xmit button is pushed, the radio will xmit until power is cut to the radio. This xmit is a 'data stream'. Channel are named HRR-nnn and one channel is HRX-nnn. The descriptions associated with the channels ate: SAW-ON, SWA-OFF and SWA-LONG
So, the question is: does any of of this nomenclature ring any bells in the aircraft world. Particularly dealing with electronics ?
HRR-nnn
HRX-nnn
SWA-ON
SWA-OFF
SWA-Long
three of the frequencies:
133.860 Mhz
134.160 Mhz
134.460 Mhz
thanks, jack
Permit to use aircraft radio frequencies on ground C. J. Clegg General Aviation 23 January 20th 05 07:23 PM
Permit to use aircraft radio frequencies on ground C. J. Clegg Restoration 1 January 1st 05 10:08 PM
Satellite Radio to broadcast weather data Richard Kaplan Instrument Flight Rules 6 July 4th 03 06:30 PM
Satellite Radio to broadcast weather data James M. Knox Owning 4 July 4th 03 06:30 PM
Satellite Radio to broadcast weather data Richard Kaplan Owning 2 July 4th 03 04:45 PM
